42 2ton
Old Feb 9, 2020 | 07:00 PM
  #421
bernette's Avatar
bernette
i didn,t seal the seam from the outside, i did use some seam sealer inside so water would not seep in. i did alot of little mistakes, that i would change ! john the guy who answerd your question is a very knowledgeable guy . he,s got 2 real nice trucks and is working on a third one , it would probably be better to seal it. but my trucks going to be kept inside,and only used occasionally. keep on your great work nils!!! i had promis my wife some house renovations , so thats keeping me busy,i hope to get back to my truck in march. i started it yesterday to have access to the rear of my garage , it was -10 C it started great,wanted to take a picture outside in the snow ,but i forgot.
Old Feb 12, 2020 | 11:02 AM
  #422
Camaronisse's Avatar
Camaronisse
Thanks. I did some welding and leading in the seam due to some rust...but i dont trust the seam not leaking, i did fill epoxyprimer in a syringe and fill up the seam, but i think i would go for the 3M sealant before filler and spraying epoxyprimer.
Nils
Old Apr 16, 2020 | 07:56 PM
  #423
bernette's Avatar
bernette
the corona virus , had me off for 3 weeks. started with household chores. then last monday i had enought honey to do list done. i decided i would work on my truck, thinking i was off until may. so sunday i bring truck in the shop, with alot of time ahead of me . started by replacing the crank shaft pulley ,i new it was wore when i disassembled the motor. my engine rebuilter had said he would see to it. keep in mind he had engine for almost a year. it was leaking alot and i kinda thought he didn,t see to it. so i found a good used one and replaced it , i hope it will be better. i then installed my transmission floor cover and rubber carpet and jute pad. lower door rubber seals. i sandblasted bumper braquets and painted them black. installed the bumper as is for now, its a better one i had found in montreal a few years ago. then we get a call that we can open shop wenesday . so that will be it for a while phone been ringing alot after 3 weeks closed.
Old Apr 16, 2020 | 08:04 PM
  #424
bernette's Avatar
bernette
old pulley
Old Apr 16, 2020 | 08:10 PM
  #425
56panelford's Avatar
56panelford
That's looking really good Brian..
Old Apr 16, 2020 | 08:18 PM
  #426
bernette's Avatar
bernette
thanks john ! i was hoping to install grill bars ,and clean and paint my front wheels to install my new tires. then i would be almost good for inspection, and maybe be able to drive it this summer !!! a temporary flat bed would be installed.
Old Apr 16, 2020 | 08:23 PM
  #427
56panelford
I may be getting some parts next week for my project finally..
Old Apr 16, 2020 | 08:59 PM
  #428
bernette's Avatar
bernette
good to hear that john. you can start showing us some of your plans ,for that new project.
Old Apr 16, 2020 | 09:03 PM
  #429
56panelford
It will still be awhile before I start any work on it, still have a few other project around the house I want to get done..
Old Apr 25, 2020 | 06:28 PM
  #430
Joe777's Avatar
Joe777
It is looking good Brian. Bout time to look for the next project!😁
Old Apr 25, 2020 | 09:17 PM
  #431
bernette's Avatar
bernette
hi joe ! i got plans already to many plans , i started last summer , i removed my firewood shed . to make room for a third door on my garage. it will be like my truck a slow process.
Old Sep 19, 2020 | 05:23 PM
  #432
bernette's Avatar
bernette
well its not much but i got my front tires on ! i will need to do some touchups on the wheels, sledge hammers and paint don,t work well together. if i can get my act together i might be able to get my inspection done this month. all i need is rear fenders ! time goes fast i can,t beleive summer over !! took it for a little trip in the field this afternoon ,now that the hay is cut .
Old Sep 19, 2020 | 06:10 PM
  #433
newold46's Avatar
newold46
That looks great outside!
Old Sep 19, 2020 | 06:28 PM
  #434
bernette's Avatar
bernette
thanks ! i drove around in the field a bit trying out my shifting skills. i can now confirm i got my ruckstell backwards !! it shifts kinda smooth,but the fields too bumpy to get to high gear .
Old Sep 19, 2020 | 07:58 PM
  #435
56panelford
Truck looks good Brian, are you going to build a flat deck for it..?
