The "Mule" Build
Old May 5, 2016 | 09:46 PM
  #406
nateairman's Avatar
nateairman
Originally Posted by ReBilld
Great news on getting the engine back from the machine shop Adam! I still think you should run the engine in your truck now until it just gives out! LOL! Just to see how long it will go!
While your waiting I can break your engine in and make sure it will run well for the first 100,000..😆
Old May 6, 2016 | 05:03 AM
  #407
pgg00's Avatar
pgg00
Is your truck governored at 90?
Old May 6, 2016 | 09:59 AM
  #408
z31freakify's Avatar
z31freakify
Nope, I was hitting 3800rpm, judjing by the truck shakines I was well over 100 mph maybe 120mph?
Old May 6, 2016 | 10:02 AM
  #409
z31freakify
, man im anxious to start prepping the engine, you know the usual painting, sealing and adding all accesories and cleaning and painting the frame.
Old May 6, 2016 | 10:06 AM
  #410
z31freakify
She Still going, its due for an oil change too
Old May 6, 2016 | 11:15 AM
  #411
cowmilker08's Avatar
cowmilker08
Save your money. Just run it til it blows!
What size tire are your running?
Old May 6, 2016 | 11:17 AM
  #412
z31freakify
285-75R16 maybe 33"?
Old May 6, 2016 | 11:27 AM
  #413
cowmilker08
(285*.75*2/25.4)+16 = 32.83"
3800 rpm / (0.75*3.55) = 1427 tire rpm
1427 * 32.83 / 12 * pi / 5280 * 60 = 139.4 mph
In reality a little slower because your tires are worn, etc.
Old May 6, 2016 | 11:52 AM
  #414
z31freakify
Dam that is good math, so roughly 130mph dam, no wonder it was shaking bad.
Old May 8, 2016 | 10:55 PM
  #415
z31freakify
I was surfing the net and found the 910 comp valve springs, is that the correct part #?
Any info on what I need to know before I order.
Old May 8, 2016 | 11:14 PM
  #416
oldbird1965's Avatar
oldbird1965
That's what I got, 910 comp valve springs. Not sure of any part number except 910.
Old May 8, 2016 | 11:16 PM
  #417
Bob_T's Avatar
Bob_T
Originally Posted by Jarrett Campbell
Is there a drawback to over-valve springing your engine?
More cam wear from the higher spring rate and more valve and seat wear due to higher closing force. I don't know how significant the wear is unless you have some real crazy springs. I don't see the need to run near or over redline with our trucks and I think the stock springs are fine. But I'm a long way from being in my 20's.
Old May 9, 2016 | 07:44 AM
  #418
Jarrett Campbell's Avatar
Jarrett Campbell
Gotcha I was just wondering. Valve springs probably aren't in the picture for a good while for me... I asked because I was curious.
Old May 9, 2016 | 09:12 AM
  #419
z31freakify
The engine Im getting rebuild had 4xx,xxx miles and the valves were worn out badly except the seat,none were salvageable Im guessing around those miles we need to get the valve train worked on but thats just my case on tgis particular engine.
Old May 9, 2016 | 09:33 PM
  #420
z31freakify
So I did an oil change and the knock is not present? The oil smelled like propane gas WTF? Thought it was weird, the oil didnt look bad at all nice and dark honey, same ol Rotella 15w-40 dino oil, just found it odd for it to smell like propane, makes me think compression is getting past the rings and or broken piston, but truck still has lots of power, but its starting to smoke more black smoke than ever, its embarrasing trying to take off on stop lights when theres a car with his window rolled down, he/she gets a plum of thick black smoke inside their vehicle and them doing their repugnant look, shame on me the smoke smells like raw diesel with oil in the mix.
Hopefully I dont do any damage to the injectors, as they are going to be reused.
