CP4 Implosion!!! CRAP! CRAP! CRAP!
Old Aug 28, 2023 | 07:23 AM
  #211
Split rims's Avatar
Split rims
Originally Posted by zeroo
breakfast right now.
Why I can just imagine.........
Old Aug 28, 2023 | 05:39 PM
  #212
helifixer's Avatar
helifixer
I love reading these doomsday cp4 threads then one of the ranch trucks show up for something simple, 2 to 300,000 miles on them, oil changed once in a while, fuel filters changed when the engine looses power, dirty fuel cans in the dirty beds used daily to fuel them. Driven and treated like it is a company ranch truck, no cp4 failures yet but some are sure they are a ticking time bomb.
Old Aug 28, 2023 | 05:54 PM
  #213
zeroo's Avatar
zeroo
it is curious and I’m interested. I’ve posted before I’ve put about 500k on the cp4 over several trucks and not the most strict fuel filter regiment. But I am curious when rust/water isn’t a factor.
Old Aug 28, 2023 | 06:22 PM
  #214
morehouse7's Avatar
morehouse7
Air is the kiss of death.
Old Aug 28, 2023 | 06:45 PM
  #215
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Luck of the draw, like russian roulette, might get you, might get the other guy...
Sort of like my last truck, RAM with a 6.7 Cummins, only engine issue ever was a broken valve spring, how often does that happen?
And, talk about warranty issues, had an extended warranty, and every time the tech went to try something new for the diagnosis or repair, they had to get a warranty inspector out to physically look at it and approve it before he went any further. Truck was in the shop for 28 days for a broken valve spring!!! Half that time was waiting for the inspector to come out and look at it each time.
Old Aug 28, 2023 | 09:00 PM
  #216
gascan's Avatar
gascan
Read the report on the very first post in this thread. The pump can fail without rust or water. There was no rust or water in my fuel system. You either have good luck or bad luck with the CP4. There are other reports that talk about how air can get trapped in the pump and that causes the pump to not be properly lubricated - then it will fail. It is inherently a bad design.
Old Aug 28, 2023 | 09:02 PM
  #217
gascan's Avatar
gascan
Yup! There is nothing you can do about it because you don't know and you can't guard against it. I never ran my truck dry. Always had multiple gallons of fuel in the tank over the years of use. Again - bad design of the CP4. There were no "air" issues with the CP3 and with the 3rd party CP4 replacement pump.
Old Aug 28, 2023 | 09:19 PM
  #218
Richbag's Avatar
Richbag
3rd Gear
Be careful with the Ram diesel pickups. There design problem #1 I hate is if you ever need a crank shaft positioning sensor is located be hind the flywheel. great place for this to be, now you have to drop the transmission to replace a $20.00 part. stupid engineers.
Old Aug 28, 2023 | 09:46 PM
  #219
6.2caribou's Avatar
6.2caribou
Drop the transmission???
Old Aug 29, 2023 | 12:53 PM
  #220
79Ranger351's Avatar
79Ranger351
Originally Posted by gascan
Uhggg! I have been struggling with a series of issues with my truck. Two weeks ago I took it back to my dealership for "low power' issue. I.E. truck just didn't move like it used to and had trouble under load with my camper. Well they got back to me and the Bosch CP4 High Pressure Fuel Pump has imploded and now I have metal shards throughout my high pressure fuel system and in my fuel tank.
Before I go on my rant about the Bosch CP4, I will state a few facts:
  1. I take care of my equipment. All service work is handled on time. I don't abuse my truck at all.
  2. I add the Ford PM-22A treatment to most tanks of fuel (probably 80% of the time) since I bought this truck new back in 2016.
  3. I have NEVER run out of fuel in this truck. The fuel system has NEVER been dry.
The net of this that as an owner, I have done every single thing I can do operate and maintain my truck properly. The result of my diligence is that the "piece of crap" Bosch CP4 fuel pump has imploded. It will be weeks, if not months before I have my truck back. We had a 4 week trip up to Colorado, Wyoming and Montana planned. Well that got cancelled. Sigh.
BEGIN RANT
Ford, GM, and Dodge/RAM have all used Bosch high pressure fuel pumps for years. In 2010 Bosch released the CP4 version of the pump. Ford specifically designed the 2011 6.7 Powerstroke around the CP4. GM immediately used it in their 2011 Duramax (LML?). Cummings (Ram/Dodge) used the CP3 until 2019 when the 6.7L Cummings was released and they switched to the CP4. Well each vendor has had failures - significant quantities of failures. GM stopped using the CP4 in 2016. They don't use Bosch pumps at all anymore on Duramax. Cummings only used the CP4 for 2019 and 2020, then immediately went back to the CP3 while issuing a recall to replace existing CP4's in the field with CP3s. What has Ford done? Nothing. They continue to ship new trucks with this POS fuel pump.
If you do your research, you can find all kinds of information and various facts / figures. But based what I found in Europe Bosch sees about 1% failure. In the USA, Bosch sees about 7% failure. (I suspect this data is educated guesses as I doubt Bosch is going to release that data...). This fuel pump is a disaster in the US market. I am just astounded that Ford continues to use this pump.
Here is a very good article on the CP4 from an independent source:
https://www.dieselhub.com/tech/bosch...p-failure.html
So my story is more interesting... This is my second experience with the CP4. I had a 2011 F-250 with the 6.7 Powerstroke. In 2014, my CP4 imploded as well. My 2011 truck only had about 52,000 miles on it. I was actually on vacation up on Colorado where it died and left me stranded. As with my 2017, I properly operated and maintained that truck (always used PM-22-A, never ran it dry, all service work completed at the specified intervals). So now Ford has let me down twice for the exact same problem. I thought the first CP4 failure was a fluke. Now that it has happened twice, I am just pissed.
Back in October of last year, I renewed the extended warranty on my 2017. I am glad I did so but apparently Ford is slow to approve the warranty action for this fuel system replacement. The dealer told me that there has been no evidence of rust anywhere in my high pressure fuel system. My fuel is clean - no evidence of gas or DEF in the tank. (which make sense - I take care of my equipment). So now I am stuck in limbo waiting on Ford to decide if they are going to SCREW one of their loyal customers. Yes, I am Ford guy. I wear Ford hats and Ford shirts. I have always been a blue oval fanboy! I have owned countless Fords since I bought my first one at age 16. So in nearly 40 years of driving, I have owned many of them. At this point, I am disgusted with Ford for two reasons:
  1. Why keep making a product with a highly suspect component!!!
  2. Why drag out the warranty approval and stall and threaten not to do it!!!
IF THERE ARE ANY FORD CORPORATE REPRESENTATIVES READING THIS, PLEASE CONTACT ME.
I am seriously considering selling my F-350 (which I have loved) once it is repaired and stepping away from Ford. Man it hurts to say that.... I hate GM products and I have never been fond of Dodge/Ram but I am seriously considering a Ram truck now. No wonder Ford stock stays in the crapper!
FORD GET YOUR CRAP TOGETHER!!!
END RANT
My 2020 Lariat Black Tremor F350 did the same thing at 60k, never been ran out of fuel, kept up on service however did not use additives. Flat traded for a 2022 F150 Lariat 3.5l, been happy so far.
Old Aug 29, 2023 | 02:58 PM
  #221
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
That's great that an F150 can do what you need it to do, but many of us require a heavy duty pickup to tow with.
Plus, your comment does not do anything to further the OP's repair of his truck.
Old Aug 30, 2023 | 01:32 PM
  #222
gascan's Avatar
gascan
Well I got an update from my Ford Customer Experience Specialist today. Looks like the fuel kit will be delivered to the dealership next week.
Old Aug 30, 2023 | 01:37 PM
  #223
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
@gascan That's great! Looks like we will be getting our trucks back close to the same time.
Getting our contamination kits shipped to the dealers about the same time, mine is supposed to be delivered this week.
Of course your 17 takes a slightly different kit than my 22.
Old Aug 30, 2023 | 01:40 PM
  #224
senix's Avatar
senix
that is great news. My experience with the ford cust svc mirrors yours. Seems overall they are better at staying in touch and tracking.
Old Sep 1, 2023 | 09:11 AM
  #225
gascan's Avatar
gascan
Yeah, I am grateful for the help. However, I had to contact them on Twitter to get the help. It is interesting that Ford Corporate has never responded or participated in this thread or reached out to me via a PM. I think the CP4 issue in general is a sensitive issue for Ford given the legal actions in play....
Once the dealer has parts in hand and can get the truck back in the bay, does anyone have any idea as to how long the process takes?
