AE class is in session!
Old Nov 9, 2014 | 08:45 AM
  #571
aaronbob's Avatar
aaronbob
Originally Posted by Tugly
You're not going to have any spunk at 1300 RPM. Where's your downshift?
if i push it to the floor it will downshift, but other than that it wont. i would think at like 2/3 throttle it should downshift but it doesn't.
Old Nov 9, 2014 | 08:52 AM
  #572
Tugly's Avatar
Tugly
My tune downshifts pretty quick, but I have a pristine EBP sensor.
Old Nov 10, 2014 | 02:01 PM
  #573
bike_guy123's Avatar
bike_guy123
subscription tuition paid......
Old Nov 28, 2014 | 11:32 AM
  #574
TKegs763's Avatar
TKegs763
A little help here please. I can't get the option for "enhanced powertrain"... I can only get the option for generic. I haven't used this in a while and was able to get this option in the past. Ideas please?
Old Nov 30, 2014 | 07:43 AM
  #575
Tugly's Avatar
Tugly
Have you changed computers since you last used AE? It sounds like your Enhanced Ford registration isn't in there or isn't recognized.
Old Nov 30, 2014 | 09:34 AM
  #576
Snowseeker's Avatar
Snowseeker
Can AE do the ABS pump stuff for bleeding?
Old Nov 30, 2014 | 12:33 PM
  #577
Tugly's Avatar
Tugly
I've never tried. I know you have to select the ABS module when initiating connection, not the Enhanced Powertrain. There will be a new list of things on the menu to look at.
Old Nov 30, 2014 | 03:10 PM
  #578
Snowseeker's Avatar
Snowseeker
You should try it out, bleed your brakes, and then tell me what to do.
Old Nov 30, 2014 | 03:25 PM
  #579
Tugly's Avatar
Tugly
Maaaan.... Just ship me some round tuits, and I can apply those to the task.
Old Nov 30, 2014 | 03:37 PM
  #580
Snowseeker's Avatar
Snowseeker
Can do, whats the address?
Old Dec 21, 2014 | 09:39 AM
  #581
timmyboy76's Avatar
timmyboy76
not sure if you found this, but, check this "hidden" feature out...
AE's HIDDEN SELF TESTS - Diesel Forum - TheDieselStop.com
Old Dec 21, 2014 | 02:09 PM
  #582
Tugly's Avatar
Tugly
I didn't see anything that I don't already have with my version of AE. I haven't updated since I bought AE because my truck didn't get any newer, and all the problems with the PIDs on the newer versions spooked me off.
This sounds more like a bug than a "secret" feature.
Old Jan 8, 2015 | 02:17 PM
  #583
coax9952's Avatar
coax9952
Helllooooo
Damn, It gets dark in this empty classroom........1st time post, long time lurker.. Just got AE up and running bout 3 days ago and been checking out all the shiney bells and whistles..... I've got a bone stock 2002 w/ about 175,000 on her. The only code that pulled up was a bad Trans case solinoid. A P1876. not bad for an old Girl, I think....anyway I want to get a baseline on it for all the important stuff before I start modding the crap outta it. What would be a good set of Parameters to start with? I've already run my EPBV and Map ( About 3 points high on EPV, so theres a replacement now) and I did a Dummy Run down the Rd. To get a look at RPM, ICR/ICP. Nothing startleing, but I want to get my settings dialed in b4 I cry foul about anything. What's a good package to set up?
Thanks
Old Jan 8, 2015 | 04:30 PM
  #584
Tugly's Avatar
Tugly
Welcome to FTE!
Here are the usual suspects, with limits for better graphing:
Change the max Exhaust Back Pressure to 55, then get rid of Mass Fuel Desired and use Torque Converter Slip with a max 1000 (assuming auto transmission).
Some versions of AE may show your Fuel Injector Pulse Width at less than 1.0 all the time. If that happens, set the scale value at 10, save it, then open it again and set the max to 5 ms.
If your MPH shows zero, set the scale value to 256, close it, then open it again and set the max to 100.
I hope you tested your EBP/MAP/BARO with Key On Engine Off, that's the only way to get an accurate reading for baseline.
Old Jan 8, 2015 | 07:03 PM
  #585
coax9952's Avatar
coax9952
Thanks, and in answer, Yes to all of the rest of your suggestions. I actually absorbed all 39 pages of class 1 and all 8 of Class 2, and been tweeking things for a couple of days now. Alot of the playing has been trying to figure out when NOT to push certain buttons.......But I know how to print now, Progress!
