1986 F-250 Progress Thread
Old Jan 20, 2013 | 07:52 PM
  #196
FordFETruck's Avatar
FordFETruck
It drives way better on the freeway than it does on the streets. Now if it just had good torque. Comp's XE256H should give it quite a bit more torque.
Old Jan 20, 2013 | 08:02 PM
  #197
GruesomeJeans's Avatar
GruesomeJeans
Ha, don't worry considering my gears and tires my truck has about as much torque as my old 200 I6 from my 82 mustang.
Old Jan 20, 2013 | 08:05 PM
  #198
FordFETruck
Wow! at least this thing started spinning tires around the corner at half throttle. It was the on ramp to head north on 167 in Pacific. The south pacific one not the one by the 76 station.
Old Jan 20, 2013 | 08:32 PM
  #199
GruesomeJeans
Gotcha, my old 88 ranger would light up the tires on those onramps with no issue. The bronco probably could but I don't push it too much.
Old Jan 20, 2013 | 09:27 PM
  #200
FordFETruck
Mine will only light them up on wet pavement :/
Old Jan 20, 2013 | 09:32 PM
  #201
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I thought y'all had nothing but moss and algae on the roads out there?
Old Jan 20, 2013 | 09:34 PM
  #202
GruesomeJeans
The bronco will spin on wet pavement if I am turning as well, dry pavement... Maybe if I push it hard enough I could get them going but I don't trust my drivetrain to be strong enough to hold up.
EDIT: Hahaha we don't get THAT much rain the sides of the roads usually have some moss growing up from the dirt areas, but the amount of traffic we get keeps the rest away.
Old Jan 20, 2013 | 09:35 PM
  #203
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
When you kids think you have discovered torque, let Jim and I know. Our engines have torque, enough for mine to light all four rear tires with a 3.55 gear.
Old Jan 20, 2013 | 09:39 PM
  #204
GruesomeJeans
Haha, if I had proper gears, well tuned carb, sturdy drive train, and good brakes then I would have no problem roasting some meaty 35's. But so far as I have discovered, I have 2.73's in my 9" AND with an NP203 t-case I have some power being forwarded up to the front so it isn't ALL going to the back. If I had the 205 t-case it would be a little different.
Old Jan 20, 2013 | 09:41 PM
  #205
FordFETruck
Nope we have pretty clean roads, except the *******s won't re pave a lot of them. Dylan, on C ST south heading back towards walmart and GSA from north Auburn, what do you think of that wonderful patch job they did all through there?
I found it quite, pathetic.
I'll take moss and algaee any day over road salt!!!!!
Old Jan 20, 2013 | 09:49 PM
  #206
85lebaront2
Dylan, yes gears help, read what I said. I don't remember what the OD of my 215/85R16 tires is right off hand, but they aren't small. I had a 1977 F-150 with 390 4 barrel and 3.25 gears in a 9 inch. It was quite capable of burning a set of 235/75R15s nicely. My 1971 Mercury Colony Park wagon had a 2.71 gear and used the same tires as the F-150, a 9.5:1 compression ratio 460 in it would smoke the tires all the way through first gear in the C6. All these vehicles simply had gobs of torque, no need for a lot of gear.
Gears, my 66 Shelby GT350 had a .030 over 289, wide ratio T10, and 3.89 gears, it would light up a pair of M&H drag slicks as it sat, go mid 12s in the 1/4 mile on one of the tracks NHRA records were set on.
Old Jan 20, 2013 | 09:53 PM
  #207
FordFETruck
Have you had an oil pump shaft twist in half yet on the 460? I've heard that's a bit of a problem with em. If I had my way I'd have a 390, lighter than a 385 series and faster for the most part. Only problem with those are the stock distributors don't give enough mechanical advance so they tend to run like a slug.
Old Jan 20, 2013 | 09:57 PM
  #208
Gary Lewis's Avatar
Gary Lewis
Originally Posted by FordFETruck
...I'd have a 390.....so they tend to run like a slug.
Subscribed! This ought to be fun to watch.
  #209
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
No reason for that. The pressure relief is there to unload the oil pump.
Old Jan 20, 2013 | 09:58 PM
  #210
FordFETruck
Thanks! hahahahaha nice word editing. Made me laugh. You want my 351W for $900? I'll put a 390 in my truck.
