The HHO injection thread
Old Sep 12, 2008 | 06:10 AM
  #781
dlmcbm's Avatar
dlmcbm
You can adjust ICP with a defuser 18K. I have one with a hypertec 3 programmer but have seen no fuel mileage gain. the best part is that it has not gone down either. The best thing to do is search for "real peoples" fuel mileage gains with other programmers to see what is the best. I like Tony Wildman chips because he programs them per truck and I am sure he has got a lot of people asking for a fuel mileage setting. I want to get one of his chips myself but $$$$$ is to tight right now.
Old Sep 12, 2008 | 07:13 AM
  #782
sam-e's Avatar
sam-e
i have a super chips tuner,programed back to stock a few months back when the trany went out, ford installed trany #5,have not reprogramed,sence i didnt noticed much differance,guess ill try it again to see what happens ,$$$$ is tight for me too
Old Sep 17, 2008 | 07:23 PM
  #783
dlmcbm's Avatar
dlmcbm
well my results are in and its not good. like i said i am only making 1-1.5LPM and i dont think this is enough. my truck has got a low fuel milage of 15.5 and a one time high of 18.3 and average high is more around 17.5. for some reason my 15.5 is in the winter and 17.5 is in the summer. for the last few tanks i have been about 17.3 and this full run with HHO i was at 16.3. this may be because it has cooled off a lot here the last week or so. Now i am running a tank with out HHO again to see milage to get a good before and after. if i get 16.3 then i will say that i just need more HHO BUT if i get 17.3 i just might throw the thing away LOL. we will see what happens.
Old Sep 17, 2008 | 08:16 PM
  #784
sam-e's Avatar
sam-e
my results arent much better,sence my last post 9-10-08 the fuel tank switch went out,topped off again9-16,11.17 mpg,picked up new switch today,install tonight .i reinstaalled superchip programer on tow safe, to see what happens
Old Sep 20, 2008 | 09:49 PM
  #785
99FordGuy's Avatar
99FordGuy
Originally Posted by Dave Sponaugle
I know the local pool supply has KOH, but I never can make it there before they close.
What do they call it at the pool supply? I went by a pool supply today and no one there knew what I was talking about.
Old Sep 20, 2008 | 09:55 PM
  #786
99FordGuy's Avatar
99FordGuy
Originally Posted by dlmcbm
Doug the first 2-3 sentences would have been fine to answer my question. Thanks for the explanation. I am just an auto mechanic not a scientist. By the way Diesels (until 06-07) don't have anyway to stop the air flow. They can take in as much as they want. everything is controlled by how much fuel you put in. More fuel the RPMs go up less fuel they come down. I have an 01 power stroke so if i add hydrogen to the system the rpms will want to come up, the computer sees that then slows down the injector pulse width and puts in less fuel to bring the rpms back down. in the end that makes less diesel in the cylinder so better fuel mileage. not to mention burning all the fuel by adding hydrogen creates more power so the computer puts in less fuel again and more MPG.
Do you know if my 05 6.0 will work the same way yours does? I can't find any info on if the 05 has a MAP or 02 sensor.
Old Sep 25, 2008 | 03:27 PM
  #787
sam-e's Avatar
sam-e
just topped off tanks today,f/tank 170.9 mi. 15.5 gal.-11.03 mpg, r/tank 160 mi. 12.12 gal.-13.20 mpg total miles 330.9 total gal. 27.62 over all mpg 11.98
Old Sep 26, 2008 | 07:52 AM
  #788
99FordGuy's Avatar
99FordGuy
sam-e
What year/engine do you have? I wonder if your computer is what is killing your MPG gains?
Old Sep 26, 2008 | 05:10 PM
  #789
sam-e's Avatar
sam-e
99fordguy, its a 1996 7.3 psd,with a1997 computer
Old Sep 27, 2008 | 09:14 PM
  #790
99FordGuy's Avatar
99FordGuy
Does the 96 have a MAP sensor? If so you probably need to get a adjustable MAP enhanser.
Old Sep 27, 2008 | 09:39 PM
  #791
sam-e's Avatar
sam-e
yes it does ,and i built a map enhanser,its adjusted just this side of turning the check engine light on ,also have super chip tuner installed,dont know if i need to get anew enchanser
Old Sep 28, 2008 | 02:11 PM
  #792
444dieselrod's Avatar
444dieselrod
some please refresh me on why you are running a map enhancer on a Turbod diesel engine, and what the advantage is because I dont think it will work.
Diesel Rod
Old Sep 29, 2008 | 08:02 AM
  #793
99FordGuy's Avatar
99FordGuy
I checked this weekend and my 05 does have a MAP sensor but no O2 sensor. I don't know if I need a MAP enhanser or not. I realy can't find any info as to if it is needed. Has anyone noticed a difference with or without an enhanser?
Old Sep 29, 2008 | 08:12 AM
  #794
sam-e's Avatar
sam-e
im going to try it with out the enhanser to see if it makes a difference or not,let you know.
Old Oct 1, 2008 | 02:08 PM
  #795
coskierken's Avatar
coskierken
Ok, newbie here. I have did quite a bit of research. I am about to take on the daunting task of building my first HHO smack booster design. More of the first science project on the use than anything. Things I have learned (read) is that is NaOH NOT COMPATIBLE with PVC(KOH compatible) and no toxins produced. ABS is resistant to acids (KOH or sodium hydroxide) and has a temp ceiling of 158 deg F, which is higher than PVC and it is less expensive. I will be installing a PWM with the unit to control any heat. It will be an 8 cell design and I will wrap the plates to reduce the amount of loss and thus less heat and more gas. I would like some help on the minimum amount of HHO needed in the cruise range of 1500 to 2000 rpms. I remember someone doing the math, but I can't locate it right away. Thanks in advance for any advice. Oh, Ford PSD 6l.
