So today I drove the truck about 10 miles, ran pretty good but it was light stumbling a lot from not enough accelerator pump shot, I fixed that. I retarded the timing back to 10* BTDC and backed the vacuum advance out and it seemed to help with the hot re start starter bounce back. I also got $75 in free gas today.
When the front tank reads 1/4 tank I have 9 gallons of gas left. Ford quality!
Also I adjusted my carb, it was slightly lean on the drivers side, runs even better now and sounds better. Oh yeah I get 20" of vacuum at idle now Gary Lewis.
Originally Posted by FordFETruck
it's brand new Chris. Well, about 7 months old.
Matthew - Glad you now have the kind of vacuum you should at idle. Sounds like at least the idle A/F ratio is pretty close. But, I'm a little confused by all the changes you seem to be making. And, I don't understand "it was slightly lean on the driver's side". What did you do - back out the screw a bit? What about balancing both sides?
Also, you said the sending unit is only 7 months old and mentioned "Ford quality". Did you buy a new Ford sending unit for your tank 7 months ago and it has already gone bad?
I don't know why I said Ford quality, sort of just joking. It's a sender from LMC (last resort since I couldn't find a OEM one for less than $80). I tuned the carb with a vacuum gauge, the drivers side screw was slightly lean, but I've made timing adjustments without tuning the carb since then and I'm sure that's probably affected it slightly. I got them both equal now with the vacuum gauge for highest vacuum.
At least I have a fuel gauge that works, when it gets to empty on the gauge I suppose I'll have about a 5 gallon reserve. I'd rather have it read like it is now than read high and I run out of gas.
Ok, now I understand. Yes, the aftermarket senders seem to be problematic, so I'm blessed to have one that works pretty well.
As for the carb, if you tuned it w/a vacuum gauge and have it pretty well balanced side-to-side then you are good. And, 20" of vacuum is good. I have 18 - 19".
Yeah, before at idle it would sound kind of like put put put put put. Now with them both equal it sounds much better.
AND as soon as I turned out the drivers side screw the vacuum went up from 17" to 19-20"
My local Oreilly's always seem to have Pertronix stuff stocked. If DSII was so good people wouldn't need to worry about their box crapping out and having to carry a spare...... Plus the wire harness mess on the drives inner fender is ugly.
Sometimes people keep extra coils and ignition boxes with them just in case something ever happens. You never know when something will go out all of a sudden and if you happen to be stranded, you wold wish to have a spare. If it is a cheap part, why not buy 2 and keep an extra on hand in the event of a disaster?
Not sure, we keep all sorts of spare parts in the van from old sparkplugs to a wiper motor, never have needed any of those haha. Couldn't hurt I guess.
Yup. I had a Ford coil fail me on I-10 in AZ back in 72. Truck was 6 months old and the coil died. Split it open with a chisel and found the wire from the positive terminal to the winding had broken. Put a splice in it, wrapped the coil with half a roll of paper towels, and stuffed it in the mount. We bought a new one in the next town but used the old one for the rest of the trip. Didn't miss a beat, but I swapped it out for the new one when we got back to Wichita and put that one in the side pocket as a spare. Was still there when I sold the truck.
Mine is mounted vertically. The coil that came off our Galaxie was epoxy filled. (352 FE) In '72 it would have been a 360 or 390 FE if it was a V8 so it might have been epoxy filled.
