400 HP Engine Build - Input Needed
Old Jan 24, 2023 | 09:32 PM
  #496
FordTruckNoob's Avatar
FordTruckNoob
One way to get the 4R100’s gears closer is to switch to a higher ratio final drive.
Old Jan 24, 2023 | 10:11 PM
  #497
brokestroke's Avatar
brokestroke
The transmission ratio doesnt change with different axle gears. Higher final drive as in 3.55 gears? I have thought about this, instead of a lower ratio that limits 3rd gear usage, use a high gear like a 3.55 that lets one use 3rd gear at highway speeds. Drive a truck with 3.55 gears and its not too bad using 3rd gear, love the low rpm cruising speed in 4th. Example; 4.30 gear vs. 3.55 is a close one in a 4spd truck because the lack of a usable 3rd gear after 50mph with 4.30. The 3.55 truck has the advantage when it comes to the use of 3rd gear lockup and 2nd gear TC lockup.
Old Jan 24, 2023 | 11:00 PM
  #498
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by brokestroke
The transmission ratio doesn;t change with different axle gears.
FTN said "one way to get the 4R100's gears closer" where it is understood that the product of the transmission gears times the rear differential gear produces the final drive ratio (assuming same tires).
Do the math.
A higher rear axle ratio (numerically lower) WILL get the gears closer to each other, in terms of reducing the difference between each gear as calculated through the final drive.
Old Jan 25, 2023 | 04:58 AM
  #499
FinnishStroker's Avatar
FinnishStroker
I love cruising with my 3.55 non limited slip.
Old Jan 25, 2023 | 07:42 AM
  #500
brokestroke
Do the math.
Your right about the math.
Real life it doesnt translate completely 1:1. A truck with higher gears will feel like it has larger splits than a lower gear truck, even if they are closer on paper. Less leverage and torque of a higher gear makes the split more apparent even though it is less.
Old Jan 25, 2023 | 04:19 PM
  #501
FordTruckNoob
@brokestroke , if 3.73 is the "standard" final drive ratio for our trucks, a higher gear ratio means 4.10, 4.30 etc etc. I think we are all in violent agreement here.
https://www.kmpdrivetrain.com/final-...20differential.
Old Jan 25, 2023 | 04:57 PM
  #502
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
if 3.73 is the "standard" final drive ratio for our trucks, a higher gear ratio means 4.10, 4.30 etc etc. I think we are all in violent agreement here..
Compare the lowest gear ratio (granny low) to the highest gear ratio (overdrive) in a manual transmission.
In the ZF 6, the lowest gear ratio (L) is 5.72, and the highest gear ratio (O) is 0.72.
In the school of thought where I was taught, "a higher gear ratio means" 3.55, 3.42, 3.31 if the "standard" is 3.73.
My F-550 has the deepest, or lowest, rear gear ratio that Ford ever matched to a diesel engine in a light truck... 4.88.
Old Jan 25, 2023 | 05:14 PM
  #503
FordTruckNoob
Well ****. EJECT EJECT EJCT!!
EDIT: This is what I was taught.
Old Jan 25, 2023 | 05:28 PM
  #504
Tpayne621's Avatar
Tpayne621
This is the same way I have always used it and heard others use it also. Lower gear is numerically higher number.
Old Jan 25, 2023 | 05:35 PM
  #505
RacinJasonWV's Avatar
RacinJasonWV
Did you state this backwards, or is my brain confused? I expected it to say “lower rear axle ratio (numerically higher).” Ex 4.30’s reducing difference as compared to 3.73’s.
My mind says numerically lower gear ratio (geared higher) would cause final drive splits to be more. Am I missing something? It was a long day at the plant.
Sorry FTN, that’s completely backwards from how I’ve always been taught. The sheet should switch “LOW” and “HIGH” to be correct. Where in the world did you find that?
Old Jan 25, 2023 | 05:44 PM
  #506
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
That infographic is so beautifully and professionally presented, it looks impossible for it to be wrong.
However, as @Tpayne621 says, and as drag racer @RacinJasonWV echoes, that infographic is in error with how gear heads were taught.
Perhaps the creator of the graphic is not a gear head, but they do have excellent graphic arts skills.
This is a fine example of how minds are influenced by beauty, even when we knew better.
Old Jan 25, 2023 | 06:09 PM
  #507
FordTruckNoob
Yukon Gear agrees with you guys’ understanding of low/high gearing.
https://www.yukongear.com/help/glossary
I shall go away and reexamine my life choices.
Old Jan 25, 2023 | 06:12 PM
  #508
FordTruckNoob
Ummm… wut did u say? I got distracted.
Old Jan 25, 2023 | 07:48 PM
  #509
brokestroke
Same difference.
Old Jan 28, 2023 | 08:05 PM
  #510
PriusLover's Avatar
PriusLover
Bit of a sidetrack but I got a pair of exhaust manifolds with the core engine. Was thinking of having them ceramic coated and selling them. No idea if they'd sell tho. Good idea or bad idea?
