6.0L Diesel: ..................Tech Folder..............
Old Nov 4, 2004 | 08:38 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
TECH FOLDER
Check back...we update often
How to post pictures: Adding pictures to threads.
Sensor and Actuator data vs output voltage. Click Here
Thanks Bismic
Frame Mounted Third Battery. Installation
Thanks WatsonR
New 11/2017 (5R110 transmission Cold fluid exchange) Home shop flush
Thanks, Syncrosmash
STC/HPOP Removal/Install with Tips & Pic's Step by Step Guide
Thanks, silverbullet6oh
High Pressure oil Pump Cover De-Confusion
Thanks, 4Kids
Scan Gauge 2 SYNC CODES View Single post
Thanks, BLADE35
Questions or thinking of buying a used 6.0L truck? Click here
Thanks, Bismic
2008/2009 Wiring Pigtail Kit Identification Catalog PDF1 PDF2
Index Of Ford Manuals PDF Manuals
Our list has grown! If you have a manual to contribute contact us.
6.0L head lifting bracket.... Build your own!
Thanks, Lilpooh
Trobuleshoting Coolant loss Checklist
Thanks, Bismic
Powerstroke Cooling System Flush View Thread
Thanks, Nylyon
Coolant Flush, Change
Discussion and Instructions
Thanks, 03-6L-X, beachbumcook, and 69cj
BELT TENSIONER TOOL, Fabrication Article Click Here
Thanks Arizona97
Testing Injector Harness and Coils Click Here
Thanks, Bismic
FICM TEST Procedure Click Here
Thanks, Bismic
FICM How to FICM Guide
Thanks, pstrang
Detailed FICM Repair Procedure
Thanks, DrQuad
FICM Connector How To Repair Procedure
Thanks, Fixxxer-upper
Battery Cables Improving battery cables for battery life.
Thanks, TooManyToys
Camshaft Position Sensor (CMP) Wiring Pigtail replacement
Thanks, dchamberlain
Crankshaft Position Sensor Removal/Installation
Thanks, SmackDaddy
Ford Manuals in PDF Click Here
Head Bolt torque sequence change New Specifications PDF
Recommended Readings - Temperature & Pressure Click Here
Thanks, Bismic
Additional PDF Help links Click Here
Thanks, smokersteve
Troubleshooting a "low power" condition
Check List
Trouble Shooting a No Start Condition
Check List
Thanks, Bismic
Stiction Fix
Must read, Instruction and Video
Thanks, BLADE35
Injector Top O-Ring/Seals
The Whole Story
Thanks, creator
Injector Questions and Answers
Injectors Explained
Thanks Bismic
Changing Injectors
https://www.ford-trucks.com/forums/5...ml#post4355612
Thanks to Matt
Super Duty FAQ
Super Duty FAQ's
6.0 fix for various running problems
6.0 fix for various running problems...Must Read! - Ford Truck Enthusiasts Forums
Diagnosing 6.0L Oil Leaks
FIX ANY 6.OL LEAK By Wyatt66f100
Thanks Wyatt66f100
Recomendations for New to me owner of a used truck Checklist:
Thanks, Texastech_diesel
Turbo Up-Pipe Exhaust Leak Fix
Thanks, Holdendaniels
VGT Turbo ABC's Turbo Information
Thanks to Brickie and Bismic
VGT Turbo Rebuild Step by Step Instructions
Thanks, Benchwrench
Upgrade Torqshift Transmission filter 2008+ Filter & Pan
Thanks, diesel dan
Torqshift Shift Relearning Strategy
Thank you Bismic…
TorqShift Transmission Information and Troubleshooting
Thanks, Bismic
TorqShift P0713 TFT Sensor Failure Replacement Procedure
Thanks, Unrealo4
Electonic Shift on the Fly (ESOF) Discussion & Trouble Shooting
EGR Disconnect Instructions
EGR Disconnect Instructions - Ford Truck Enthusiasts Forums
And Cleaning
Scary pics of my 11,000 mile-old EGR valve - Ford Truck Enthusiasts Forums
Brought to you buy t_b
EGR O-Ring Ford Part Number
Egr-o Ring Ford Part# Is - Ford Truck Enthusiasts Forums
Thanks to eight301
EGR Cooler Hose Discussion & Procedure
Thanks to everyone, Blade35, amdriven2liv, Bismic
2003 & Early 2004 ICP (Injection Control Pressure Sensor)
Must Read Discussion on ICP, No start problems
Includes Part Numbers and removal proceedures
Thanks to all who participated
03/ Early 04 ICP Swap
Thanks, william_04_x
Water Pump Replacement
Thanks, fixxxer-upper
Crankcase Ventilation Rerouting
Crankcase Ventilation Rerouting - Ford Truck Enthusiasts Forums
Thank You Riggz
Inter-cooler hose clamp
Intercooler hose clamp - Ford Truck Enthusiasts Forums
Powerstroke 6.0 L Technical Intro Manual
Powerstroke 6.0L Technical Intro Manual
or
6.0L Bible Table of Contents pdf
'05 PSD Update to Powerstroke 6.0 L Technical Intro Manual
International Truck & Engine Corporation Publication
Features, Descriptions, Unique Service Procedures, and General Diagnostics of the 6.0L DIT Power Stroke
Thanks, Brickie
6.0 in very cold climate
Newbie considering 6.0 in cold climate - Ford Truck Enthusiasts Forums
Small Hint For Flash Programmer
UsersSmall Hint For Flash Programmer Users - Ford Truck Enthusiasts Forums
Thanks Matt
Controller Area Network Explained
Controller Area Network Explained - Ford Truck Enthusiasts Forums
and again thanks Matt
High Idle Mod 2003-2004 Click Here
2005-2006 Diesel Stop.com
Thank you hitecdan
UpFitter Switch wiring Click Here
2005 upfitter realy panel location?????? - Ford Truck Enthusiasts Forums
Engine Idle Control
Engine Idle Control - Page 6 - Ford Truck Enthusiasts Forums
Thank you me1mckee and JimReitz...
Body Builders Guide - includes PTO, snowplows, body sizes etc. Advisory Service
Change the Air Filter
Air Filter
Thank you Bismic…
6.0L Engine Oil change
CHANGING ENGINE OIL
Thank you Bismic
HFCM Filter Change and Fuel/Water Separator Drain Procedure
FUEL/WATER SEPARATOR DRAIN PROCEDURE
Thank you Bismic
Upper Fuel Filter, Engine
Changing Upper Fuel Filter
HFCM Water Separator Drain Plug Upgrade
PLUG INSTALL
Fuel Pressure Regulator Udate Kit Blue Spring Install
Thanks, Rusty Axlerod
Fuel Pressure Gauge Installation Procedure
Thanks, texastech diesel
Battery Disconnect —Dual
Battery Disconnect - Dual
Thank you Bismic
How to Harpoon the fuel tank
Harpoon The Tank? - Ford Truck Enthusiasts Forums
Thank you Bob
Engine Break in
breaking in the 6.0L - Ford Truck Enthusiasts Forums
Tow/Haul mode on start-up mod
TOW/HAUL- any way to set as start up default??? - Page 3 - Ford Truck Enthusiasts Forums
Thank you me1mckee...
Mirror Swap
'03 Mirror Swap - All Done! - Ford Truck Enthusiasts Forums
Thanks to Rick "Karic"...
Missing Items on the Super Duty
Missing Items on the Super Duty - Ford Truck Enthusiasts Forums
Thank you 04FordHarleyF250
Tractive Force graph
Tractive force graph (contains photos) - Ford Truck Enthusiasts Forums
Thanks to me
2002/2005 F-250/350 Proper Foglight Operation/ SUVLIGHTS Harness Fix
Thanks to big ride and 4X4 IN REFUGIO
Block heater cord routing Diesel Technician Society
Cord part number at International: Z3500043
Marinco Bumper Plug Installation
Thanks, EXbowtieguy
Ball Joint replacement
How to replace your Super Duty Ball Joints - Ford Truck Enthusiasts Forums
Thanks to RacerGuy
Transfer Case, Power Steering, Differential Oil
Additional Maintenance not addressed in Tech - Ford Truck Enthusiasts Forums
Thanks to Bear Hunter
Elimination of Door Chime
Elimination of Door Chime - Ford Truck Enthusiasts Forums
Thanks to kb1aah
MPH Speedo Calculator For Variable Tire Sizes
Speedometer Calibration Calculator And Information
DIY Coolant Filter
Information for the home built Coolant filter
Thanks to Diesel Dan and the rest who contributed
__________________________________________________ ______________
Old Jul 4, 2006 | 12:01 AM
kw5413's Avatar
kw5413
Instrument Cluster / Battery Altern ABS / Parking Brake Light / Illumination Issues Electrical Checklist and Tips
Thanks to gearloose1
Always bright overhead display: billgart.com - Lighting
Thanks for the find Customz
Greasing the driveshaft slip joint: Slip joint regreasing
Thanks again to Customz
Fuel Gauge (Gage) / Level - Read post # 7
Gas Guage - Ford Truck Enthusiasts Forums
Thanks to Hayapower!
Reprogramming "Flash" Procedure For Techs
Hey kw.... - Ford Truck Enthusiasts Forums Post # 13
Thanks vloney & huntercgr
6.0 Updates from Various Model Years
https://www.ford-trucks.com/forums/5...ml#post3974497
2006 6.0L Diesel Power Stroke Cylinder Head Commonization
Ford Truck Enthusiasts Forums - View Single Post - Differences between new 6.0 an old 6.0
Great Lie-O-Meter Explaination Post # 2
https://www.ford-trucks.com/forums/5...ml#post3990543
Thanks Matt.
CJ4 rated oil, from API...See Post # 19
https://www.ford-trucks.com/forums/5...ml#post4014847
Special Thanks To mrxlh
OEM Oil and Fuel Filters... What To Look For
https://www.ford-trucks.com/forums/5...ml#post4145955
Thanks to Beachbumcook...Great research.
__________________________________________________ _________________
Transfer Case Fluid change
Welcome to guzzle's Transfer Case Fluid Change Web Page
Thanks to Customz for finding
SRW rear differential fluid change
Welcome to guzzle's Rear Differential Maintenance Web Page
Front differential fluid change
Welcome to guzzle's Front Differential Maintenance Web Page
Replacement brake rotors and pads
Welcome to guzzle's Powerslot/Hawk pads brake Maintenance Web Page
Fabricated Aux. Fuel Tank
https://www.ford-trucks.com/forums/5...lly-sorry.html
Thanks to bczolone...Nice Work!
Tips to prevent common probelms
https://www.ford-trucks.com/forums/7...-problems.html
Thanks to bismic
Heated Seats Indicator
https://www.ford-trucks.com/forums/7...ndicators.html
Thanks to Benchwrench
Most asked Question: Best Mods for my truck?
Keyless Entry Code Keypad code & functions
Thanks to Jnobles06
knottyrope
Nov 17, 2024 04:42 PM
bismic
Aug 18, 2024 10:55 AM
Spool&Go
19
Jan 2, 2017 08:01 PM
Fabbed5.0
Sep 27, 2013 12:40 PM
kw5413
6.4L Power Stroke Diesel
Jul 6, 2009 07:26 PM
