Rebuild Thread
Old Feb 29, 2020 | 02:25 PM
  #241
SmackDaddy's Avatar
SmackDaddy
UPS was way late delivering the roll of firewall sheet and radiator. I tinkered in the shop until 8:30 and drove out to the gate and waited and he showed up about ten minutes later. I got the firewall covered and installed and had everything ready to roll the engine in by 1:00am. The upgraded Mishimoto radiator is about 7/8” thicker than the other one and the transmission orifices are about three times larger in diameter. I’ll post some comparison photos later.
I had to helicoil two valve cover bolt thread bosses in the rockers. I never went to spec on the torque value the service manual shows at 71 ft/lbs. I think it’s a typo. Anyway, I got the lift plate and lift rigged up and rolled her in place. It took me a little over an hour to stab the transmission but I’m working solo. Needless to say I got my sit-ups in for the week! I took a lunch break to shower and eat then headed back out to continue.
Old Feb 29, 2020 | 02:29 PM
  #242
SmackDaddy's Avatar
SmackDaddy
  #243
TooManyToys.'s Avatar
TooManyToys.
Out to the gate ... Texas .... must be South Fork.
71 lb-in.
Old Feb 29, 2020 | 02:33 PM
  #244
SmackDaddy's Avatar
SmackDaddy
71 lb-in.
I have to go look at it again, I could have sworn it read ft/lbs. I knew it wasn’t right. These damn valve covers have been on and off so many times I’m surprised they didn’t strip out a year ago.
Old Feb 29, 2020 | 02:34 PM
  #245
TooManyToys.
Almost home.
Old Feb 29, 2020 | 04:06 PM
  #246
SmackDaddy's Avatar
SmackDaddy
See, I read it correctly! 8Nm is 72 lb/in, not 71 lb/ft. Where did you get your torque value Jack? I could see some guy stripping out every fastener before it dawned on him...
Old Feb 29, 2020 | 04:13 PM
  #247
SmackDaddy's Avatar
SmackDaddy
I found another typo!
Old Feb 29, 2020 | 04:21 PM
  #248
TooManyToys.
2003 Ford DVD Service Manual, a pre-production one. It has errors, like they all do, just not that one. I tend to confirm by using two sources, I also have the International one that's on-line, and I think I dropped that into a thread on here at some point.
There's no way that rocker box can handle that torque. I've heard it being stripped out before, there must be a number of those manuals out there that people are following.
Old Feb 29, 2020 | 04:26 PM
  #249
TooManyToys.
My value cover numbers are correct, but the FICM bracket number is like yours, wrong.
I've found discrepancies in the wiring diagrams too.
Old Mar 2, 2020 | 01:10 AM
  #250
SmackDaddy's Avatar
SmackDaddy
Mated up without forcing it.
No firewall stud trimming necessary Fuzzpuss...I tightened my v-band clamps with everything lined up while the engine was on the stand so it would line up easy. Installed the y-pipe in one unit.
Turbo to down pipe and collector buttoned up.
Old Mar 2, 2020 | 01:19 AM
  #251
SmackDaddy's Avatar
SmackDaddy
We had family day today and after my son was in bed I had to take some time to knock out the turbo and pipes. I will button the rest up tomorrow and hopefully have her purring tomorrow evening if I don’t fart around with OCD stuff tomorrow...
The trick to any Y-pipe installation, turbo and down pipe is to wire the down pipe up and out of the way, leave up pipe bolts loose at the manifolds, leave turbo to pedestal bolts completely out, leave pedestal to block bolts out and mate up the y-pipe without forcing it, clamp it then work the down pipe so it mates up easily, clamp it then turbo to pedestal bolts then finally the pedestal to block and torque the pipe to manifold bolts last. Do it this way and you won’t have exhaust leaks from trying to use the v-band clamps and pry bars to pull the mating surfaces together.
Old Mar 2, 2020 | 09:19 AM
  #252
Fuzzpuss's Avatar
Fuzzpuss
Looks like you forgot the intake manifold, or did you upgrade to a late model one without the bridge? Of course I'm speculating that the 05 and up manifold can go in after the turbo is mounted.
Old Mar 2, 2020 | 07:18 PM
  #253
SmackDaddy's Avatar
SmackDaddy
I have an ‘05 intake with no crossover. About to install the radiator.
Old Mar 2, 2020 | 08:51 PM
  #254
countrycar's Avatar
countrycar
Originally Posted by SmackDaddy
The firewall looks awesome Pal, as well as the engine!
Old Mar 2, 2020 | 09:12 PM
  #255
troy676's Avatar
troy676
Im interested in seeing how you ran your regulated fuel return lines..i made new lines and moved the regulator over to the the left side fender. Your Doing an amazing job.
