Overkill2s truck thread...
Old Nov 11, 2022 | 09:06 AM
  #766
Overkill2's Avatar
Overkill2
Originally Posted by speakerfritz
I think the ford 15w40 is a blend….it is also pumped up with a lot of phosphors
Not sure it's a blend or not, but I believe it would say blend if it was.
SAE 15W-40 SUPER DUTY DIESEL MOTOR OILS
Here's the 10w30 :
SAE 10W-30 SUPER DUTY DIESEL MOTOR OILS
This stated on BOTH the 10w30 and the 15w40 products pages:
"It meets the requirements of Cummins CES 20086, Detroit Diesel 93K222, Volvo VDS-4.5, Mack EOS-4.5 and API Service CK-4."
After looking into it more:
If you look on this page,
it states when it's a "synthetic blend" and when it's a "full synthetic." So if it's not stated as in the case of the 10w30 and the 15w40, I have to assume it's a conventional motor oil.
Just FYI...
Old Nov 11, 2022 | 09:08 AM
  #767
speakerfritz's Avatar
speakerfritz
Originally Posted by Overkill2
Why would you when you have all that 5w40 for 4 oil changes? I ran out of the (3) 6 gallon bags in a box that I scored for $50 bucks a piece two oil changes ago I believe. As to using 10w30 in a diesel, my UOAs with MC Super Duty 10w30 came back . And I let the truck tell me when to change (7k miles plus).
But I have to imagine big trucks are using it as that 2% fuel savings over many miles and in many rigs would have to add up. It appears just like modern day gasser engines are going to lighter grades of multi-viscosity oil, diesels may be doing the same. But I'm no expert here and I do see that old habits die hard.
My next upcoming oil change (in about 3k miles or so), I'm going to use Rotella T4 10w30 that I scored at my local NAPA on sale.
This is just my opinion, and I'm no expert, but I believe your situation with more slow speed, stop and go city driving has more to do with higher levels of fuel dilution than it does with the grade of oil. With that said, more fuel will affect 10w30 viscosity wise than it would 5w40. I see your point there.
yes, us metro drivers need all the help we can get.
Old Nov 11, 2022 | 09:12 AM
  #768
Overkill2's Avatar
Overkill2
You got that right fritz... good luck there buddy...
I see how the mileage just drops too, when I do more stop and go, local driving...
Old Nov 11, 2022 | 10:21 AM
  #769
cj45lc's Avatar
cj45lc
Heck Dave I'd have enough for 6 oil changes if I can find the 5-40 on sale. LOL
Matter of fact I'll probably buy a couple 2.5 gal jugs today at Tractor Supply...15% off for vets today hahaha
Old Nov 11, 2022 | 12:58 PM
  #770
Overkill2's Avatar
Overkill2
Happy Vets Day to ya! Thanks for serving...
HAPPY VETS DAY TO ALL WHO SERVED HERE!
But I don't think they do it for first responders though...
Old Nov 11, 2022 | 02:11 PM
  #771
The Bone's Avatar
The Bone
I don't buy full synthetic because of fuel millage, it's because of gaskets and seals. Also it stands up to heat better. If you don't tow heat isn't much of a issue.
Old Nov 11, 2022 | 04:25 PM
  #772
cj45lc's Avatar
cj45lc
Well 2.5 gal jug T6 5-40 for $62.05, had to get 2 so now have enough for at least 6 oil change now
Happy Vets Day to all here
Old Nov 11, 2022 | 04:38 PM
  #773
chadstickpoindexter's Avatar
chadstickpoindexter
I assume you have more than just these 2 jugs… otherwise it won’t be close to 6 oil changes…
And yes, happy Veterans Day to all the Veterans!
Old Nov 11, 2022 | 08:23 PM
  #774
cj45lc's Avatar
cj45lc
Yep quite a bit more, Dave was teasing me about having enough for at least 4 O C so I was just letting him have it back with the 6 comment
at least that's the way I took his comment
Old Nov 11, 2022 | 08:41 PM
  #775
Overkill2's Avatar
Overkill2
Not at all... I meant why would you want to try 10w30 when you have all that 5w40?? I've got zero issues with people stocking up on oil... I've got somewhat of a prepper attitude myself...
Old Nov 11, 2022 | 09:10 PM
  #776
cj45lc's Avatar
cj45lc
Thumbs up
I just took it all jokingly, never intend to stir anything up but I do have to keep an eye out for filters now that we are talking about prepper attitude
Old Nov 12, 2022 | 09:33 AM
  #777
Overkill2's Avatar
Overkill2
Dieselfiltersonline for Motorcraft filters
No worries either way... I went on the 17 plus Super Duty section and those guys seem wound up pretty tight. Most guys here seem more relaxed... They better watch out if I ever get a 17 plus. My sarcasm has no end.
I just went down in my basement to check on my supplies from my past order from dieselfiltersonline.com
I have 1 Motorcraft oil filter left, 1 Motorcraft trans filter left ( I think I only ordered 2 ), and 3 Motorcraft fuel filter sets. I do have an extra DFCM cap with an extra WIF sensor and drain plug just in case.
As for oil, I have 16 qts of Rotella T4 10w30 that will be going in for the upcoming oil change (along with a fuel filter set>>due on this 3rd oil change since last filter replacement) and 16 qts of Rotella T6 5w40 that will go in after the 10w30. I do have 7 qts or so of Motorcraft 10w30 that I may buy another two 5 quart bottles of at Wally World.
I do have two Donaldson oil filters for my truck but will probably hold off to use until after warranty just in case... probably doesn't matter but I can be OCD about some stuff.
In case you are curious...
https://www.dieselfiltersonline.com/...and-parts.html
Old Nov 12, 2022 | 09:58 AM
  #778
chadstickpoindexter
Before I got my truck I ordered a dozen oil filters and 2 sets of fuel filters. I am about to use my 3rd oil filter and my first fuel filter set. So, sometime I will need to pick up some more fuel filter sets and a transmission filter too. Not in a super hurry since I have another 15k before needing the transmission filter though… I also ordered from dieselfiltersonline.com. The only thing is make sure you order enough to get free shipping!
And I only have enough T6 for 2 more oil changes. I’ll slowly start picking up more of that here and there too…
Old Nov 12, 2022 | 10:15 AM
  #779
Overkill2's Avatar
Overkill2
Forgot to mention that... about free shipping.
Old Nov 12, 2022 | 12:15 PM
  #780
cj45lc's Avatar
cj45lc
I'll have to look into that online deal, I have been pretty lucky with the oil filters at the local Walmart. I've got fuel filters & air filters from Ford dealers that sell on ebay for good prices without cost for shipping, where I also got a fuel filter cap with the drain & WIF sensor. My cap had the stop broken off of it when I bought it but I've just been keeping track of the turns to remove & put it back that way w/o any problems so far.
BTW maybe I better check myself I have 13 gal of 5-40 & 7.5 gal of 15-40 sitting here but then again my son works at the local Ford dealer as a service writer & has had to turn folks with trucks away from oil changes because they didn't have oil.
