Rebuilding E4OD
Old Nov 25, 2013 | 02:06 PM
  #511
akuhr93'f150's Avatar
akuhr93'f150
Sorry to those I didn't send the zip too over the last couple of months, I have been inactive on here for a while because of college and I spent a month in Australia this summer. Send me a personal Message with you email address (if you did and didn't recieve it please do it again.) and I will try and get it to you. However I would appreciate it if some other people would jump in and help share the files.
Old Nov 25, 2013 | 02:07 PM
  #512
akuhr93'f150
I will not be consistently checking this thread for people asking for it so it is up to you to contact me through a PM. Just want to make that clear.
Old Nov 27, 2013 | 04:17 PM
  #513
Aroth's Avatar
Aroth
not sure on how to send a pm. Can some one please help? Thank u!
Old Dec 2, 2013 | 08:41 AM
  #514
f350dually95's Avatar
f350dually95
E4OD front pump
My flexplate broke and took out the tq conv and front pump seal. I replaced and tested good till OD suppose to kick in. Light blinks and no OD. Good til OD every time after reset. I think my front pump is the problem so I am removing the tranny again and replacing the pump. I would like to study the zip file mentioned. Can I get the E4OD zip file without putting my email address on the forum? Maybe sending a private message?
Thanks
Old Dec 2, 2013 | 01:44 PM
  #515
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Why is the OD light flashing? What code is stored? How could the pump work in all gears except overdrive?
I recommend reading the codes before pulling the trans.
Old Dec 2, 2013 | 03:21 PM
  #516
f350dually95
I got no codes. The reason I think it is the pump is I opened the line going to the cooler and ran it timing the output into a bucket and it was very low less than a quart in 1 min 30 seconds. As I understand it the overdrive is not a gear it just locks the tq conv.. It does not have the umpth to do that. This is just my screwed up thinking on my study of the E4OD.
Old Dec 2, 2013 | 08:11 PM
  #517
Mark Kovalsky
Your pump flow is VERY low. It should be one quart in 15 seconds.
You understanding of overdrive is wrong. It is another gear ratio in the transmission. The torque converter can be locked or unlocked in overdrive.
Old Dec 3, 2013 | 09:35 AM
  #518
f350dually95
Thanks. Do you think I should try the pump?
Old Dec 3, 2013 | 04:26 PM
  #519
Mark Kovalsky
Before doing that I'd put a pressure gauge in the test port and see what it is doing.
Old Dec 3, 2013 | 04:47 PM
  #520
f350dually95
OK Thanks. My friend is coming over from Texas tonight. We will check PSI.
I think I saw the Pressures in my manual. Thank you for the tips.
Old Dec 7, 2013 | 10:09 PM
  #521
f350dually95
Hi Mark,
I forgot to bring up the PSI readings but the best was 6 PSI low and the worst was 14 PSI low. We replaced the pump and all is well now. I have test driven now numerous times and have over 100 miles so far Thanks for the assistance. Do you know how to get a code reader to work on the 1995 models? It has only an OBD2 connector and never shows a code. I think I should have had one with the tranny issue and several other times but never shows a code.
Old Dec 8, 2013 | 08:58 AM
  #522
Mark Kovalsky
It takes a high end scan tool with Ford specific software to read transmission codes.
Old Jan 21, 2014 | 10:46 PM
  #523
Dbozian's Avatar
Dbozian
Originally Posted by dieselzen
Sure Kinglg, no problem, except that I need your email address to get it to you. R.A.
New to forum read that you were sending copies of e4od helpers guide. Nay I get a copie please. Thank you for your time and patience in this matter. Dbozian
Old Feb 15, 2014 | 04:13 PM
  #524
mrlogger's Avatar
mrlogger
what would cause reverse to stop working
Old Feb 15, 2014 | 06:17 PM
  #525
Mark Kovalsky
Usually a failed reverse clutch.
