42 2ton
Old Mar 23, 2019 | 09:17 PM
  #376
Joe777's Avatar
Joe777
Nice bright lights! I really should make the switch to 12v on my truck. When I get the dump body installed I'm going to put some marker lights on it and I know the 6v genny won't get the job done.
Old Mar 24, 2019 | 07:30 AM
  #377
bernette's Avatar
bernette
good morning guys ! down with a cold again ! stayed quite and rested. my Young helper showed up he should start the bondo on the front fenders next week. i was afraid he wouldn,t come. radiator sent last week ,and i sent my crab distributer to charlie.
Old Mar 26, 2019 | 06:31 PM
  #378
bernette's Avatar
bernette
could someone take a close up picture of the front fender park lights. my right side was smashed pretty bad. and the left side i,m no sure. maybe a side view if possible.
Old Mar 26, 2019 | 09:01 PM
  #379
white 66's Avatar
white 66
pics...
Does this help?
Old Mar 27, 2019 | 05:53 AM
  #380
bernette's Avatar
bernette
thanks mark ! what i,m tring to figure out , is if theres some kinda of eyelid molded in the fender. looks like its smooth on the pictures you posted. . my better side has an eyelid ,but it was dented there to.
Old Mar 27, 2019 | 09:03 AM
  #381
tacomacream's Avatar
tacomacream
Old Mar 27, 2019 | 07:23 PM
  #382
bernette's Avatar
bernette
thank you Tacoma exactly what i was looking for.
Old Mar 30, 2019 | 08:04 PM
  #383
bernette's Avatar
bernette
with a slide hammer and a round piece of iron. i managed to pull it out. we should be able to get the park lens right. i thought i would bolt the park lens ,but theres no room for the bolt head. the glass got a small indentation,but not large enought. i welded a stud, and made a cork gasket between lens and light. sandblasted and painted my head lamps.had to do a bit of welding on them. on the bottom of my fenders where they bolt to the running boards ,there was a reinforcement flat bar. i,m not sure thats original, it helps to stiffen the fenders. the bolts on the fenders were not spaced the same so i welded the hole and made one similar to the other side. on my left fender the crack between the fender and cab was not right it was to large. i probably didn,t weld the cab correctly ! i made a notch in the running board to bring fender in about 1/4 inch, no its even. and during that time my yonng helper been applying bondo.
Old Mar 30, 2019 | 08:11 PM
  #384
bernette's Avatar
bernette
Old Mar 30, 2019 | 08:20 PM
  #385
56panelford's Avatar
56panelford
Looking good there Brian..
Old Mar 30, 2019 | 08:30 PM
  #386
bernette's Avatar
bernette
thanks john ! crazy the amount of time you put on little things .
Old Mar 30, 2019 | 09:39 PM
  #387
56panelford
It is but well worth it in the end..
Old Mar 31, 2019 | 09:50 AM
  #388
bernette's Avatar
bernette
Old Mar 31, 2019 | 09:53 AM
  #389
tacomacream
Here are some pictures of a front fender on ebay: https://www.ebay.com/itm/FORD-TRUCK-...QAAOSwPtBcn5Ja
Old Mar 31, 2019 | 10:01 AM
  #390
bernette's Avatar
bernette
when i drove my truck in the shop ,the steering would not come back straight by itself. i had adjusted the steering box with wheels straight ,and removed almost all slack. when i turn the wheels the steering Wheel felt tight on left to right full turn. i suppose the gears ware more in the center ,because thats where you drive most of the time. i had installed bushing and seals thinking it would be ok. i guess i will have alot of slack in the ,middle to get the left right full turn right. yesterday i played on the adjustment and didn,t remember exactly which way to adjust.
craig46 had made a good write up on repairing a steering box.
https://www.ford-trucks.com/forums/1...-question.html
