Dad's Engine
Here's a close-up of one of the holes - before I painted them.
Also, I smoothed the edges on the block, which had many razor-sharp ones due to the machining operation. And, I took some of the flashing off from various places on the block to save my hand as some of that stuff was very sharp. And, ran a tap through all 77 holes on the block to ensure they are clean.
So, here's the block ready to use the ball hones on when they come in. Except, that I just realized it doesn't have the heater hose nipple that goes in the hole in the left front corner. And, that appears to be a DOOZ 8555-A, which is "Steel—3/4" O.D. x 5/8" O.D. x 1 3/4" long". Guess I'll go looking for one of those.
As for my Beezer, I sold it long ago and never got it running. Apparently that wasn't unusual for the Birmingham Small Arms bikes.I also forgot to point out something else I did today. Compare the drip pan in the first picture to it in the third pic.
My new mottos are "Leave the shop better than you found it" and "No tools left out at night!!!" I'm hoping to sidestep the massive cleaning effort I went through for the week plus prior to the GTG.
Hopefully I'll carry through with that.
I even rolled the engine stand over to the other room and swept after I used the die grinder to take off the flashing and to dress the gasket surfaces. So, there was lots of debris since that carbide burr works rapidly and the flap wheel spreads all sorts of stuff.
And, cleaning the engine itself will be messy. In the past I've taken them outside and used the garden hose on them. But this time the block is clean from the machine shop vat, so all I'm doing is getting any dirt, grit, or chips out. I'm thinking that brake cleaner will wash most of it out and once everything is degreased and dry that compressed air will finish the job. What do you think?
Motorcycle parts you can boil in a big pot.
Wear goggles.
Brake cleaner burns when you get it in your eyes.
(not as bad as yhe old 'crackly' carb cleaner though)
Also, and I realize this isn't the valve cover thread, but I had a thought that I want to bounce off of you. Remember that I want to recess the two top screws on each cover. The hole in the cover measures .310ish and I was thinking of counterboring it and using a washer to catch the head. But now I'm thinking of using 5/16" (.3125") OD stainless tubing, which measures .257" ID, and using Loctite to hole them in the hole. That way I won't have to use the washers, but I would still counterbore. Thoughts?
You like Amazon.
You know they bought SmallParts, and they also have 'Industrial and Scientific'.
Are you suggesting to sleeve the counterbore, or the hole below it?
Sorry if I am slow on the uptake.
On the valve cover, the two back holes are bored through .310 the height of the cover. But a SHCS's head is usually .365", meaning there's no/little purchase for the head. So the original thought was to counterbore the hole just deep enough to take the head and a washer flush with the top, and large enough to take a washer, although I may have to turn the washer down. But the new idea is to just sleeve the hole with a piece of .3125 OD/.257 ID stainless tubing. I might have to ream the bore slightly, but it is already very close and I would think Loctite would hold it. Then counterbore to recess the head. But, as I think about it I'll probably need a washer anyway to prevent galling, so maybe the earlier idea is the way to go?
Kyle - No, I'm not going to PC the block. I probably could get it in the oven from a size standpoint, but I don't know how to handle the weight. And, I'd need to mod the oven to install the window I have, but I need to do that anyway. The reason is that you are supposed to heat the part until the powder flows, then hold it for 20 minutes. I get by w/o the window by timing it for 20 minutes from when the oven gets to 425. But, that's on relatively light things. A block would take forever to get hot enough to cause the powder to flow, so it would require the window.
I think the guy to talk to at eagle would be Arron. 5444 S 103rd E Ave, Tulsa, OK 74146
<nobr>(918) 627-1123</nobr>
<nobr>
</nobr>
<nobr>They are in the same area as Inland Truck Parts.</nobr>
I used to think we should try it, but I have seen first hand what happens when powder is over baked and under baked. Sometimes it looks like a really cool crinkle coat, but sometimes it looks burnt.
316 has 2% moly and better resists chlorides.
300 series cannot be tempered, so it's either (B) work hardened or (A)annealed, and that is too gummy and likes to gall.
Look at an ISO 7092, 6mm small O.D. washer they are 6.4 id and under 11mm od.
