400 HP Engine Build - Input Needed
Old Feb 11, 2023 | 11:31 PM
  #541
PriusLover's Avatar
PriusLover
So from the core engine I got a front cover, oil cooler, fuel bowl, HPOP res, HPOP, bunch of stuff from several heads (mostly rocker arms assemblies). What parts are worth keeping around for say ten years of ownership and what should I just sell?
Old Feb 12, 2023 | 05:30 AM
  #542
FordTruckNoob's Avatar
FordTruckNoob
If you were to ask my wife, she would tell you to sell everything. Seriously though, if the engine gets built right from the get go, the most I would keep are "wear" items the HPOP and front cover. Perhaps the transmission adapter as well since those seem to have a history of breaking at the starter mount.
Old Feb 12, 2023 | 05:56 AM
  #543
RacinJasonWV's Avatar
RacinJasonWV
I would keep anything that isn’t damaged. But I’m a bit of a parts hoarder. 😳
Old Feb 12, 2023 | 06:18 AM
  #544
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If it were me, I would sell anything that doesn't require a core or to be rebuilt. The two big ones that come to mind and ones I have on hand are injectors and HPOP. I would sell the other parts simply based on this...
You will get money for the parts and be helping someone out. You can use the money at A LOT of places where the parts are designed for one purpose. If down the road and on the off chance you need some parts in the future, you can purchase them.
Why store parts for an engine that is pretty much new or better than new when you are able to help out others and recoup some expenses.
I seem to recall you live in an appartment and have nowhere to work on the truck. Do you have a place to store parts long term that doesn't cost additional funds?
You are going through a lot of effort to make one of the most reliable engine platforms more reliable.
That said, you do whatever gives you the most peace to think about because what we say doesn't matter at all in your daily life.
Old Feb 13, 2023 | 01:12 AM
  #545
PriusLover's Avatar
PriusLover
I guess I'll keep the HPOP and it's IPR as a backup. I guess Finlander's whole ordeal made me think twice about the front cover and oil cooler castings.
Old Feb 15, 2023 | 01:37 AM
  #546
PriusLover's Avatar
PriusLover
Time to start thinking about first start and break-in procedures.
I figure fill the oil rails, HPOP res, crank for 20. Let starter cool, crank again, let cool. Start truck check for leaks let coolant burp, check oil pressure. Apply a light load to bring it up to operating temp quickly. Once warmed up run up some steep hills moderately loaded at RPMs around the engine peak torque points to increase cylinder pressures and help seat rings. Drain oil, cut open oil filter to check for metal. Check for exhaust fuel/oil/exhaust leaks. Refill and drive with a loaded bed and emphasis on peak torque region of RPM with little idle time for 500mi. Change oil and filter at 500 and drive normally after that.
Is this a good plan? There anything I'm missing?
Old Feb 15, 2023 | 06:56 AM
  #547
FordTruckNoob
Maybe do the light load to warmed up cycles several times with full engine cool down in-between before you do the steep hill heavily loaded runs. Then before each light load warm-up startup, check head bolt and injector bolt torque. Maybe check injector bolt torque immediately after shut down.
Old Feb 15, 2023 | 07:02 AM
  #548
Dan V's Avatar
Dan V
Do you have an idea when this moment might occur? And video, we'll need video.
Old Feb 15, 2023 | 07:27 PM
  #549
PriusLover's Avatar
PriusLover
End of march perhaps? Depends a lot of factors.
Old Mar 14, 2023 | 05:38 PM
  #550
PriusLover's Avatar
PriusLover
Anyone know the compressed thickness of OEM gaskets? Looking at Cometic MLX which are 0.067" compressed.
Old Mar 14, 2023 | 06:21 PM
  #551
ESwift's Avatar
ESwift
CNCFAB
I believe they are about .062 if memory serves me. Hopefully others can verify
Old Mar 15, 2023 | 04:27 PM
  #552
Bonanza35's Avatar
Bonanza35
There were some bad reviews on Cometic gaskets in the early days here, don't think I would use them!
Old Mar 16, 2023 | 07:53 PM
  #553
callforfire's Avatar
callforfire
I've got a pair of the MLX gaskets on the shelf I was going to use on a build. I would be interested in the bad reviews.
Old Apr 5, 2023 | 11:27 PM
  #554
PriusLover's Avatar
PriusLover
Yeah I've seen a lot of conflicting stuff. I'm mostly going by the following:
From Swamps I think:
From @DZL JIM on another board:
In terms of other updates:
After speaking with a head parts supplier, decided to go with SBI iron guides and SBI nitrided valves.
Also, landed a good deal on Brian Crower rods... after selling my rods/studs, factoring in saved machining costs, doesn't come out too bad. Felt like they were a good idea given I'll be using a VGT.
Old Apr 6, 2023 | 07:50 AM
  #555
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Cometic has a very solid name, and products, and I would never hesitate to use them for anything.
Yes, I had an issue, but we pushed them to make the .120" gaskets and in the end they said "Don't blame me, it's what you wanted." Which I get. It just isn't a good idea to go that thick to lower compression.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
