CP4 Implosion!!! CRAP! CRAP! CRAP!
Old Sep 4, 2023 | 04:12 PM
  #271
mhollem's Avatar
mhollem
Originally Posted by Ltngdrvr
Well, the thing about priming/purging the new filters is that if you don't, the truck won't start without multiple tries, which is doing the priming but not enough, then will eventually start, but will run very rough with too much air in the system. It will eventually work the air out, but it takes quite a bit and will run rough until it does.
So, doubtful anyone would change the fuel filters without doing a good prime/purge.
But if the fuel is supposed to lubricate the CP4, it could mean excessive wear on the pump due to lack of lubrication?
I always prime the fuel system until the system stops making gurgling/bubbling noises. Last time that was about 8 or 9 cycles of the push button, each cycle lasting 20-30 seconds. It seems by 2022 takes more cycles than my 2019 did.
Old Sep 4, 2023 | 04:38 PM
  #272
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I always prime the new filters, use the same procedure as when I changed filters in my RAM, on for 15 seconds, off 5 seconds, back on 15, etc. Do this a total of 6 times, then a last 15 seconds of on time, then start the truck. Has never failed to fire right up and run completely smoothly, no noticeable air in the system.
There is only so much anyone can do when changing the filters, but any small amount of air in the system, any possible slight lack of lubrication to the pump will be negligible.
Old Sep 4, 2023 | 04:50 PM
  #273
scraprat's Avatar
scraprat
Top Answer: 5
I think it would be interesting to know especially of the FTE members that have had this failure if they did their own maintenance (fuel filter) or did they rely on a dealership/ shop. This wouldn't count the failures from mishaps of say putting def in the tank and running it.
I would think an owner who does their own maintenance is more conscientious of details than a shop that gets them in get them out. Or the dealership using the guy that flip burgers yesterday and now is the oil/ quick lane technician.
Old Sep 4, 2023 | 05:58 PM
  #274
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
But, no matter what, there will still be fuel inside the pump to continue lubing the cam, the fuel, does not drain out of the pump completely when the filters are changed.
So, when the fuel filters are changed and primed, there will not be an appreciable amount of air going through the pump before a full load of fuel fills it up.
I really don't think this is a cause for the pump failing.
Old Sep 4, 2023 | 06:06 PM
  #275
4wd6.7L's Avatar
4wd6.7L
Well, it doesn't surprise me that the maker of the $400 kit would say that about the lesser expensive ones, they have to defend their higher cost one so they can keep selling them.
Did you watch the video? He gave you a direct comparison of 2 knockoff's showing real, factual quality concerns with them. You asked what the difference was, and some differences were shown in those two examples. Even the filter itself was a fake in one, and generic in the other. I would much rather spend a few more dollars with a reputable company who designed and manufactured the part, using their experience and with quality in mind, rather than some unknown offshore company who's only objective is to visually clone someone else's product, as cheaply as possible.
Would you put a knockoff Motorcraft oil filter on your truck to save a few bucks? Looks close enough, so it must be just as good.
Old Sep 4, 2023 | 07:37 PM
  #276
extrachrispy's Avatar
extrachrispy
Originally Posted by gascan
Ok 6.7 Powerstroke experts... I have another question for you.
I keep thinking through both of the failures of the CP4 (on my 2011 and on my 2017). Yesterday, I finally had some time to do a little research. I keep records on everything including all of my fuel stops, where I fueled up, amount of diesel I put in etc. in a spreadsheet along with all my service work. My dealership has done all of the service work at the correct intervals on both of my Super Duties. One thing I did notice in common between my 2011 and 2017 failures is that just prior to both failures, I had the fuel filters changed. [...snip...]
Multiple people and the report I quoted indicated that air in the CP4 is major issue and can cause failure. So my question is... What if my dealership technician didn't repeat the on/off ignition procedure 6 times as indicated in the manual? Could this have been the cause of the issue? I would love for those of you more knowledgeable than me to weigh in on this...!
This certainly sounds plausible. Like others here, I change my own filters, and cycle repeatedly until I hear no gurgling or until I've done it six times, whichever comes last.
Old Sep 4, 2023 | 08:26 PM
  #277
gascan's Avatar
gascan
Good point, I just don't know how much air is "too much" air and what the flow looks like in the pump when it is not full of fuel.
Thanks!
Old Sep 4, 2023 | 09:42 PM
  #278
FishOnOne's Avatar
FishOnOne
Thanks!
I agree with your analogy about failures soon after a filter change. I've noticed that myself and is why I change my own filters and go above and beyond purging the air from the fuel system by cycling 12 times.
Old Sep 4, 2023 | 10:28 PM
  #279
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Well, mine didn't fail after a fuel filter change, it failed about 4000 miles before the next change was due.
I really don't think the filter change has anything to do with it.
Old Sep 5, 2023 | 12:35 AM
  #280
FishOnOne's Avatar
FishOnOne
The failures have been few, but something I've noticed over the years. As a matter of fact the very first failure reported here by ricatic was just after a filter change. What I don't understand is the new pumps like your is supposed to pinned so the roller/bucket doesn't rotate which was the most of the failure modes.
Old Sep 5, 2023 | 05:54 AM
  #281
zeroo's Avatar
zeroo
Would be curious how prevalent this is. Pump failure posts get my attention here. But the vast majority of trucks/fleet trucks that’s pump exploded won’t be posted here, and more than likely just chalked off as contamination. Here, we see trucks that are obviously taken care of have failures.
Old Sep 5, 2023 | 07:57 AM
  #282
okie981's Avatar
okie981
I keep thinking through both of the failures of the CP4 (on my 2011 and on my 2017). Yesterday, I finally had some time to do a little research. I keep records on everything including all of my fuel stops, where I fueled up, amount of diesel I put in etc. in a spreadsheet along with all my service work. My dealership has done all of the service work at the correct intervals on both of my Super Duties. One thing I did notice in common between my 2011 and 2017 failures is that just prior to both failures, I had the fuel filters changed. Back in June 2015 on my 2011 Super Duty, I had the fuel filters changed about 1 week before we drove from Austin, TX up to Estes Park, CO. That is about 2.5 day trip - around 1100 miles. The day after we arrived my fuel system failed. On my 2017, I had the fuel filters changed about a month before the failure (back in June) as we were getting ready for our trip to Montana. So my you can see where I am going here.... The common thread is that the fuel filters were changed and then I had a failure. I was reading in the 2017 Owners' Manual about changing the fuel filter and noticed the following sentence "Note: No special air purge is necessary after filter servicing. The fuel system purges the air in the filters." Then further down at the end of the installation instructions for the filters is bullet point number 3 "Switch the ignition on for 30 seconds and then switch the ignition off.Repeat this operation six times in a row to purge any trapped air from the fuel system."
Thanks!
I change my own on my 2020 F250 6.7L. The tank boost pump times out after about 30 seconds of on time. Owner's manual says do it 6 times (in a round-about way, not clearly worded). I repeat the power on process, allowing it to time out each time, until I hear no gurgles or trapped-air sounds coming from the under body filter area. Sometimes this takes 8 to 9 cycles. My truck is at 45,500 miles and no issues yet.
Old Sep 5, 2023 | 09:29 AM
  #283
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
You guys talking about hearing the pump and gurgling, damn sure have LOTS better hearing than I do.
Old Sep 5, 2023 | 10:15 AM
  #284
longhaultransport's Avatar
longhaultransport
The driveway in my rural neighborhood is very quiet.
Old Sep 5, 2023 | 10:16 AM
  #285
mhollem's Avatar
mhollem
This seems to put a shade of truth on 'work' trucks that don't see fuel filter changes done on schedule and rack up 300k miles on them with no CP4 issues.
