AE class is in session!
Old Apr 6, 2015 | 05:31 PM
  #661
ExPACamper's Avatar
ExPACamper
Logs upload?
Okeedokee, I now have a set of logs from my mostly-stock Ex
Is it okay to send them to you to look at, and what is your preferred method, address, etc?
Thanks!
Old Apr 6, 2015 | 05:50 PM
  #662
ExPACamper's Avatar
ExPACamper
Log sent!
Cleared DTCs before run, pulled again after run:
U1262 SCP (J1850) Communication Bus Fault
U1027 SCP (J1850) Invalid or Missing Data for Engine RPM
Not sure if they affect the run or not. Haven't begun to track these down yet, but mention them just in case
Old Apr 6, 2015 | 06:09 PM
  #663
white Buffalo's Avatar
white Buffalo
Originally Posted by ExPACamper
Log sent!
Those are most likely from KOEO, I see those when I using the Turbo Lifesaver engine timer
Old Apr 6, 2015 | 06:16 PM
  #664
white Buffalo
Thanks!
If you like you can e-mail them to me.....I'll add them to Rich's (Tugly) log pile.
Edit: PM sent with my e-mail
Old Apr 6, 2015 | 06:19 PM
  #665
ExPACamper's Avatar
ExPACamper
Log pile? Something like this?
Thanks. Just sent it
Old Apr 6, 2015 | 06:27 PM
  #666
white Buffalo
That would be the too high FIPW log pile ........
Old Apr 6, 2015 | 07:24 PM
  #667
Tugly's Avatar
Tugly
Log jam, log pile, log in, log out, log on, log off, log the floored - I feel like the freaking Karate Kid.
Old Apr 6, 2015 | 07:55 PM
  #668
ExPACamper's Avatar
ExPACamper
LOL. Sorry to pile on, wish I could do more on my end.
Old Apr 6, 2015 | 07:59 PM
  #669
white Buffalo
Looks very good John, she's strong, can give the 2700+ ICP that is called for at 40% Duty Cycle......next time don't back off the pedal during the data logging run
Old Apr 6, 2015 | 08:40 PM
  #670
ExPACamper's Avatar
ExPACamper
That's awesome news!
Thank you guys for all you do!
Don't back off the pedal? Tell that to the Blazer I gave loads of room to but caught near the top of the hill
Deer everywhere here the past few days, but I know a spot with no houses and an extended hill. About 20 mins away, but I can go that way when there shouldn't be any traffic
Edit:
For those interested, my Ex is stock, never chipped or tuned, except for Ford AIS just added, Cat delete pipe, and 305/45/R22 tires.
Old Apr 6, 2015 | 08:43 PM
  #671
white Buffalo
Boost numbers looked good as well, 17 psi. 30.9(MAP) - 14.2 (elev. pressure @ 1,000 feet) = 16.7 psi.
so no boost leaks
I'll update the graph................
Old Apr 7, 2015 | 05:38 AM
  #672
Tugly's Avatar
Tugly
Yep... good looking graph. With the new intake, I'd be curious to see what would happen with the red line capped.
Old Apr 7, 2015 | 06:06 AM
  #673
Tugly's Avatar
Tugly
Upon closer scrutiny of the data, I have to ask a couple of things: I think you're getting 16 PSI boost, but I need to see a KOEO with MAP, BARO, and EBP first. I'd also like a good look at that EBP for another reason - the pressure differential at WOT. I need to check my old logs, but that 20 PSI differential at WOT looks a little steep to me. Bear in mind, I could just be having a mental log jam (hyuck), and those numbers could be normal.
Oh.. and the FIPW has the AE bug in it. You need to go to your PID settings for FIPW, and set the "Scale Value" to 10.
Old Apr 7, 2015 | 07:13 AM
  #674
ExPACamper's Avatar
ExPACamper
She sat quiet all night, about 50*F now and about 1200ft elevation. Took this screen shot a few mins ago.
Better? Worse? More interesting?
Old Apr 7, 2015 | 07:57 AM
  #675
Snowseeker's Avatar
Snowseeker
Boy those are all off of each other.
I'd order all new sensors!
