99-03'_7.3L Link Bible !
Old Jul 22, 2010 | 05:09 PM
Spool&Go's Avatar
Spool&Go
Exclamation 99-03'_7.3L Link Bible !
Hey everyone,
I was directed to a Forum where everyone posted excellent links for various mods and repairs. I am not attempting to offend anyone or plagiarize anyone's hard work. I went through and compiled all of the links on that forum so people who didn't know it existed at can more easily find answers to their questions without even having to ask! Thanks to everyone who contributed these links and write ups and I hope you all don't mind that I put them together.
P.S. There is no harm in asking questions. Just thought I'd throw it all together.
Bryce
__________________________________________________ _______________
Links:
ball joints
https://www.ford-trucks.com/forums/sh...d.php?t=354091
atf change
https://www.ford-trucks.com/article/i...nsmission.html
cps change
https://www.ford-trucks.com/article/i...ke_Diesel.html
hutch mod
Fuel By-Pass And Regulator Install pictures from cars photos on webshots
F250 Diesel Fuel Supply Modifications pictures from cars photos on webshots
replacing injectors
https://www.ford-trucks.com/forums/sh...injector+rings
Wicked Wheel
https://www.ford-trucks.com/article/i...tallation.html
externally regulated fuel/air bleed mod
https://www.ford-trucks.com/forums/sh...d.php?t=260173
https://www.ford-trucks.com/forums/sh...d.php?t=446151
a little gauge help
https://www.ford-trucks.com/forums/sh...ghlight=gauges
wicked wheel w/o removing turbo
http://www.blackclouddiesel.com/Tech...on%20Guide.pdf
exhaust break
https://www.ford-trucks.com/forums/sh...d.php?t=268610
wastegate
https://www.ford-trucks.com/forums/sh...ght=waste+gate
Gauge Installation Walkthroughs:
http://www.dieselmanor.com/diy/PSD3-...D3gauge-p1.htm
http://www.gts-motorsports.com/gaugemountinst.html
Gauge Install
Keep Overhead console from dimming when headlights/parking lights are turned on:
billgart.com - Lighting
Wicked Wheel Installation (turbo off the truck):
http://dieselsite.com/wwinst.pdf
Getting rid of the Clunk when putting truck in gear:
(greasing the rear driveshaft slip joint)
Slip joint regreasing
Harpoon Mod link:
http://65.121.190.196/diesel/intank/
SteveRacer Mod:
S&S Diversified
7.3L PSD "bible"
http://www.nav-international.com.br/...rStroke/hs.asp
Replacing Superduty Ball Joints:
CPS Issues:
forgotton.net
Tightening the Parking Brake:
post by SmokeyWren on TDS
The parking brake is an old-fashioned drum brake up inside the rear rotors. It's called a "drum-in-hat" rotor.
The only adjustment available is to adjust the drum brake shoes.
Look on the back side of the hub and you'll see a rubber plug. Remove that plug and look inside and you'll see the "star adjuster wheel". Turn that star adjuster until it's tight, then back off only until the wheel will rotate freely.
Shadetree mechanics can "get by" using a flat-blade screwdriver to turn the star adjuster. But it's fairly easy to do with a special brake adjusting tool - available for only a couple of bucks from almost any auto parts store.
Here are the words from the workshop manual:
Quote:
Parking Brake Shoe and Lining Adjustment
• Raise and support the vehicle.
• Remove the wheel and tire assembly.
• Remove the brake adjusting hole cover from the backing plate.
• Turn the brake adjuster screw to expand the parking brake shoe and linings until they drag against the drum-in-hat rotor.
• Back off the brake adjuster screw until no drag is evident.
Amount of Fuel Burned when Idling:
- at idle of 650-670 rpm, engine consumes about 1 1/3 (1.33) quarts per hour, or about 1/3 gallons per hour.
- at idle of 1200 rpm, engine consumes about 2 3/4 (2.75) quarts per hour, or a little over 2/3 gallons per hour.
info credited to WayneT at TDS
ESOF information:
https://www.ford-trucks.com/forums/sh...d.php?t=436756
Common or not so Common but well worth it, replace the stock screw jack with a 6 or 8 ton bottle jack. The 6 ton fits the same spot as OEM jack. If you have ever had to use the screw jack, you already know what I am talking about, 15 bucks or so at Wally world can save a whole lot of headache.
__________________
https://www.ford-trucks.com/user_gall...id=153297&.jpg
I didn't see any instructions for shimming the stock pressure regulator. I got to searching and I thought these were really good instructions:
Fuel Regulator Shims pictures from cars photos on webshots
Removing the E-clip on wastegate arm, for removing or replacing wastegate actuator:
https://www.ford-trucks.com/forums/sh....php?p=3716297
Here is a link to how to do a Lighted display for a flip chip
https://www.ford-trucks.com/forums/sh...d.php?t=488652
IPR rebuild: New Page 0
IPR o-ring kits: https://www.ford-trucks.com/forums/sh...d.php?t=501097
Rebuilding HEUI injectors at home: http://www.thedwilsons.com/powerstro...-Assembly.html
SpringerPop's 6637 dust cover: https://www.ford-trucks.com/forums/sh...d.php?t=476325
Upgrading to/wiring up 2003+ TT mirrors with heat/clearance/turn signals:
https://www.ford-trucks.com/forums/sh...d.php?t=123257
Fat Diesel's brake fluid flush made easy, with pics:
https://www.ford-trucks.com/forums/52...with-pics.html
Fuel leak from fuel bowl drain... Changing o-rings on fuel bowl drain lever
https://www.ford-trucks.com/forums/31...king-fuel.html
posts by SpringerPop
Source for o-rings:
http://www.puredieselpower.com/catal...ngs-p-103.html
DIY Tymar aka "kwik filter" aka 6637
https://www.ford-trucks.com/forums/54...s-h-u-g-e.html
Check here for a listing of all the links from our old common mods thread
thai tv learn women speak at 7point3.com
Task: Wicked Wheel
Your Ability: Shade Tree
Cost Est: $100 - $200
Benefits: increases air flow, anticipate 5-10% more HP below 1,000 RPM
When: 1st year mod
Recommend combine with: Tymar aka "kwik filter" aka 6637, 4-5" exhaust
Link: https://www.ford-trucks.com/article/...stallation.html
Task: CPS R&R
Your Ability: Novice
Cost Est: $0-$100
Benefits: You will be stranded on the side of the road if you don’t.
When: ASAP
Recommend Combine with: N/A
Link: http://guzzle.rbmicro.com/cps.html
Task: Break Flush
Cost Est: $0-$100
Benefits: Regular Maintenance
When: 75,000 Miles
Link: https://www.ford-trucks.com/forums/52...with-pics.html
7.3L oil leak from hpop end plug
https://www.ford-trucks.com/forums/56...look-here.html
Diagnosing vacuum leak when auto-hubs 4x4 stops working, and heat/AC switches to defrost when it shouldn't:
https://www.ford-trucks.com/forums/59...ped-workn.html
Cheap and quick mods, from bdrummonds: AIH delete with boost tap, underhood mechanical fuel pressure gauge, adjustable map fooler:
https://www.ford-trucks.com/forums/64...cant-wait.html
Wrench On!
Old Jul 22, 2010 | 05:20 PM
Blackbeltdually's Avatar
Blackbeltdually
Thanks for the wealth of information. You are right, new users like me will find this helpful.
Old Jul 22, 2010 | 05:38 PM
Spool&Go's Avatar
Spool&Go
No problem! I have noticed that a few of the links are broken. When this is the case, just use the info/titles for your forum searches. I would suggest searching under "Titles only" when looking for something specific. Hope this helps.
Old Jul 22, 2010 | 05:41 PM
tdpower's Avatar
tdpower
If you click on the RHN link in my signature it has a lot of links. Maybe that is where you got them from. Some of my other favorites are in my sig. I save them to a word document and then can hyperlink. To many for Bookmarks. Thanks for sharing.
Old Jul 22, 2010 | 05:49 PM
Spool&Go's Avatar
Spool&Go
Right on. Thanks for the info. Reps to you!
Old Dec 17, 2010 | 02:33 AM
joe Kikiwai's Avatar
joe Kikiwai
Thanks just what I was looking for!
Old Dec 17, 2010 | 02:44 AM
joe Kikiwai
Spoke to fast all you links don't work! Bummers
Old Dec 17, 2010 | 02:46 AM
Muktown's Avatar
Muktown
Here is some awesome info for everyone. I printed it out and keep it in the truck. Alot of pages but may save a tow someday. Most things are the same or similar between obs trucks and super dutys
http://pages.prodigy.net/stevebaz/_i...az/index3.html
Old Dec 17, 2010 | 09:56 AM
Brother Les's Avatar
Brother Les
I was directed to a Forum where everyone posted excellent links for various mods and repairs. I am not attempting to offend anyone or plagiarize anyone's hard work. I went through and compiled all of the links on that forum so people like me who didn't know it existed at first can stop bothering all of you veterans with questions that have the answers posted already on the site. Thanks to everyone who contributed these links and write ups and I hope you all don't mind that I put them together.
Bryce
Hey Bruce, thanks for the reminders of some of the great write up that have been put here by members. One thing that I have noticed is that these 'veterans' have become just that...'veteran' because they like to interact with everyone here at FTE. The 'vets' know, just as the 'newbies' that it is impossiable to know everything about these trucks and we are all one big Family that helps each other any way possiable. There is the 'Search the thread' mode, but many times instead of 'going alone', the 'vets' are there just waiting to asked about the how toos and the what fors.
Old Dec 17, 2010 | 10:02 AM
Spool&Go's Avatar
Spool&Go
Strange. They all worked when I made this thread!
I'll have to go through it soon and update all the links. Sorry about that!
Old Dec 17, 2010 | 10:18 AM
driximus's Avatar
driximus
Lots of great info there. Thanks to everyone who takes the time to do this for everyone else. And Thanks Spool for putting it all in one thread.
Dare I say Sticky?!!
Old Dec 17, 2010 | 11:41 AM
Spool&Go's Avatar
Spool&Go
Haha thanks drix !
Old Dec 17, 2010 | 11:49 AM
cj45lc's Avatar
cj45lc
Good deal Bryce, nice to see everything together in a thread. Got a lot of time on your hands bud...lol
Old Dec 17, 2010 | 12:34 PM
Spool&Go's Avatar
Spool&Go
Haha not really any more. Posted this one a long time ago. How you been CJ?
Old Dec 17, 2010 | 01:03 PM
cj45lc's Avatar
cj45lc
Doing great bud, I'm ready for summer tho...how you doing?
