Starting Point
Old May 19, 2022 | 04:00 PM
  #616
BWST's Avatar
BWST
Got Data?
I used a stainless zip tie like the ones used for exhaust wrap to accomplish this task.
I like that idea - for those of us that do not remove our tailgate much. Is it tight to get in there and cinch it down?
Old May 19, 2022 | 04:23 PM
  #617
FordTruckNoob's Avatar
FordTruckNoob
It’s pretty easy with the screwdriver bit that I modified to coil the zip tie.
Old May 20, 2022 | 09:47 PM
  #618
F350towing's Avatar
F350towing
Today I put her to good use.
We are currently sitting in the trailer up on our future retirement property.
Through the Fraser Canyon I ran into a slow poke driver who would wait until he started to slow down on the hills before getting on the gas. This became annoying quickly as he kept putting me under the turbo at the base of a long hill. First chance at a passing lane and I put him in the rear view mirror.
Not 100% happy with the shift strategy yet as it still commands TC lock up too soon for my liking.
Just to see how the egt’s we’re doing under heavy load, 3rd gear,TC locked, 1600rpm, 40ish-mph and I just put my foot into it on a long uphill. Way under the turbo. I couldn’t get it to over 1200° in SDK 65 light tow with 8500lbs on the bumper.
Truck ran amazingly well and I only once was it not capable of maintaining my desired speed up a hill.
Ready to roll.
First stop just outside of Hope but before the Fraser Canyon.
Second stop in Ashcroft $160.00 in Fuel.
Future home sweet home.
That is one nasty rain cloud. Just across the Thompson River from our fuel stop in Ashcroft.
Old May 21, 2022 | 04:07 PM
  #619
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Great pics! Gives me 'get on the road' urges.
Old May 22, 2022 | 12:01 AM
  #620
F350towing's Avatar
F350towing
If anybody recalls last year here in British Columbia we had some extreme weather events.
One was called a Heat Dome. OK… Whatever… bottom line is it was really freakin hot. One town in the Fraser Canyon broke all time Canadian heat records a number of days in a row. Lytton. Unfortunately a spark from a railcar brakes lit some grass and with the winds through the valley within a short time the entire town was nothing but ashes.
This is the temporary lot where they are storing all the burned up cars.
The next major event was what was dubbed as “ An Atmospheric River “. Over a 3 day span it was something like 20 inches of rain. Again the Fraser Canyon was not spared and we had a chance to see the carnage as well as some of the temporary measures to keep this arterial route open. 7 months since the damage and still a single lane Bailey Bridge for alternating traffic.
Single alternating traffic guided by a pilot car.
Just past the bridge on the temporary single lane. Just to the left you can see the old washed out highway.
Jackass Mountain Summit
Thompson River in between Lytton and Spence’s Bridge.
All photos courtesy of my wife Sonya riding shotgun.
Old Jun 11, 2022 | 09:33 PM
  #621
F350towing's Avatar
F350towing
Finally got some shop time today and got the 2wd lo switch mounted up and all wired in under the dash.
Didn’t have enough time to get under the hood to finish the install on that side.
Almost looks like it grew there.
Finally remember to climb underneath and check the block serial numbers.
Bummer, it’s a PMR. Not that I ever expect to NEED a forged rod engine.
Old Jul 15, 2022 | 02:32 PM
  #622
F350towing's Avatar
F350towing
Question about Bilstein shocks.
They list different shocks for the cab chassis’s, single rear wheel and dually.
The dually shocks don’t come with boots, only the blue plastic sleeves. I would prefer the boots as I feel they would provide better protection for the piston rod.
They appear to have the same mounting.
Are they just valved differently specific to the application, and if so, anybody know what would be the difference in ride quality with the singe rear shock on a dually? I’m sure anything will be better than the stock 21year old shocks with 120k miles on them.
I’m towing with 1200# spring bars on WDH with 800# tongue weight and 20lbs in airlift bags. Definitely not apples to apples on a stock configuration.
I know this is probably like asking the preferred oil or tire choices but thought I would throw it out there.
Old Jul 15, 2022 | 02:41 PM
  #623
kbeefy's Avatar
kbeefy
you can usually look up bilsteins and find their valving specs.
I prefer the sleeves to the boots, In my experience the boots hold debris against the seals and cause early failure. (in a boot up configuration)
Old Jul 15, 2022 | 04:44 PM
  #624
F350towing's Avatar
F350towing
That is an interesting angle to look at it from which I hadn’t even considered.
Thanks for that insight.
As an added bonus the dually shocks are $15.00 cheaper.
Old Jul 15, 2022 | 06:37 PM
  #625
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
While they may appear to have the same mounting, they may not.
The cab chassis frame is different than the pickup frame, which can affect mounting points and shock length.
Old Aug 7, 2022 | 09:42 PM
  #626
F350towing's Avatar
F350towing
Just got back from another week up at our retirement property.
Truck ran strong and efficient.
Gotta get under the hood and do the AC mod. It just can’t keep up in the scorching heat.
At one point noticed that boost was off a bit and EGT was climbing higher than normal on some steeper hills. Soon followed by no boost registering on the gauge. Could still hear the turbo spooling so wasn’t too worried. At our regular fuel stop I popped the hood.
Boost line got hot an ruptured. Quick snip and a zip tie and we are back on the road.
Old Aug 8, 2022 | 02:02 AM
  #627
aawlberninf350
It's a Van Gogh
Nice on the road fix!
Old Aug 8, 2022 | 11:49 PM
  #628
F350towing's Avatar
F350towing
This morning I dropped the spare tire and hit all the shock mount bolts with PB Blaster in preparation for the new Bilstein’s in the rear.
Yes I went with the dually specific shocks.
Old Aug 11, 2022 | 11:34 AM
  #629
F350towing's Avatar
F350towing
Got the rear shocks done this morning.
Soaked the nuts for a few days with PB and then needed to hit the lower nuts with some heat to get them the break free. Upper mounts were a breeze.
Cleaned up the bolts with the wire wheel on the bench grinder and applied a liberal amount of Anti-seize before reassembly.
First shock took about an hour as I figured out the heat was needed. Second was about 25min.
Probably won’t get to the fronts, or the steering stabilizer before my next trip but at least the rears are in the books.
Old Aug 11, 2022 | 01:30 PM
  #630
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Your labor should yield great results. There was a very noticeable difference between the worn out shocks and the Bilstein shocks on my truck. I look forward to your 1st impressions and final thoughts once the full set are installed and road tested.
