Overkill2s truck thread...
Old Jan 1, 2021 | 09:30 AM
Overkill2's Avatar
Overkill2
Overkill2s truck thread/pertinent Diesel info
EDIT -- TABLE OF CONTENTS
02/16/2023
I am going to start compiling a table of contents for ease of finding all the different posts/information I have posted here in my truck thread.... go down to the bottom of this page where I will list the links and what they are about....
I had a problem with one of the rear red Extremes in the rear in August of 2020. It had a intermittent blinking problem where it would blink and then go out. VLEDs wanted me to switch the bulbs to make sure it wasn't the vehicle. I made videos to show them and sent them. Once they approved the return which was quick, they wanted me to cut the wire at the housing which I did and filmed to send to them as well. They got out a replacement pretty quick so I believe customer service is top notch.
The new bulb has been working great but there was one day not long ago where the new bulb stayed on in the brake/signal function where it's brighter but the same day fixed itself. No more problems. The fronts have been flawless. Bone, you asking where I mounted the resistor for the rears which is plug and play with no splicing of wires. The front bulbs have no resistors at all... they are not needed nor required.
>>>>TABLE OF CONTENTS<<<<
My first LED replacement thread here which deals with front and rear 3157 bulbs replacement and 194 bulb replacement in the cab lights.
Here's my other LED thread for the 194 Bulbs and smoked cab light covers for the cab clearance lights here.
Information on the FS2500 oil bypass filter system I have on my truck here.
Info on brass towing mirror replacements for our trucks here.
Last edited by Overkill2; Feb 16, 2023 at 09:01 AM. Reason: Change title and add to first post/start to compile a Table of Contents
Old Jan 1, 2021 | 09:32 AM
mecdac's Avatar
mecdac
Thumbs up Excellent
Always appreciate your posts and the information included. Looking forward to this.
Old Jan 1, 2021 | 09:51 AM
senix's Avatar
senix
Subscribing!
Old Jan 1, 2021 | 10:01 AM
Overkill2's Avatar
Overkill2
Thank you Gentlemen. Appreciate that.
Next up I think is a AFE DFS 780 filter/pump install on my truck to attempt to get my fuel system to last longer; i.e. rid the fuel of all entrained air in the fuel.
Stayed tuned.
Old Jan 1, 2021 | 10:20 AM
KodiakF250's Avatar
KodiakF250
Using the title for different topics
One thing that might help you segregate the different topics in the same thread is to put the different topic in each post's title. I've never used the title on a new post (until this one), but this might be a time for it to work.
Old Jan 1, 2021 | 10:23 AM
Overkill2's Avatar
Overkill2
My FS2500 info was posted on @Chuck-B thread on
Oil Bypass System
here:
https://www.ford-trucks.com/forums/1...ss-system.html
Hope you're well Chuck if you see this. Happy New Year buddy.
It starts at post #15. I will have to post pics of where it's mounted and where the hoses run.
Old Jan 1, 2021 | 10:24 AM
Overkill2's Avatar
Overkill2
You're right!
Good idea Kodiak Thanks...
I have done that in the Club a lot...
Old Jan 1, 2021 | 05:06 PM
speakerfritz's Avatar
speakerfritz
Good idea
Old Jan 1, 2021 | 05:54 PM
Jstamm2001's Avatar
Jstamm2001
I appreciate your insight! Thank you sir!
Old Jan 1, 2021 | 07:26 PM
Overkill2's Avatar
Overkill2
Originally Posted by speakerfritz
Good idea
Appreciate it guys... Thanks.
Old Jan 1, 2021 | 07:51 PM
FishOnOne's Avatar
FishOnOne
Looking forward to this one...
Old Jan 1, 2021 | 08:11 PM
Overkill2's Avatar
Overkill2
Yeah buddy!! 👍
Old Jan 1, 2021 | 08:18 PM
Overkill2's Avatar
Overkill2
Okay just saw an email from VLEDs. They are having a 20% off New Years sale until 01/04/21. Check it out.
https://www.vleds.com/?mc_cid=20f15f...eid=9e16451d66
Old Jan 2, 2021 | 05:59 PM
The Bone's Avatar
The Bone
Originally Posted by Overkill2
This thread will be for when I install or do something to my 16 F350. To me, it makes more sense to post everything I do to my truck so it will be in one place so I don't have to go searching for my own past threads when someone asks me a question. I hope this helps someone like all the others here who have helped me. May the conversation start...
Hey Bone, I installed my VLEDs Triton Extremes back on 05/04/2020.
Here's the link of where I only posted pics of the front and rear installs.
https://www.ford-trucks.com/forums/1...-thread-2.html
Here's my other LED thread for the 194 Bulbs for the cab clearance lights.
Thanks Overkill. Now all I need is the back door to the bank.
Old Jan 2, 2021 | 07:28 PM
Overkill2's Avatar
Overkill2
Yep... they ain't cheap. Especially the Extremes that I bought. Hopefully I get a decent life out of them for that $$.
