Rebuilding E4OD
Old Jul 8, 2011 | 12:52 PM
  #376
pickncrew's Avatar
pickncrew
sent to MuskyMoe, lol
Old Jul 8, 2011 | 08:19 PM
  #377
torkum's Avatar
torkum
Please send me a copy of the file, thanks!
Old Jul 8, 2011 | 08:46 PM
  #378
pickncrew's Avatar
pickncrew
file sent to torkum...
Old Jul 9, 2011 | 06:04 AM
  #379
torkum's Avatar
torkum
Got it, thank you!
Old Jul 10, 2011 | 04:06 PM
  #380
Youngbell's Avatar
Youngbell
Need zip file
Please send zip to youngbell1@aol.com
Thanks
I overhauled my e40d trans now it has no reverse or forward but it will move when I unplug the vss and an error code is set then it works fine. Any thoughts?
Update: getting 8 volts not 12volts to the epc and low line pressure about 8 psi when I unplug the vss I get 12 volts to the epc and 70 psi when the error code is set for the unplugged vss. Trans Works fine
Old Jul 10, 2011 | 09:01 PM
  #381
pickncrew's Avatar
pickncrew
sent to youngbell... you may want to start a new thread with your problem you are having
Old Jul 11, 2011 | 11:16 AM
  #382
IJRoorda's Avatar
IJRoorda
Pickncrew, if I could get a copy of that file, I would appreciate it; I have an E4OD rebuild in my future (hopefully the trans in the truck holds on long enough to rebuild one on the bench). My Gmail address is same as my username - thanks a lot!
Old Jul 11, 2011 | 11:37 AM
  #383
pickncrew's Avatar
pickncrew
sent to IJRoorda !
Old Jul 17, 2011 | 12:27 PM
  #384
jonl370's Avatar
jonl370
Hi, Could you please send me the zip file? Thanks!
Old Jul 17, 2011 | 02:30 PM
  #385
pickncrew's Avatar
pickncrew
what's your email?
Old Jul 20, 2011 | 11:28 AM
  #386
jonl370's Avatar
jonl370
jonl370@hotmail.com
Old Jul 20, 2011 | 01:14 PM
  #387
pickncrew's Avatar
pickncrew
sent to jonl370
Old Jul 27, 2011 | 07:29 AM
  #388
96_F250_Deezal's Avatar
96_F250_Deezal
deleted my email with the zip file on accident... send again please
ericps70@yahoo.com
Old Jul 27, 2011 | 11:45 PM
  #389
Slimline's Avatar
Slimline
Found this thread searching on how to rebuild an E4od. If possible I would love a copy of your file! robDOTdeforge@gmail.com (dot is . :P) Thanks a lot, if my new valve body does not fix the issue I will let you know how the rebuild goes
Old Jul 28, 2011 | 08:32 AM
  #390
pickncrew's Avatar
pickncrew
sent to 96 F250 Deezal & Slimine
