Sensor and Actuator data vs output voltage
Old Dec 30, 2023 | 07:42 AM
bismic's Avatar
bismic
From the 2003 6.0L bible (Coffee Table Book), I pulled the charts (attached below) that show voltage output for most of the 6.0L sensors, and the EGR valve.
This information can be helpful during troubleshooting.
EBP:
Baro:
MAP:
ECT:
EOT:
IAT1:
IAT2:
ICP:
MAF:
APP:
EGR:
Old Dec 30, 2023 | 08:04 AM
bismic's Avatar
bismic
For 03 ICP sensor
I have posted these before, but they belong in this thread also.
More detail on ICP sensors (from Ford data and using least squares method of curve fitting)
__My curve fit data for the 03 ICP sensor_pressure vs voltage:
For Tables below: Gray highlighted cells are Ford data, Light green highlighted cells are my calculated data.
__Table 1 for my curve fit data for the 03 ICP sensor_pressure vs voltage:
__Table 2 for my curve fit data for the 03 ICP sensor_pressure vs voltage:
Old Dec 30, 2023 | 08:11 AM
bismic's Avatar
bismic
For 04.5+ ICP sensor
As above, I have posted these before, but they belong in this thread also.
More detail on ICP sensors (from Ford data and using least squares method of curve fitting):
__My curve fit data for the 04.5+ ICP sensor_pressure vs voltage_chart 1:
https://www.ford-trucks.com/g/picture/32204549
__My curve fit data for the 04.5+ ICP sensor_pressure vs voltage_chart 2
https://www.ford-trucks.com/g/picture/32204550
__Table 1 for my curve fit data for the 04.5+ ICP sensor_pressure vs voltage:
https://www.ford-trucks.com/g/picture/32204554
__Table 2 for my curve fit data for the 04.5+ ICP sensor_pressure vs voltage:
https://www.ford-trucks.com/g/picture/32204558
Old Dec 30, 2023 | 11:41 AM
six_eaux's Avatar
six_eaux
Thanks for the information. Hope I can remember where it's at when I need it!
Old Dec 30, 2023 | 12:16 PM
Jokester00's Avatar
Jokester00
Thanks @bismic good stuff!!
Just to clarify, i'm assuming these values (more specifically ICP) are while running the STOCK PCM tune, correct?
-jokester
Old Dec 30, 2023 | 01:24 PM
bismic's Avatar
bismic
Yes, it is based on stock calibrations. All data is from International/Ford, or my calculations based off of their information.
Old Dec 30, 2023 | 01:38 PM
Fuzzpuss's Avatar
Fuzzpuss
This belongs in the tech folder.
Thank you Mark for yet another outstanding contribution to the 6.0 community.
Old Dec 30, 2023 | 02:16 PM
diesel_dan's Avatar
diesel_dan
Great job Mark! I requested John to add this to the Tech Folder...
Old Jan 2, 2024 | 11:53 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
You didn't do my favorite, the oil pressure switch
KirkF
24
Nov 6, 2024 11:35 AM
bk0005
25
Sep 28, 2022 10:42 AM
BrandB09
Nov 19, 2019 08:48 AM
not enoughsmoke
Engine Swaps
65
Jul 26, 2013 08:11 PM
76f350spercamprspeal
S. California Chapter
Jun 22, 2011 12:14 AM
