Overkill2s truck thread...
Old Nov 20, 2022 | 09:59 AM
  #796
Overkill2's Avatar
Overkill2
Originally Posted by The Bone
Hey Dave did you get any snow last night LMAO
Great drone footage here...
Old Nov 20, 2022 | 10:14 AM
  #797
FishOnOne's Avatar
FishOnOne
Seen the Bills stadium full of snow so bad that the Bills vs Browns game will be moved to a different location.
Old Nov 20, 2022 | 11:16 AM
  #798
Overkill2's Avatar
Overkill2
Yep, Detroit Michigan....
The stadium is in OP (Orchard Park) where they got 77 inches...
Old Nov 20, 2022 | 11:49 AM
  #799
Overkill2's Avatar
Overkill2
The problem was the time frame... Not enough of time to get all the snow out of the stands... And field and lots...
Old Nov 20, 2022 | 12:15 PM
  #800
cj45lc's Avatar
cj45lc
Stay safe buddy, I don't know about there but here if a dozen snow flakes stick to the road folks start looking for ***** to run into
Old Nov 20, 2022 | 12:17 PM
  #801
Overkill2's Avatar
Overkill2
Originally Posted by speakerfritz
no
drain back valve
it prevents the oil up in the block from draining thru the filter . It’s a rubber ring that blocks the filter holes when not under pressure. Basically a flapper valve. You can see it by looking into filter.
with out the valve…every start is a dry start.
From 1:04 from that vid link...
The Donaldson P502503 filter...
Old Nov 21, 2022 | 05:27 AM
  #802
Overkill2's Avatar
Overkill2
A quick share here...
Last night I saw an older guy in a Ram 1/2 ton or maybe 3/4 ton truck who had at least 5 of those Ram decals on his back window. He was waiting on the side of the road as one of our tow operators was yanking out one of our local Muslims at the top of the side street... So anyways, I walked up to the Ram and told the guy he had a lot of Ram vaginas on the back of the truck (those decals look like the female reproductive system from a distance ). He was real serious when he said he was a Dodge guy. I told him I was a Ford guy and couldn't help myself...
Old Nov 21, 2022 | 10:08 AM
  #803
cj45lc's Avatar
cj45lc
Yep Dave & if you turn the Dodge stickers upside down they look like Daffy Duck lol
Old Nov 23, 2022 | 06:18 AM
  #804
Overkill2's Avatar
Overkill2
https://www.wgrz.com/article/sports/...f-5b2b4e7045ca
Old Nov 23, 2022 | 05:42 PM
  #805
brokestroke's Avatar
brokestroke
Just saw this and thought I post it here since you often put up links to new parts, etc.
Is it possible to use this and mount up a zf-6 manual transmission???
https://www.spemotorsport.com/collec...100-rear-cover
Old Nov 23, 2022 | 08:06 PM
  #806
FishOnOne's Avatar
FishOnOne
And the Bills put the smackdown on the Browns
Old Nov 24, 2022 | 09:08 AM
  #807
Overkill2's Avatar
Overkill2
ZF6 swap to the 6.7 Powerstroke
I appreciate the thought but I'm just a guy who looks online alot and I'm no expert on this stuff. I just know how to find stuff online... but I can steer you in the right direction though.
Doing a preliminary search here, I found these:
https://www.ford-trucks.com/forums/1...ap-to-zf6.html
From there:
I would ask this guy, @strokerdiesel @strokerdiesel02 the second one maybe the same guy. He apparently does the ZF6 swap into 7.3 4R100 era trucks, so maybe he would know if that adapter plate would work.
https://www.powerstroke.org/threads/...6-swap.560633/
"Your main choices for a manual are the older ZF5 or the ZF6. The ZF6 for a 7.3 isn't the easiest transmission to come by. The bell housing is part of the trans so you will need a 7.3 version. You also need to get the trans hump from the floor of the donor, drive shaft, pedals, master/slave and the spacer. I just wrapped up a ZF6 swap earlier today, the spacer ended up being the one piece I couldn't find. If you don't find the spacer, 10ga steel works."
Here's a search for zf6 to 6.7 Powerstoke here. In this link, there are videos for a ZF6 swap to the 6.7 Powerstroke. I would also shoot an email to SPE and ask them to see what they say.
https://www.powerstrokearmy.com/thre...version.42790/
Something to consider:
"A zf 5-6 whatever WILL NOT hold continuous power that a stock 6.7 can dish out. There is NO aftermarket shafts, syncro's or anything else out there to make a zf 5-6 any better than in stock form. The only gain over as auto trans would be for a competition sled pulling vehicle where you only want one gear, running for short periods of time, low range in the transfer case and need 4000+ rom to spool a large competition turbo.
All preferences aside no BS just the facts a zf 5-6 conversion would be very costly, slower and less reliable than a stock 6r any day of the week at all power levels from stock on up. They were designed to hold 650 input FTlbs of torque not 890 our of a stock 6.7. A 6.7 would eat it alive over not too many miles if towed heavy.
The zf trans is not cooled the same (3.5 quarts fluids capacity compared to 12+ quarts in most all the autos) as the auto. It will get hot and melt under high loads and high stress applications."
Hope this helps dude...
Post up if you go for this... though I lack the fab skills and knowledge, I love the "Built not Bought" mentality. I'm a huge fan of custom trucks.
Old Nov 24, 2022 | 09:12 AM
  #808
Overkill2's Avatar
Overkill2
I've been to the old stadium in Cleveland for a Bills/Browns match up... back in my single drinking days. My buddy and I picked up a couple of MILFs but didn't get in to the endzone... Good times. I live vicariously through myself now that I'm old, married, boring and don't really drink anymore...
Once I'm back to work on Saturday, I'll see of I can get pics of the giant pile of snow where they are dumping the snow from the streets in our town... I got a glimpse and it's quite impressive to say the least.
Old Nov 24, 2022 | 07:37 PM
  #809
FishOnOne's Avatar
FishOnOne
How bout them Cowboys!
Old Nov 24, 2022 | 07:59 PM
  #810
Overkill2's Avatar
Overkill2
Yeah yeah... but you do live in Texas. The only thing I liked about the Cowboys way back when were the cheerleaders... I had a friend from high school that liked the Cowboys... They got a W today too... So I'm happy for you Troy.
