AE class is in session!
Old Jun 11, 2015 | 08:40 AM
  #811
Snowseeker's Avatar
Snowseeker
The "save session" is the one feature I actually like with the version I have now.
What I would also like to have like with my hondata is a slideable bar in the "playback" graph where I could slide the bar up to a certain spot in the recording and it would then show me all the gauge/sensor values at that point.
Old Jun 11, 2015 | 11:11 AM
  #812
coax9952's Avatar
coax9952
Unless AE changes their mind, Save Session is a Dead Duck at V13.0, granted for reasons that make no sense. But it's not my toy, I just rent it. whattaya gonna do.......I ranted at them for 35 min. on the phone to just fix V13 and I'd be a happy puppy, but...You know what they say about pissin in the wind.......
Old Jun 11, 2015 | 07:31 PM
  #813
Snowseeker's Avatar
Snowseeker
Another interesting thing I noticed about my 7.3 and I believe our work truck 7.3 does the same as how cool it runs all the time. I think I need to change some thermostats.
Old Jun 12, 2015 | 06:06 AM
  #814
Tugly's Avatar
Tugly
That looks to be about 175-180. It's hard to tell on a scale of 0-450. Maybe if the maximum was 250, we could all see a bit more clearly what the temperature is. I hate to drag you through this exercise, but could you repeat the process of making the graph (no need to get more data) - setting the max temperature to 225-250?
Old Jun 12, 2015 | 08:59 AM
  #815
Snowseeker's Avatar
Snowseeker
Fixed it. I need to be told stuff over and over again sometimes with computer stuff. It is all greek to me.
Old Jun 12, 2015 | 09:04 AM
  #816
Snowseeker's Avatar
Snowseeker
Now that the graphs are adjusted better it looks like my EBP seems to be jumpy like you were talking about earlier with someone elses graph.
I know my up pipes are good but I have questioned the baby butt seal ever since I had the turbo off for o-rings and other work. The clamp went on like ti should and tightened up good and all but I just never felt like it had a 100% seal up. I keep looking and never notice any soot around the v-band but it may be hard to see with the clamp over the joint?
Old Jun 12, 2015 | 01:58 PM
  #817
Tugly's Avatar
Tugly
I don't want to start a craze where everybody's pouncing on jumpy EBP readings. I can say I have seen smooth data out of the EBP, and I noticed a jumpy reading after I developed a boost leak. I have seen other trucks with leaks with the same jumpy EBP. That's not an iron-clad "if it jumps, it's a leaker", but it has proven to be a good indicator so far. The faster sampling rates of Torque Pro and Infinity (compared to AE) may be a partial culprit here, but nobody has shown me a jumpy EBP line on the same graph as good boost... yet.
Old Jun 13, 2015 | 09:51 AM
  #818
Snowseeker's Avatar
Snowseeker
One thing I left out of that graph and may be part of the jumpy EBP is the rpms. Looking once again the drops in EBP may be at shift points. Lower the rpm and the ebp should lower as well yes?
Old Jun 13, 2015 | 09:55 AM
  #819
Tugly's Avatar
Tugly
When the clutch is in, yes. As soon as you get back on it while in gear, the EBP bounces back up. The RPM data will show the shift points.
Old Jun 13, 2015 | 10:22 AM
  #820
Snowseeker's Avatar
Snowseeker
EBP, Intake pressure, and RPM.
Old Jun 14, 2015 | 07:31 AM
  #821
Tugly's Avatar
Tugly
Looks pretty good. Did you let up for a sec or hit a small rise/dip in elevation?
Old Jun 14, 2015 | 09:03 AM
  #822
Snowseeker's Avatar
Snowseeker
I believe that last dip was when the converter locked up or it went into the last gear. That was around 70-75mph.
The speed output I have trouble getting right too. It only shows 0.1-0.3 all the time. I have read your post more than a few pages back about setting the max speed at like 256 and then closing the program or something and then when reopening setting it at like 100?
Old Jun 14, 2015 | 09:50 AM
  #823
Tugly's Avatar
Tugly
Ah... easy fix. Open up the settings for your speed PID and look at the "Scale Factor". Set that to 256. OK the setting, then open the Speed PID setting again, and set the max to 100. OK the setting, and you're good to go.
Oh, and I thought you had a hand shaker.
Old Jun 14, 2015 | 10:28 AM
  #824
Snowseeker's Avatar
Snowseeker
I remember trying this stuff before. I can't seem to find any adjustments for the speed beside the scale adjustment when opening a log file.
Old Jun 14, 2015 | 10:47 AM
  #825
Tugly's Avatar
Tugly
Once the data is logged, you have what you have. The advice above is for setting AE up to record the data correctly. There are two known logging issues with a few versions of "Legacy" AE (Pre-Giotto):
Fuel Injector Pulse Width PID is on the wrong scale - the Scale Factor needs to be set to 10, and the MAX to 5. This will set the software to record the data in milliseconds, on a scale of 0-5 ms. The FIPW can go higher than 5 when cranking, but what's 2 seconds of data when compared to a drive? Stock trucks should max out at about 3 ms, but a hot tune can go over 5. After exceeding 5 ms FIPW while driving, it no longer matters how much higher it goes - hot is hot.
Side note: I sized my injectors to deliver 100% fuel at just over 2.8 ms FIPW.
Vehicle Speed Sensor PID has an error in the formula. Setting the Scale Factor to 256 corrects the error, then a MAX of 100 fits our trucks nicely.
Giotto has a bundle of issues - too many to fix with settings alone. My favorite problem is the inverted pressure signal (goes up when it should go down), but I forgot which one that was. It's another item where I adopt the attitude "broken is broken", and I move on.
