April 2019 I had the engine out for a lot of upgrades including a custom regulated return fuel system with a 6.7L fuel pump at the heart. I hand lapped the block decks and installed UCF o-ringed heads, 6.4 pushrods, Mahle head gaskets, rocker box gaskets, oil pan reseal/POR15 paint, oil cooler reseal, IPR stainless HPOP screen, Motorcraft glow plugs, Motorcraft glow plug harnesses, Motorcraft injector reseal, Driven Diesel coolant return lines, firewall heat shield, Motorcraft IPR heat shield, wrapped down pipe and y-pipes with DEI heat wrap then sprayed with ceramic paint. 5200 miles later I was changing the oil and noticed a thin brown line in my degas bottle and sure enough, it was diesel. I pulled the engine and sent the heads back to UCF for inspection and they found their proprietary cylinder 4 and 5 injector cups were leaking and could not repair so they sent me new heads and head gaskets. Both heat tabs were not melted out so they were warrantied. While I was this far I figured I may as well check the cam wear and it had some scuffing but no pits or lines but I wanted to swap it for a Colt stage 2 so the crank needed to come out. I flipped her over, removed the bedplate and had more wear than I was comfortable with so I decided to jump in the rabbit hole and do a full rebuild. I broke her down to the short block and took it to Texas Engine Machine and let master machinist Jeff Winn and his crew do their magic. I decided to go with Johnson Hylift HD made in USA lifters, Mahle 20 over shaved top pistons and the full package deal on the crank, block, connecting rods and cam. I had Jeff install the bearings, measure clearances then grind the crank journals to fit so there would be absolutely no guess work when I go back together with it.
I’m going to try to keep this updated but can’t get as in depth as some of the builds I read over the last few years on here. I’ll do images separately because for some reason when I type a long paragraph and try to post it with a photo it will delete everything and take me to the top of the page.
Scuffed cam lobes Lifters looked fine Crank journal wear More wear Crank bearings worn to copper More crank bearing wear Cam lobe scuffing Going back in with the crank you can just use the right size screwdriver and pin the cam gear through a hole that comes drilled in the block. This method works to set crank in the proper orientation to ensure timing is right. One tooth off and the truck won’t start. The Rotunda tool to center it is too expensive for what it does. Short block prepping for hauling Crank no cranky like this! Loaded up for the 3 1/2 hour drive to the machine shop
My little shop isn’t much but it sure beats working under an open air carport and have to cover tools and everything to protect from the elements. 18x38’ I built on a slab from an old wood shed my father and I built 30 years ago that burned down. The slab cracked from the heat but is good enough for my shop. I plan on filling and smoothing it one day and possibly raising the shop another three feet.
The garage/shed at the farm was built by my Dad, 24’x24’ but with a dirt floor. Someday I’m going to get a real floor in there, but it’s filled with leaky farm equipment. He built it with 2x3 studs and underside rafters that would never, never pass code. Inspections weren’t necessary back then. Damn thing is still there after all the hurricanes and Nor’easters we’ve had over 60 years.
Engine enamel primer on the heads Red! Upskirt shot of o-rings Front cover cleaned with NuBrite AC coil cleaner. It works great on radiators to foam out bugs and crud from in between the little fins. It’s made for aluminum coils but don’t get it on polished aluminum like the top of a Mishimoto radiator...ask how I know. My little shop hand helping me clean and prep the shop. Have to keep those valve springs clean I had my local coatings shop bead blast and Cerakote my exhaust manifolds titanium. It’s good to over 2000 degrees and he did inside and out. It’s the same coating people get on their guns and rifles. It’s durable and looks great! The Flameproof VHT red I did before didn’t cure on the truck like the instructions said it would. Cerakote More cerakote Colt Stage 2 New tapered wrist pin bushings machined to wrist pins Pile of con rods ready to go! Rings Lifters Ooooo nice! Heavy duty clip
188,640 on the engine, hopefully another 300k after this. My frame is rust free and I’m about to install a Blue Top steering gear, new power steering pump, hydroboost rebuild and Sweeting’s high flow hydroboost banjo fittings and braided stainless lines.
Wow, looking good. That's quite a job. I'm tired just thinking about all that work.
Are the Sweeting's upgraded hydroboost hoses/fittings supposed to help with steering and braking? My brakes don't work as well as they used to and I think the hydroboost may be the cause.
Well I broke the oiler ring on my forth piston so I had three piston sets overnighted to get this thing done. I didn’t have my piston ring compressor tight enough and I needed a heavier deadblow hammer to knock it in in one whack instead of tapping on it with the butt of the small hammer with an oily hand like a woodpecker. Live and learn! I am using the Lisle wrinkle band compressor. I like my engine stand but it’s a pain in the butt having to rotate it versus having an engine stand that mounts to the front and rear so the engine can be rolled on it’s side. I’ll post photos tomorrow.
Yes this kit has a banjo fitting on the high pressure lines that aren’t as restrictive as the stock fitting. We will see, I’m installing it along with the other steering components before the engine goes back in while I have all that space to work (naturally). It’s supposed to help the braking as well as the whining power steering I have with the 35” rubber.
I don’t want to clutter this thread debating about these lines and fittings but don’t mind letting you guys know what I know this far and will report back with a review.
