Starting Point
Old Apr 2, 2022 | 08:48 AM
  #571
F350towing's Avatar
F350towing
Good job getting it figured out. Will your insurance company still cover you without the immobilizer though?
I am still insurable however the premiums will go up.
May not be covered for theft with immobilizer disabled.
Im currently looking into a replacement unit. Nothing local without a complete alarm system.
Found this one though.
Seco-Larm SLI 762PP-ISS ENFORCER Passive Proximity Immobilizer, 3-point immobilization, Two tamper-proof controllers, Simple, Multiple car operation, Code learning, Passive arming, Secure valet/override mode, Installer test mode, Street tough, Multi-
Old Apr 2, 2022 | 08:53 AM
  #572
FordTruckNoob's Avatar
FordTruckNoob
A complete alarm may not be a bad idea. I like Compustar personally.
Old Apr 24, 2022 | 07:43 PM
  #573
F350towing's Avatar
F350towing
Today after working the truck to bring our trailer home I decided to give her a spa treatment.
Pressure wash and hand mitt.
Meguires scratch 2.0
Meguires Ultimate Compound
then Nu Finish for the protection coat.
Yes… My shoulders are killing me.
Truck goes in for a windshield next week.
The warm windshield didn’t like it when I hit it with the cold water and the crack is now complete from top to bottom.
Old Apr 25, 2022 | 07:07 AM
  #574
SkySkiJason's Avatar
SkySkiJason
Windshield replacement has gone up here. $250 for the one I had done last week... I did a time lapse video of it that may show up on the truck owners YouTube. Probably took 15min to R&R the glass including a little rust mitigation.
Curious what you have to pay up there.
Old Apr 25, 2022 | 12:10 PM
  #575
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Looking fab! Great color combo.
Old Apr 25, 2022 | 01:12 PM
  #576
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Looking good sir! Hopefully the windshield replacement goes well.
I use Meguiar's Ultimate Compound and really like it. I used to use the NuFinish wax, but felt that the clean up was cumbersome. I switched to Meguair's Ultimate Liquid Wax and it has treated my vehicles well. I use a Turtle Wax Ceramic coat spray at the 6 month mark after the compound and wax were applied.
I have not seen the Meguiar's Scratch 2.0 in action and may have to give that a shot. Thanks for posting up the products you use and the results.
Old Apr 25, 2022 | 05:14 PM
  #577
F350towing's Avatar
F350towing
I hope so as well.
I use the NuFinish inside the shop so shaded and cooler and I find it comes off nicely. In the sun on warmer days it can be a bear to polish off.
Been looking into the Ceramic Coat Spray and have contemplated giving it a shot.
For heavy oxidization on the paint or some deeper scratches. Cuts through the crud quickly, but definitely has to be followed up with the ultimate compound.
the obligatory 8 characters.
Old Apr 25, 2022 | 05:25 PM
  #578
F350towing's Avatar
F350towing
At a minimum it will be $300.00 for me since that is my glass coverage insurance deductible.
I will let you know the total cost for the install.
Going to go with the 2001 replacement glass as opposed to the newer Superduty logo glass. Wife says “you want 2016 logo’d glass, buy a 2016”.
I agree, Retro Jethro. Won’t change my mirrors, nor front signal lenses either. Headlight lenses and bulbs… well that was a safety issue.
Old Apr 27, 2022 | 09:49 PM
  #579
F350towing's Avatar
F350towing
Since the truck sits so much I decided to pull the trigger on the Noco Genius 2D and their GCP 1 plug.
Now I have to figure out where to mount the GCP plug. I was thinking just behind the grill on the driver’s side.
Anybody see a reason not to mount the plug here?
Old Apr 28, 2022 | 07:19 AM
  #580
FordTruckNoob
As in behind the grill on that header? Depending on the plug on the end of the extension cord, it might me a little difficult to reach in there. Otherwise, I don't see a reason why not.
Old Apr 28, 2022 | 08:00 AM
  #581
Sous's Avatar
Sous
FTE Emeritus
I preferred to mount my two AC port plugs at their respective corners on the front bumper. I have one for battery a tender on the passenger side battery and the other for the block heater on the driver side. I put them there for easy access and in case I forgot to unplug them and was backing out of the driveway they would "unplug themselves". They have been this way for years and not one issue with either of them.
To answer your question directly, there is nothing wrong with your proposed location of mounting the port other than ensuring there is ample space and clearance behind the mounting surface other than it may be a bit cumbersome to use. I tend to go with easier to use solutions as if they are a pain in the ****, I may skip using them. Then that defeats the purpose of the modification or project.
Below is a recent picture I took where you can see the block heater port in the lower right of the bumper.
Old May 3, 2022 | 03:07 PM
  #582
F350towing's Avatar
F350towing
I managed to get the NOCO installed today.
I had to relocate the daytime running lights relay for where I mounted the 2D.
The plug is easily accessible and not too noticeable for a clean / stock look.
Looking at this picture and see I have to do something about cleaning up the CAC pipe.
Old May 3, 2022 | 03:53 PM
  #583
FordTruckNoob
Nice work! Looks good.
Old May 3, 2022 | 04:00 PM
  #584
Sous's Avatar
Sous
FTE Emeritus
I will echo what Leonard has said above.
(echo voice on) Nice work! (/echo voice off)
Old May 3, 2022 | 09:15 PM
  #585
F350towing's Avatar
F350towing
Truck goes in for transmission service on the 5th, then scheduled for the windshield replacement on the 12th.
@Sous which wire did you tap into for the 2wd lo. IIRC it was the grey, but memory is fuzzy and it easier to ask here than search. I like the fact that you used the ground so no hot wire running hither and yon.
May 20th will be our first big trip of the year up to our retirement property for a week. I’ve done a lot to the truck since the last time it towed through the canyon. Looking forward to the results of my hard work.
