Sponsored by: Real Truck
Gas vs PSD
Old Dec 14, 2009 | 10:18 PM
  #3046
T8R's Avatar
T8R
Originally Posted by Sand_Man
Know what's guaranteed to double torque, tripple mileage and ensure everlasting relabilty in your engine regardless of it being gas, diesel or plutonium-powered? Just start a pointless debate on the internet...
Apparently bullsh** is better than biofuel or additives. There's an endless supply of it too.
Old Dec 14, 2009 | 10:20 PM
  #3047
bill11012's Avatar
bill11012
Modular motor junkie
hahaha, I think every body here is being honest.
Could you imagine if I got 1/3 the MPG I was claiming? lol
Old Dec 14, 2009 | 10:25 PM
  #3048
95_Dually's Avatar
95_Dually
Sand_man, T8R: very good posts. Laughing too hard.
Old Dec 14, 2009 | 10:51 PM
  #3049
2001400ex's Avatar
2001400ex
Originally Posted by phillips91
It is actually a 5.4, but pretty much the same thing. Now that you mention "stirring the pot" I think I hear Bill's mom coming. She thinks you are talking about food
Hmmm, I skimmed the last few pages, but I could have sworn this was a V10 vs. psd argument. LOL my bad!
Old Dec 14, 2009 | 11:03 PM
  #3050
95_Dually's Avatar
95_Dually
The V-10 can get Bills mama to the restraunt faster, but after she eats, the PSD needs to be used to get her home.
Old Dec 15, 2009 | 12:32 AM
  #3051
ddemetrius456's Avatar
ddemetrius456
With the V10, you basicly gas up and go. Normal maintenance, 6 qts of oil every 3K etc. With the PSD it's 14 qts of special oil , test strips for the coolant, draining the water out of the fuel filter, cold weather problems. Also in AZ, diesel fuel is about 10 cents a gallon more than Unleaded. Ford rates the V10 just a tad more in towing capacity. (actually the weight difference between the V10 and PSD) In therory, there shouldn't be any difference. I'd give the nod to the PSD for heavyduty towing.
__________________
Wonderbra
Old Dec 15, 2009 | 12:37 AM
  #3052
bill11012's Avatar
bill11012
I agree with all of that.
They are both rated at 33,000.
__________________
Old Dec 15, 2009 | 01:11 AM
  #3053
2001400ex's Avatar
2001400ex
__________________
I assume you mean combined weight rating and even then it would have to be a 450. Even the one ton dually is not rated that high.
Old Dec 15, 2009 | 10:30 AM
  #3054
brian42's Avatar
brian42
Veteran: Navy
Some of us have a "newer" PSD so don't need the test strips, but I need an extra quart of oil on top of that (don't short me my extra $4 ). Sure I drain a pint of fuel every month to get all the water out (you would think diesel would be cheaper because the negligible refining process compared to unleaded ) so there's some more money down the drain (literally), but that's nothing compared to the fuel/water filter I have to replace every 10K or so ($20-$50 per filter, depending on where you buy it from). Couple that with the fact that a 4x4 CC SB diesel has a slightly reduced towing compared to the other configurations and.......wait a second, I'm supposed to be arguing FOR the PSD!
Basically it comes down to this simple equation:
Low IQ + Lots of extra money = Happy diesel owner!!!
-or-
Loud injector cackle + No spark plugs = Man Points
By combining these two equations you get the following result:
You can either have money or be a man.
Old Dec 15, 2009 | 12:14 PM
  #3055
bill11012's Avatar
bill11012
You have to get the F550 to get that much towing with either motor.
Old Dec 15, 2009 | 03:47 PM
  #3056
phillips91's Avatar
phillips91
Originally Posted by T8R
That's what I love about torque.
You drove 60 miles in OD with no lower gears?
I was actually in my Bronco, which was not a fun drive. I had to floor it to pull out and get up to speed. When I saw a hill coming up I just sped up to about 70 to keep from having to downshift.
Old Dec 15, 2009 | 03:51 PM
  #3057
phillips91's Avatar
phillips91
With my PSD I just "gas" up and go too. My "special oil" is in the same aisle and on the same shelf as the v10 oil, but there is one difference. It's about $1 cheaper per quart than the v10 oil. Test strips cost about $1 each and coolant only has to be checked every 25k miles. For most people that's about every 5 years. Diesel fuel may be 10 cents per gallon more expensive, but my PSD gets much better mpg's than the v10, so I pay less per mile. Haven't had any cold weather issues with mine yet either.
Old Dec 15, 2009 | 05:11 PM
  #3058
brian42's Avatar
brian42
Veteran: Navy
What is a "downshift"?
Old Dec 15, 2009 | 05:29 PM
  #3059
bill11012's Avatar
bill11012
So you don't have to down shift ever?
Real Men Have at Least Twice as Much Torque as Horsepower
Haha, You just add that to your sig? I have not noticed it before.
Old Dec 15, 2009 | 05:35 PM
  #3060
bill11012's Avatar
bill11012
