There is a statistic that 7% of all CP4’s fail. If we accept that as true, which it very well might be.
Then who used the pump longer doesn’t change the rate of failure for any given brand truck.
GM could have run the pump for just a single year and had a 25% failure rate.
RAM could run the pump for 2 years and had a 10% failure rate.
Ford could run it for 12 years and have a 4% failure rate.
The only thing changing as someone (Ford) continues to use the CP4 is their SHARE of the total number of pump failures.
Ford using it longer doesn’t make it impossible that they’ve had a lower RATE of failure than the others.
It’s totally plausible that Ford has had the lowest failure rate while the others had higher rates (which bring it up to 7% from their shorter time using it).
Look at it this way:
Ford has a 4% failure rate.
if they were the only ones to use the pump then that would be the overall rate. It’d be 4%.
now say others used it for a few years in between. They could raise the OVERALL rate if they had worst luck with lots of failures. Now it could go from 4% to 7% hypothetically.
WRONG
As the others stopped using the pump, the total number of pumps being used falls off sharply, for the overall average to continue at 7%, then the lone user would have to have a higher failure rate to maintain that overall average.
The thing is we do not have all the numbers, and many failures are not considered in these numbers because they are repaired without being reported so are not included.
So how do you know the failure rate when all 3 were running the pump?
what if the overall failure rate was 10% and year by year it has gone down since GM & RAM stopped running it because they had worst luck?
you’re confusing the overall failure rate to the share of over all failures.
due to how long ford has used it I’d say they probably have the largest share of over all failures but it doesn’t mean their RATE of failure was higher than anyone else’s.
I don’t think GM would’ve stopped using it if they had a 2% failure rate. Something tells me theirs was pretty high in comparison.
I'm no statistician but that doesn't pass the sniff test. If overall failure rate is 7% and GM's is 5%, that means the non GM users would have higher than 7% failure rate for the overall to be 7%.
Another thing to consider is Ford has been using the pump far longer than anyone else and continues to do so after GM and Ram stopped using it, so the sheer number of SDs sold with diesels would mean much of that 7% comes from Ford with some coming from Ram, and a very small amount from other users but these days diesels are very uncommon outside of class 2B and up pickups in the US.
Years ago it was shared on this site the failure rates from the NHTSA and the percentage from Ford was a littler under 1%. Having said that it wasn't known what the breakdown was from fuel contamination and infant mortality. The CP4.2 pump implementation for the 6.7 cummins was a disaster.
In a Google search, the consensus is that CP4.2 failure rates show as about 7% in the US,
Per year?? with what mileage??? Each year adds more pumps (total), so consistently 7% per year (if it's really per year), means it's
getting better every year, especiallyif earlier pumps are getting more mileage.
Well, my understanding of these disaster prevention kits is that they just keep the shrapnel from recirculating through the entire system, not keeping the major components from failing.
true…with the DPK, when the cp4 fails…the cost will be just the pump cost and the cost of the return filter.
with out the DPK, the cost is everything lus the crazy labor for everything in the fuel transport and injection path.
there is so much issue with your imagining and hypothesizing that I don't even know where to start.
It does okay for what I need it to do most of the time. Even the occasional medium sized one! Okay you guys have fun now and try not to lose too much sleep over that fuel pump.
I’ll run a disaster prevention kit and enjoy the power the 6.7 has.
if I have to change the fuel pump once during ownership and DPK does it’s job then I’ll gladly take it over the 7.3. I’d rather enjoy the other 99% of the time towing with it before settling for a lot less power to pull things in a gasser.
it’s always funny the folks with gas trucks are the ones who care most. I’ll never understand it.
The disaster prevention kit has no bearing on cp4 failures, won't prevent them from happening, all they do is keep the shrapnel from the failed pump from getting into the rest of the high pressure side of the fuel system, pump will still be trash.
Never said it did, but it PROTECTS the HP side which is $8-$10K to repair, a Disaster in my book, compared to the $1500-$2K to replace just the pump, a WIN in my book.
Originally Posted by Rwhjr
Agreed he might be slightly confused on what it does.
But pump failure with and without the S&S DPK is a night and day different kind of problem to have.
A pump swap is a fraction of the issue (time & money) that you’re faced with if you need a total fuel system replacement.
Not at all confused, I know and have always stated in other threads, that if the CP4 fails, a DPK will prevent the EXPENSIVE side from getting destroyed.
Yep, which is why it was the very first thing I did to the truck after buying it. Especially since it was a used truck with no history of how it was fueled or driven.
Also that 7% had nothing to back it up that I could find, they were just numbers put out there. On the GM forums, when the CP4 was used though, the majority of it spoke to at least a 5% per year failure rate. No other stats were found though as to how many of those engines were produced, which matters. The number of Powerstroke engines produced is speculation based on the average production could put out per year since 2011, which is supposedly 200K.
Precisely why I have zero interest in ever owning a 6.7 Powerstroke. Or any other rig with a CP4 for that matter. But ya'll do what you want.
Hey, thanks for wandering in here and giving us permission. There's a few dozen other subforums of products you don't own that could use your wisdom too, be sure not to leave them hanging.
I was doing a little research on the 6.7 last - specifically any future directions eluded to by Ford, etc... Found this article and I found it interesting that it calls out the CP4.
