Rebuilding E4OD
Old Dec 16, 2010 | 10:46 AM
  #241
mustangman's Avatar
mustangman
Pickncrew got it thank you !!!!!!!!very valuable info, happy holidays!!!
Old Dec 23, 2010 | 10:02 AM
  #242
ecuatt4's Avatar
ecuatt4
zip file
i would greatly appreciate it if someone would be able to send me the zip file
ecuatt4(at)gmail.com
Thanks for your time
Old Jan 2, 2011 | 02:15 PM
  #243
Offroaddog's Avatar
Offroaddog
If someone could send me the Zip file I would Appreciate it
Bugman67(at)Hotmail.com
Old Jan 12, 2011 | 05:34 PM
  #244
BILLANDTEDS's Avatar
BILLANDTEDS
Dieselzen, I have a 91 f-350 dually crew cab with the E4OD Tranny. Just went through it top to bottom, with tender loving care back in the truck I now have Reverse. Hope you and your zip might be able to HELP!!! Please send to tedsweld@comcast.net ,Thanks
Old Jan 13, 2011 | 08:51 AM
  #245
bubbswins16's Avatar
bubbswins16
e40d diesel
can someone please send me the zip file. jwallker22@yahoo.com thanks
Old Jan 13, 2011 | 01:46 PM
  #246
pickncrew's Avatar
pickncrew
sent... to bubbswins16, offroaddog & ecuatt4
Old Jan 29, 2011 | 08:18 PM
  #247
lonecountryboy's Avatar
lonecountryboy
Could you send me the zip also? worley6969@yahoo.com
Thanks
Old Jan 29, 2011 | 08:41 PM
  #248
pickncrew's Avatar
pickncrew
on it's way lonecountryboy
Old Jan 29, 2011 | 09:21 PM
  #249
lonecountryboy
Thank you hopefully this will give me the information I need.
Old Feb 3, 2011 | 01:16 PM
  #250
ratio411's Avatar
ratio411
Wow... Thanks for keeping this thread and the "file" alive for all these years!
I sure could use a copy.
Glad I found this site.
Thanks again!
Dave
ratio411 at live dot com
Old Feb 6, 2011 | 04:40 PM
  #251
pickncrew's Avatar
pickncrew
got you covered ratio411
Old Feb 6, 2011 | 08:27 PM
  #252
raymonkey77's Avatar
raymonkey77
I'm having some of the issues mentioned here. replaced MLPS, TPS, transmission solenoid harness, and now I have 1-2 is fine, but 2-3 and 3-4 doesn't work at all. When I had replaced the harness everything started working again, that was a month ago. I have codes 536, 617, 618 and 628. I'm wondering if my soleniod pack is bad. I occasionally can get it to shift from 2 - 3 by going WOT (wide open throttle) then it will shift and go to overdrive normally. This started out where when cold it would shift perfect then when warmed up to full operating temperature it would start shifting late. Now 2 - 3 is more 2 - neutral. I would also like a copy of the infamous zip file pretty please. Raymonkey77 at gmail.com
I welcome any suggestions. This trans was rebuilt about 17,000 miles ago. replaced fluid and filter. Shuts down at 70 mph and kicks back on at 65. I think the trans temp sensor is out.
Old Feb 6, 2011 | 09:50 PM
  #253
pickncrew's Avatar
pickncrew
File sent Raymonkey.
Any warranty on the rebuild?
Old Feb 6, 2011 | 11:17 PM
  #254
raymonkey77
It is still under warranty, but the company that did the rebuild is no longer in business. I had changed the fluid because I could hear the fluid boiling. This was because the torque converter failed to go into lockdown thanks to a corroded solenoid pigtail. I'm thinking because of the extreme heat that the TOT is now out. I've had back surgery twice now so getting under the truck to test the TOT with an VOM is not the easiest thing in the world to do. I'm hoping that I can replace the fluid, filter, and solenoid pack and be back to operating normally again. I'm looking for any suggestions anyone might have.
Old Feb 7, 2011 | 07:02 AM
  #255
PDR60's Avatar
PDR60
Could I get a copy of the zip? I'm getting ready to overhaul/update. TIA phil@pdr60.com
