400 HP Engine Build - Input Needed
Old Apr 6, 2023 | 07:55 AM
  #556
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Originally Posted by PriusLover
Time to start thinking about first start and break-in procedures.
I figure fill the oil rails, HPOP res, crank for 20. Let starter cool, crank again, let cool. Start truck check for leaks let coolant burp, check oil pressure. Apply a light load to bring it up to operating temp quickly. Once warmed up run up some steep hills moderately loaded at RPMs around the engine peak torque points to increase cylinder pressures and help seat rings. Drain oil, cut open oil filter to check for metal. Check for exhaust fuel/oil/exhaust leaks. Refill and drive with a loaded bed and emphasis on peak torque region of RPM with little idle time for 500mi. Change oil and filter at 500 and drive normally after that.
Is this a good plan? There anything I'm missing?
I know I'm a bit late on this, but:
7.3 Power Stroke Engine High Pressure Oil Rail Bleeders
They really do cut down on cranking and ease firing up after injectors have been removed.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Apr 6, 2023 | 09:00 PM
  #557
PriusLover's Avatar
PriusLover
Great idea!
Old Apr 17, 2023 | 08:28 AM
  #558
FinnishStroker's Avatar
FinnishStroker
Where we at?
Old Apr 17, 2023 | 08:43 AM
  #559
Walleye Hunter's Avatar
Walleye Hunter
Originally Posted by FinnishStroker
Where we at?
We're at 2032, engine build is complete and diesel fuel has been banned in US.
Old Apr 17, 2023 | 09:31 AM
  #560
FordTruckNoob's Avatar
FordTruckNoob
Old Apr 17, 2023 | 09:36 AM
  #561
PriusLover's Avatar
PriusLover
Where we at?
The block is done. Heads have been held up because I needed to source guides and valves (which should arrive today). So heads and balance are left and should take 2-3 weeks last I heard.
Old May 27, 2023 | 01:22 AM
  #562
PriusLover's Avatar
PriusLover
@Dan V You've a recommendation for best technique to de-burring the bottom of the cylinders? Machinist recommended doing so. I've seen people use die grinders but getting power tools near the cylinder walls makes me nervous. Would a Noga tool be sufficient?
Old May 27, 2023 | 06:03 AM
  #563
Dan V's Avatar
Dan V
The bottom of the cylinder has no ring travel, so unless you slipped in a grand fashion I think you'll be fine. But a Noga tool should work, and probably what I'd go with. Get a kit that has an assortment of blades.
Old May 28, 2023 | 01:08 PM
  #564
cleatus12r's Avatar
cleatus12r
Butt-Head
For the last 8 years.
Old May 28, 2023 | 02:13 PM
  #565
jstihl's Avatar
jstihl
Son of A ...That's gonna leave a mark!
Old May 28, 2023 | 02:24 PM
  #566
Walleye Hunter
Eh...don't feel bad. I have a buddy who's refurbishing a food trailer but by the time he's done that, propane will be banned too.
Old May 29, 2023 | 05:31 AM
  #567
FordTruckNoob
Old May 29, 2023 | 06:16 AM
  #568
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Damnit bobby
Old May 29, 2023 | 02:45 PM
  #569
PriusLover's Avatar
PriusLover
Eh, I'm a left-winger so don't really think of the matter in that way. In anycase political commentary can go elsewhere, I've got something much more fun to talk about
Old May 29, 2023 | 02:51 PM
  #570
Dan V's Avatar
Dan V
Ok...We are all dying to know....what color?
