DIY head install/remove bracket.
Old Dec 8, 2012 | 08:20 PM
Lilpooh's Avatar
Lilpooh
First wanna say thanks to Dale (Jugermaut) for supplying me with the OTC bracket for measurements. Bryan (Tuscany) for helping me with my welding skills. Thanks guys!
Please do not PM me with request to make this bracket. Thanks!
List of material and tools.
Flat stock 2 1/2" wide X 1/4" thick X 8 15/16" long, and 4" wide X 1/4" thick X 8 15/16" long.
Center drill
"L" drill
2" colbalt hole saw
Bendable flat metal (105* jig)
Four 1/4 X 20 X 1 1/2" bolts/nuts
Four 1/4" washers
Four 6m X 1.0 X 45mm long bolts
Four 1/8" NPT black pipe couplers (3/4" long)
When cutting length of flat stock, be sure it's square with factory edge. Marked in "yellow" is the measuring start points (bottom edge and right edge).
Come off the bottom edge of the 2 1/2 flat stock to 5/8" and mark/scribe the length of piece. Now coming off the right edge to 13/16" and mark/punch for your first hole to be drilled.
At this point if you have new/used intake gaskets laying around, used the marked/punched dimple as a guide. The 5/8" marked/scribed line will be your guide for the left hole.
Now mark/punch the top two holes, if you used the gasket to mark/punch your holes, then your ready to move down and start drilling.
Those of you who don't have a gasket handy, look at the pic below to get your measurements. Be sure your right edge is square with the factory bottom edge.
Time to drill bottom plate. Drill the punch marks first with a center drill so the "L" drill don't walk on you.
Next, take the 4" flat stock piece and make sure the right edge is square with the factory bottom edge. Use the pic below to get your measurements for the 2" hole saw.
After you marked/punched where the 2" hole is going, use the center drill to start a hole and prevent the hole saw drill from walking.
Now for the hole saw, it's best to use a drill press. You can try using a hand drill, but might have trouble holding the drill square and cause the hole saw to "bind".
Your going to keep the RPM's slow when using a hole saw. Going at a faster RPM will cause the hole saw to "chatter" and "burn up" the teeth on the blade. Use oil to keep the teeth cool, and remember "SLOW RPM"!!
After you have the 2" hole in the 4" flat stock, you need to "bevel" the bottom edge for welding, and the 2 1/2" flat stock will get a bevel on the top edge.
NOTICE in all the pics, your 4" flat stock will have the 2" hole just left of center. The 2 1/2" flat stock will always have the very first measured/marker hole on the bottom/right. DON'T accidentally "flip" one of the pieces and weld them on backwards.
Now move onto making the 105* template/jig. I used metal drawer dividers. Anything flat that can be bent and stay sturdy. Give them a bend till your at 105*.
Back to the bracket, clamp the 4" flat stock in a vise. Use the 105* templates/jig and clamp them to the 4" flat stock.
Now put your 2 1/2 flat stock onto the 105* jig and adjust until your "bevel" edges line up, also match up the two flat stock pieces line up length wise.
Now check to be sure you still have 105* angle.
Now your ready to weld the back side of the bracket.
After the bracket has cooled, flip over and weld the front side.
You are ready to add the 1/8" NPT couplers. I used 1/4" X 20 bolts/nut/washer to bolt the coupler to the bracket. Try to keep the coupler hole centered up with the bracket hole. Now tack weld these couplers to bracket (pic below). These couplers act as a spacer needed for the head/rocker box clearance.
At this point you are done. You can cut off the corners of the top of bracket or leave it square. I chose to cut the corners off for "looks".
When hooking up the chain to bracket for lifting/install head, Dale set the chain up thru the back of bracket and locked it in with a ratchet extension. I don't know how a hook will work, but Dale's method kept the head at the right angle to lower the head evenly with the block/head gasket.
You will use the 6m bolts and washers to bolt the bracket to head for lifting/install.
Old Dec 8, 2012 | 08:24 PM
bismic's Avatar
bismic
'Bout time you posted this info here - lol.
Thanks for documenting this Rich.
Old Dec 8, 2012 | 08:38 PM
Lilpooh's Avatar
Lilpooh
LOL! Thanks Mark! I suck at typing, so the original post took me 2hrs!! This one took me 1/2hr of copy/paste! HA!
Old Dec 8, 2012 | 08:42 PM
m-chan68's Avatar
m-chan68
That sure looks like an interesting piece of work right there for those of you choosing to lift/install the heads on these engines with the cab bolted to the frame.
Old Dec 8, 2012 | 08:51 PM
Lilpooh's Avatar
Lilpooh
LOL! It sure beats breaking your back! Ahhh, to be in my 20's again! HA!
Old Dec 8, 2012 | 08:54 PM
cheezit's Avatar
cheezit
looks just like the oe one. sure it works like it too, great tool to have.
the upside is this is a pretty easy build if you have a welder laying around.
Old Dec 8, 2012 | 09:00 PM
Lilpooh's Avatar
Lilpooh
Yep, copied the OE bracket made by OTC. The first pic is the OTC in action, the second pic is the DIY in action.
Old Dec 8, 2012 | 09:03 PM
Maxium4x4's Avatar
Maxium4x4
I think he is serious about getting them heads out Nice job! Would you like this added to the Tech Folder for future reference?
Old Dec 8, 2012 | 09:36 PM
bismic's Avatar
bismic
What was the OTC part number (do you recall)?
Old Dec 8, 2012 | 09:38 PM
Lilpooh's Avatar
Lilpooh
Thank you!
Tech Folder..... Sure why not, it will be easier to find after I get slammed with PM's! LOL!
Old Dec 8, 2012 | 09:40 PM
Lilpooh's Avatar
Lilpooh
#303-759
http://www.toolsource.com/cylinder-head-lifting-bracket-p-108525.html
Old Dec 8, 2012 | 10:36 PM
Yahiko's Avatar
Yahiko
Lilpooh,
Very nice on the write-up
Thank You
Sean
Old Jan 8, 2014 | 02:07 PM
stoker420's Avatar
stoker420
thanks for posting this info going to make this up ASAP and save 135 bucks
Old Feb 25, 2014 | 01:53 PM
Yahiko's Avatar
Yahiko
Some if not all of the tools are so much money.
They you look at what they are and take a second and
a third look and say how much!?
Like this little beauty
AKA Cam/crank shaft alignment tool.
Too bad I suck at drawing or I would make one to post.
Sean
Old Sep 29, 2015 | 05:53 PM
condition001's Avatar
condition001
OP: Great post! I wish I could weld...
For those of us still browsing a year or two later, the equivalent of these brackets can now be found on ebay for about $45 shipped. My welding skills are non-existent, so it beats $135 for the original tool that we all will hopefully only ever use for one day!
