Dad's Engine
But first I decided I should protect the bearing surfaces. So I installed the old bearings on the big end and tightened the caps down snugly. Then I pressed a wrist pin out of one of the $40 rods and turned it down .002" in the lathe to be a snug fit in the small end. However, that may not be quite enough as I had to go back to the press and nudge it to get it out, so I'll take another .002" off and see how that works.
Then on to the blast cabinet using aluminum oxide at 50 psi to just clean things up. I think the first one turned out good. Here's a before/after. Note the copper on the big end. Presumably that's a factory treatment?
So the next question is how far to go with the cleanup. Here's a shot of the parting line running down the side of the rod. It measures about .075" wide and gets to about .040" tall.
I can take it off, as SDDL-UP did on his, as shown below:
But, does it provide any strength or is it just some place for stress to gather?
If the latter just take off any sharp edges or obvious stress risers.
Putting the surface in compression will do more than polish.
Keep an eye on weights.
Don't go crazy on one of them and not the next.
Once peened you want enough on the pads to easily balance the rotating assembly.
Sharp edges and rapid changes in section are really what will cause risers.
That forging line is small enough that I doubt it would be 'noticed' in a stress analysis.
This guy beat Ferrari at LeMans.
Maybe he is on to something?
http://books.google.com/books?id=S0s...eening&f=false
In a nutshell, he says there is no way to accomplish it DIY and there is no need to polish or smooth the rod first.
He also mentions that it is imperative to get the roots under the bolt heads, as this machined section is one of the most highly stressed areas in a connecting rod.
I'm not jealous, but I'm glad you were able to enjoy one!
in Europe including the Targa Florio and Le Mans. Even more of us know Carroll Smith through his books. His “To Win” series of books brought technical acclaim as they became staples for amateur and professional racers, while his “Engineer in Your Pocket” are today highly regarded as engineering handbooks. We’re never surprised to find his name on or featured in – books on race car design, preparation, engineering and tuning. Among his peers at the Society of Automotive Engineers, he served as a judge for the Formula SAE competition. One of his proudest honors was the Society’s Excellence in Engineering Education award. Carroll Smith was a race engineer and special motorsports consultant with Automotive Racing Products for more than decade. The pages of our catalog alone bear the mark of his enormous contributions to our efforts.
Here at ARP, as elsewhere, Carroll Smith’s mission was simple. He was determined to impart the encyclopedic knowledge of racing and the machinery of racing that he learned during those decades on the world’s racetracks, around those shops and among his engineering peers. He left us at ARP with a significant engineering inheritance. Much of what we now know from Carroll will ensure we remain the world leader in the field of racing fasteners. It is our way of reciprocating for what he gave us that we impart his expertise and experience in the form we know best, superior engineered products. As an engineer, Carroll Smith had successes in Formula 5000, numerous GT and sports car races, and with the Ferrari Formula 1 team. He is best known, however, for his work with Carroll Shelby and the Ford GT40 program which he helped develop into a winner at Le Mans. Ford has recently announced it is bringing back the GT40, its signature race car and a vehicle which, even forty years later, bears Carroll’s fingerprints. To those of us who knew him in person and through his work, the return of the GT40 is just another indicator of the enormous contribution to race engineering that John Carroll Smith continues to make, even after his passing.
Carroll Smith passed away at his California home on May 16, 2003, from pancreatic cancer.
Then he says:I dont think it's worth worrying about Brute.
Bruno it sounds like your only thinking of the cylinder walls. Yes this kind of pre-oiling would do very little in an engine like this one without forced wrist pin oiling or piston squirters. The only things that can be done for cylinder wall wear besides using good oil have to be done now, coated pistons, chomoly rings, and very good machine work. And no gas is not a lubricant. It would however do a lot for the 400s weak spots which my understanding is the cam bearings and to a minor extent the rod bearings. This cam issue is even more important for this engine as he intends to run a roller cam which puts more stress on the bearings. The rear cam bearings and lifters are the last critical parts to get oil pressure and in some cases can take way too long. You've never fired up an engine and it's rattled for 15 seconds after words?
With a little effort and investment it can be ensured that nothing will wear out before the cylinder walls and that that takes a very long time.
HiJack mode off
So, having started I must go on. And here's the first one:It is hard to get a good picture but the parting line is gone and all sharp edges are gone. It took awhile, but now that I have the process down I can do it on the rest of the rods in about a day. And, while it may not make much difference it makes me feel good.
But I understand you're quite a character already!
Carry on.
The live tuning comment is a term the diesel guys use. They do live tuning on dynos at shops and certain meets. All of it is done with a laptop or PC. The only manual adjustments would be if the motor had a regulated return on it and a fuel pressure tweak was made. Supposedly it custom tunes the truck in as good as it can be done.
Morton may indeed let you make changes to the motor during the session. The only issue I could see would be people standing in line to get their turn, which i doubt is the case. It wouldnt hurt to ask.
Now the oiling at start up conversation: So I cant believe that 100% of the oil that services the mains, rods and wrist pins all drains back into the pan over night. There still has to be some left the next morning for the start up. Again once the engine turns so does the oil pump. I can believe that there are intermittent periods of not a lot of oil servicing the lower end. but i just cant see it amounting to much as far as wear goes.
(See the Kinser mini Mopar oilfilter page)
Think about where the sender is in relation to the crank, rod and cam bearings.
But there is not the sort of pressure needed to maintain a proper hydrodynamic cushion.
Bearing metal is soft (it has to be)
There is an explosion jamming a couple of pounds of metal into the bearing and twisting it.
At 600 rpm idle this happens 300 times a minute, or FIVE TIMES A SECOND.
This is why the first few seconds count.
