Dad's Engine
Old Jul 22, 2014 | 08:41 AM
  #1246
Docjekyl's Avatar
Docjekyl
I just visites your blog, and see your great Job on your truck, congratulations.
Old Jul 22, 2014 | 08:45 AM
  #1247
lavatan's Avatar
lavatan
I'd have to look at my build sheet but I think I tried to get as close to the same on all the cylinders and I think that came out to be .007".
Depending on your machinist they get pretty close to the same bore size on them all. Where I ran into mixing and matching were the pistons. They were all different. Not a lot but enough to make a difference.
I'll have to look at my build sheet to find out where exactly I came out.
Old Sep 8, 2014 | 05:10 PM
  #1248
Gary Lewis's Avatar
Gary Lewis
Got the engine parts from the machine shop today!
Old Sep 8, 2014 | 06:21 PM
  #1249
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Engine ****....
Old Sep 8, 2014 | 08:40 PM
  #1250
RL250's Avatar
RL250
So pretty.....
Old Sep 8, 2014 | 09:47 PM
  #1251
Gary Lewis's Avatar
Gary Lewis
Next step is to get the block on the engine stand and run a tap through every hole. Then I'm going to make the Tim Meyer mods on the oiling system as well as some Gary Lewis mods to smooth some corners.
Old Sep 8, 2014 | 10:26 PM
  #1252
lavatan's Avatar
lavatan
It's looking good, Gary. The good part is when you start working on it and it all comes together. Even better is when you get to hear it fired for the first time.
Old Sep 9, 2014 | 12:22 AM
  #1253
EffunFiddy's Avatar
EffunFiddy
It's like Christmas in September!
Old Sep 9, 2014 | 07:15 AM
  #1254
Gary Lewis's Avatar
Gary Lewis
Jeremy - That point is a ways off, but closer than the truck being done as I plan to put it on a dyno for break-in.
Brad - Yes, it is like Christmas, although a bit more than I would spend on Christmas.
Old Sep 9, 2014 | 06:05 PM
  #1255
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
GAry, is there any space for water between the cylinders on those, or are they like a 400 SBC, siamesed walls?
Old Sep 9, 2014 | 06:37 PM
  #1256
RL250's Avatar
RL250
Looks like plenty of steel from the top at least. Not sure what the passages do inside the casting.
Old Sep 9, 2014 | 06:52 PM
  #1257
Gary Lewis's Avatar
Gary Lewis
No, it isn't like a small-block 400 as there is water between the cylinders.
Old Sep 9, 2014 | 07:59 PM
  #1258
85lebaront2
Good, because those pigs spark knock if you even think about advance.
Old Sep 9, 2014 | 09:28 PM
  #1259
Gary Lewis's Avatar
Gary Lewis
Dad melted down two of those in a mini-motorhome. And I know it was working the engine 'cause he and I took it out one night to tune the carb - with the doghouse off. And the exhausts glowed RED all the time. Man, were those things hot!
Old Sep 10, 2014 | 02:23 AM
  #1260
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Fun, fun, fun
Cruising the highway for hours in the summer, when those things are in the cab with you.
IDC how much insulation you have inside the lid, your legs cook.
