Crewcab Only Thread.
Old Oct 21, 2010 | 09:43 PM
  #1216
Turner's Avatar
Turner
77 250 crew cab 2wd 460 swb auto trans.
79 350 crew cab 2wd 351m lwb 4 speed
79 350 single cab 4wd 351m lwb 4 speed
I am in the process of making the 79 crew 4wd. I am doing the 79 half ton style on the front with a coil sprung dana 60 and a dana 80 disc brake in the rear. She is my baby.
Did someone put the 460 in your 77 or make it 4wd? Or did you? Ford didn't offer a 460 in a 4wd truck until 86 or so.
I am looking for a good hood for my single cab right now. And a independent 205 transfer case mount for my 79 crew cab.
Are you looking for any parts for yours?
Old Oct 21, 2010 | 10:18 PM
  #1217
Big Big Blue's Avatar
Big Big Blue
Yes I did put the 460 in the truck. It originally had a 400.
I am in the market for a good rust free roof off of a 73 - 79 F100, F150, F250, or F350. Of course I would prefer one from a crew cab but the odds of finding that are almost nill. I am also in the market for a decent bench seat, and dash pad. Also a set of aluminum wheels 16" or 16.5 x 8 on 6.5" minimum of 10" wide.
If I could find a good deal on both rims with decent all terrain tires I would be interested.
Old Oct 21, 2010 | 11:42 PM
  #1218
fordtrucknut's Avatar
fordtrucknut
I need crew cab rear door panels and pull straps!!!
Old Oct 22, 2010 | 07:19 AM
  #1219
Turner's Avatar
Turner
Well I know where there is a cab sitting on a frame. It is a crew cab. I don't know what shape it is in. I have asked about it before and didn't get an answer. I will call him again. If it had a good roof and door parts it would work for both of ya'll. How much would that be worth for the cab to pull those parts from?
Old Oct 22, 2010 | 05:09 PM
  #1220
Big Big Blue
If the cab is in decent shape I would be interested in purchasing the whole cab but I would need to see it before putting a price on it. The same goes for just the roof, I would need to see it.
Thanks
Old Oct 24, 2010 | 02:13 PM
  #1221
Turner's Avatar
Turner
I am trying to find out if he is going to sell it. I have been having a hard time getting an answer on it. I have been asking for 3 months. If I find out I will let you know for sure.
Old Oct 24, 2010 | 04:06 PM
  #1222
Big Big Blue
ok, sounds good.
Thanks
Old Oct 24, 2010 | 11:56 PM
  #1223
Skip1970's Avatar
Skip1970
that would be kinda neat to take 2 crewcabs and weld one on top of the other make a homemade double decker crew. if i can find another cab i just might try it!
Old Oct 29, 2010 | 12:13 AM
  #1224
mytybug's Avatar
mytybug
Hi, new to the thread, I have 3 crews one 78 2 wheel, one 76 highboy and one 77 highboy.
The 76 I am building and am looking at doing a power steering conversion from benchworksteering.com. Has anybody delt with this set up?
Old Oct 29, 2010 | 03:45 AM
  #1225
Skip1970's Avatar
Skip1970
wow thats pricy! wonder what box that is looks liek a bronco one, maybe you could get most the parts off other vehicles used and then just get he steering arm and the shaft form them to save some bucks
Old Oct 29, 2010 | 03:54 AM
  #1226
fordtrucknut
It's a 2wd box
Old Oct 29, 2010 | 10:25 AM
  #1227
mytybug's Avatar
mytybug
fordtrucknut you said that it is a 2whl box. Would it be the same as my 78?
Old Oct 29, 2010 | 05:17 PM
  #1228
crummy's Avatar
crummy
Hi there new to the crewcab section any way.
I own a 1977 F250 RangerXLT CrewCab HighBoy 4SP,NP205,60's F/R all original. Except motor,lockers and tires. go to my garage if you want to see pics of it and some of the spec's.
Here's a pic..
Old Oct 29, 2010 | 05:43 PM
  #1229
fordtrucknut
mytybug...is your 78 a 2wd?? I've done a conversion similar to this...but i sit the box back a little closer to the cross member so I don't have to cut as much out from the core support.
Old Oct 29, 2010 | 05:59 PM
  #1230
mytybug's Avatar
mytybug
Truck nut the 78 is a 2wh and it is a donor truck. I am useing the 400m it only has 3000 miles on it and the cab is near mint. I don't really want to do mod's to the frame, so what ever you have for wisdom I would be happy to hear
