Dad's Engine
Old Feb 8, 2014 | 05:52 PM
  #436
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
All gas does is cut the oil film that IS doing the lubricating.
That is why they call it washdown.
Old Feb 8, 2014 | 06:01 PM
  #437
BruteFord's Avatar
BruteFord
Originally Posted by bruno2
..... So I cant believe that 100% of the oil that services the mains, rods and wrist pins all drains back into the pan over night.
Gas may not be a lubricant, but it does help reduce the friction once it is introduced into the cylinder. It lubricates better than nothing at all.
OK I'm sorry, I gotta answer this.
So in one breath you claim that the left over oil is plenty. Of course there is left over oil but the way these bearings work they rely on a supply of oil to form a rotating cushion.
Then try and say that gas is a better lubricant then nothing. Sure yes that is true, but just like above there is always a little oil and in a gas engine excess fuel in the cylinder will wash out the left over oil making it A LOT worse.
EDIT, you beat me to it with a better answer Jim.
Old Feb 8, 2014 | 06:03 PM
  #438
bruno2's Avatar
bruno2
Originally Posted by ArdWrknTrk
There is some residual oil IF the drainback valve in the oil filter is holding.
(See the Kinser mini Mopar oilfilter page)
Think about where the sender is in relation to the crank, rod and cam bearings.
But there is not the sort of pressure needed to maintain a proper hydrodynamic cushion.
Bearing metal is soft (it has to be)
There is an explosion jamming a couple of pounds of metal into the bearing and twisting it.
At 600 rpm idle this happens 300 times a minute, or FIVE TIMES A SECOND.
This is why the first few seconds count.
I see. It's not so much the oil itself as it is the force of the oil creating resistance against the force of the combustion.
Old Feb 8, 2014 | 06:07 PM
  #439
bruno2's Avatar
bruno2
I am not buying that either. I have some oil that I washed down with acetone and now it's called penetrating oil. So yeah, it's better than nothing. Even better than straight gas. Spit isnt a lubricant either , but it sure makes vacuum hoses go on nipples easier.
  #440
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes, it's the oil pressure in a restricted area that keeps the bearing from smearing.
If not, you could drive your truck around forever with 5psi or less.
This is one thing that the TMI oiling mod does.
It is changing where the oil is forced out into the cam bearings.
Old Feb 8, 2014 | 06:13 PM
  #441
BruteFord's Avatar
BruteFord
WOW, a mix of oil and acetone is better then gasoline, omg, maybe then 100% oil would be even better.
And actually yes spit is a lubricant, it lubricates your throat for swallowing your words.
Old Feb 8, 2014 | 06:17 PM
  #442
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Aaaand, we're back to the ring seating discussion.
Is there any reason to pre oil the cylinders before inserting the pistons?
Is there a reason for crosshatch?
Is there a reason for proper oil viscosity?
Penetrating oil does not have to support a VERY hard iron or chrome ring under dynamic load at piston speeds of ~4,000 feet per minute.
That's 45 miles per hour!
Old Feb 8, 2014 | 06:27 PM
  #443
bruno2's Avatar
bruno2
I never said it was plenty. I said there was some. Think of it like a garden hose rolled up and hanging on the wall. When you turn it on the hose isnt full, but it isnt empty either. It goes spurt, spurt, spurt and then it flows. When it is "spurting" there is oil present and even though there is oil air , oil air it still is making some pressure. So whenever the oil is present regardless of it being intermittent there are still periods of pressurized oil in the bearings. Maybe not "ideal" pressure , but pressure.
Old Feb 8, 2014 | 06:31 PM
  #444
bruno2's Avatar
bruno2
OK Jim, we are stranded in the desert and we lost all of the oil out of your 460, but caught in time before the motor Seized. we have no motor oil, but we have 7 quarts of penetrating oil. Do we try to drive it back with nothing in the pan or give the penetrating oil a try?
Old Feb 8, 2014 | 06:32 PM
  #445
Gary Lewis's Avatar
Gary Lewis
Meanwhile, back at the ranch, I have an idea. (Don't say it!) When I talked to Kayla at the machine shop yesterday she said they wouldn't deck the block until they have the pistons, which I thought meant they would mock the engine up and measure how far down in the hole the corner pistons are. Instead they will just measure the components and block, calculate the distances, and then determine how much to remove from the block. But, Tim won't have the pistons until March 3rd so it'll be about a month from now (Dad's 94th birthday) before I get them. So, why can't I get the measurements on the pistons from Tim on Monday and pass them to the machine shop? Surely Tim knows them off the top of his head, and they can't vary more than a few tenths.
If that works then the machine shop would be done with the block and crank about the time I get the parts from Tim and I can start assembling the engine.
Old Feb 8, 2014 | 06:34 PM
  #446
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Air compresses, oil does not.
That is the difference between a liquid and a gas.
Air has no viscosity.
Clearances (lack of an escape route) is the only thing that keeps oil in a high speed plain bearing.
I used to have race bikes with pressed together roller bearing big ends.
They could survive with no oil pressure, but not for long...
Old Feb 8, 2014 | 06:40 PM
  #447
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
So, all she wants is the compression height?
Are they going to line bore the block and mains?
Me, I like to mock everything up.
But I don't do this all day, every day.
To me, there are too many variables (like how much rod length you will lose when reconditioning)
This shop came highly recommended.
Do you trust them?
Do you trust your doctor?
Old Feb 8, 2014 | 06:49 PM
  #448
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
How do we seal it up that won't dissolve in Acetone?
I wouldn't expect the engine to survive a mile.
I SURE wouldn't expect it not to need a COMPLETE rebuild if we did make it out.
There is a reason modern vehicles have a big warning
"STOP ENGINE NOW" when they lose oil pressure.
It's not that the engine is going to lock up that moment, but the scoring will completely destroy it.
Engines can run for quite some time.
Remember all the C4C videos?
Old Feb 8, 2014 | 06:59 PM
  #449
BruteFord's Avatar
BruteFord
Decking the block is one thing, sure it's better to do it with the parts in hand but can be done. However the bore is something else entirely. The bore should not be honed until pistons are in hand and actually measured by the shop doing the work. So as they should wait for the pistons anyway for the hone, then all decking it without them saves is a couple hours now instead of then.
Old Feb 8, 2014 | 07:01 PM
  #450
Gary Lewis's Avatar
Gary Lewis
Do you trust them?
I don't know what she wants, but she wants some measurement from the piston. And it has to be the compression height as there's really nothing else. Tim obviously knows that, so....
Yes, I would mock it up as I don't trust myself. But, they do it day in and day out, so know how to do it and have faith they can do it correctly. They did come highly recommended (including by the spitter ) so I trust them.
And, I guess I trust my doctor as I go in Monday to plan out three surgeries:
  1. Removing a pterygium from my right eye
  2. Removing cataracts from my left eye
  3. Removing cataracts from my right eye
So, I'll be less active in the shop when all this starts, although the recovery time from the cataract surgeries. But, a couple of days afterward I'll be able to do most things but lift something heavy - part of the impetus to get the block and crank to the machine shop yesterday. Anyway, the next several weeks will be ...... interesting.
