CP4 Implosion!!! CRAP! CRAP! CRAP!
Old Sep 5, 2023 | 10:49 AM
  #286
senix's Avatar
senix
when changing and then purging the air, if you hit the on button, step out near where the primary filter is you can hear it easy enough.
Old Sep 5, 2023 | 11:11 AM
  #287
acdii's Avatar
acdii
I work in my garage, inside a tent that I can enclose for winter work or body work to keep dust down, so it is very easy to hear the gurgling.
Scenario, maybe right, maybe not, but here is what "could" be happening. If started right after a filter change, with a partial purge, the pump could be filled with air so when it cranks, its a dry start. The pump spins at a decent rate, which could burn off the fuel on the cam and lobes, pinned or not and cause a scratch or two. Then it fills with fuel and goes on it's merry way. Now that there are a couple scratches, diesel fuel is a lousy lubricant, works well when everything is smooth, but introduce a scratch or two, and it can start eating up the metal. Eventually it eats itself until failure is noticed.
When I purged my fuel system it took 10 cycles before I stopped hearing any more gurgles from underneath. Don't forget, the underhood filter has to fill up too, it is taking in air from the water filter underneath, while sending it's air directly to the pump. While doing this it agitates the air, so there are a LOT of bubbles mixed in, and some foaming can occur. If not fully purged, some air can remain. Also keep in mind the pump is not very big and doesn't hold a lot of fuel, so won't take much air to expose metal to metal.
What I do is cycle on 30 seconds, or until the pump stops, key off for 15 seconds to let the air rest, then repeat until I no longer hear gurgles, then one more for insurance before starting. All that air has to travel through 2 filters, the pump and then the return to the tank. By giving it 15 seconds rest, any air bubbles will rise to the top of the filter and be purged quicker.
Old Sep 5, 2023 | 12:51 PM
  #288
OX2's Avatar
OX2
Originally Posted by mhollem
This seems to put a shade of truth on 'work' trucks that don't see fuel filter changes done on schedule and rack up 300k miles on them with no CP4 issues.
Until someone hacks the true failure rate from Ford, all of this is pure speculation.........
Old Sep 6, 2023 | 02:12 PM
  #289
mhollem's Avatar
mhollem
Agreed, but it's a nice feeling to think that I'm doing something to prevent my CP4 from failing....even if its just speculation.
Old Sep 6, 2023 | 02:30 PM
  #290
OverheadCram's Avatar
OverheadCram
Originally Posted by zeroo
Would be curious how prevalent this is. Pump failure posts get my attention here. But the vast majority of trucks/fleet trucks that’s pump exploded won’t be posted here, and more than likely just chalked off as contamination. Here, we see trucks that are obviously taken care of have failures.
Going back to 2011 when the CP4 was fitted it was not the most common diesel service I would regularly book but I did see enough of them that I was cautious with my own fleet trucks until I phased out the diesels all together. Had over 100 Ford 6.7L diesels in rotation on an annual basis up until id say 2015 when the number started dropping fast as customers who didnt actually need the diesel traded off for gas. As of this year I have 43? diesels or very close to that number and not all are Ford 6.7L. Off the top of my head I cant really put a date to the last CP4 failure we have seen here but it hasn't been a popular service for me over the last 6-7 years but then I also haven't had many Ford 6.7L under service contracts for a while now.
Old Sep 6, 2023 | 04:48 PM
  #291
OX2's Avatar
OX2
Of course. I will also do virtually anything reasonable that might extend life, even if it eventually does nothing.
Would be nice to start a "sticky" thread that had as many details about the failures (and the non failures) as possible.
Not Ford info, but something I have seen on other boards, the best one being one I posted already, the
2.7 EB failures on the 6G bronco. Incredible detail.
Old Sep 6, 2023 | 08:20 PM
  #292
mhollem's Avatar
mhollem
Maybe this lawsuit will stick??
https://fordauthority.com/2023/09/fo...ve-fuel-pumps/
Old Sep 6, 2023 | 10:26 PM
  #293
jRedondox's Avatar
jRedondox
Are the 2023 high output using the cp4 pumps?
Old Sep 6, 2023 | 10:41 PM
  #294
4wd6.7L's Avatar
4wd6.7L
Yes, and I'm not sure if it makes any difference but they also increased the (displacement)fuel pressure again.
The HO version of the 6.7l is not much different than the 2023 standard output 6.7l.
Old Sep 7, 2023 | 10:55 AM
  #295
gascan's Avatar
gascan
Update - Thursday, September 7, 2023
My dealership emailed me yesterday...
Good afternoon. Our diesel technician is currently installing the new fuel system on your truck. I'm hoping he will be done by Friday but don't want to over promise. I will keep you posted sir. Thank you.
So it may be Friday or Monday of next week.
Now I have another question... How much do I trust this newly repaired truck? We are supposed to drive from Central Texas up to Steamboat Springs, CO late next week. Do I take this truck on the drive and assume all is good? Or do we take the wife's Escape?
Old Sep 7, 2023 | 11:03 AM
  #296
acdii's Avatar
acdii
Take the truck and enjoy. If the tech screwed something up, thats on them for 2 years.
I found an article from 2011 regarding the 6.7. At that time the plant the builds the engine had a capacity of 200K per year. If true, thats 2.9 million built. Thats a lot of engines that are used in all Superduty trucks from F-250 to F-750. Would be nice to know the statistics on how many actual CP4 failures NOT related to contamination over the life of the engine.
Old Sep 7, 2023 | 11:53 AM
  #297
senix's Avatar
senix
Truck tine!!
Old Sep 7, 2023 | 12:31 PM
  #298
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
You would just have to trust it like it was a new truck, but change the fuel filters when you get back home.
Get yourself a jug of this stuff... https://opti-lube.com/opti-lube-xl-x...1-280-gallons/
Old Sep 7, 2023 | 03:11 PM
  #299
texas42's Avatar
texas42
Yes, the more I read on this thread and others, the more I think this is further widespread than many think.
Just my observation
Old Sep 7, 2023 | 04:06 PM
  #300
ShotgunZ71's Avatar
ShotgunZ71
This right here. Sure, the percentage of CP4 failures is low in respect to the number of trucks produced. However, I'd like to see how many failed that were legitimately not related to fuel contamination, not simply a Ford, GM or RAM excuse to deny warranty repair.
