Missouri Chapter Join Chapter , Leader:77&79F250
JANUARY early thread!
Old Jan 22, 2012 | 11:17 AM
  #586
earthquake68's Avatar
earthquake68
RC, I'll run that by my niece and see what she wants to do with it.
Old Jan 22, 2012 | 11:33 AM
  #587
earthquake68
This dent is really starting to TICK ME OFF!!!
I pulled the old exhaust manifold. I ran a sanding block across it. Yup, sure enough, it was warped bad. Then I ran the sanding block across the manifold that I got from Rich. Nice an flat. Great! I chased the threads on the manifold and in the head so I had proper clamping force. I cleaned, and block sanded the head so everything was as good as it could be. I double gasketed the manifold again. It is just about as perfect as it can be. Everything pulled up tight. It all looked good. I even used high temp silicone on the gaskets. Then I fired it up.....
The damn thing sounds like it's LEAKING!!! I felt all over the manifold and pipe flange with it running. I felt no leak. I pulled the manifold back off and looked at the gaskets. No evidence of a leak or blow by on the gaskets or head. Put it back together. It sounds like it's leaking. but it's not. Damn it! I give up. I'm DONE with this pile of crap.
Old Jan 22, 2012 | 02:29 PM
  #588
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Did you high temp the exhaust to manifold fitting area? (you know where the 2 threaded studs are) (perverts need not reply) lol
And are you sure its not the the exhaust system it self?
Old Jan 22, 2012 | 02:38 PM
  #589
earthquake68
Here's some pictures of that Dodge. The condition was somewhat disappointing to say the least. I'll let you all form your own opinions.
Of course the ole' girl did a fantastic job hauling the carcass around!
Here's the actual truck...
Old Jan 22, 2012 | 02:42 PM
  #590
earthquake68
That's about it. Like I said. Disappointing. RC, is the scrap weight still good? I understand if it's not. I was expecting more myself.
Rich, I have no idea what's up with this piece of crap exhaust. There's no leak at the pipe flange. That I know for sure.
Old Jan 22, 2012 | 04:46 PM
  #591
77&79F250's Avatar
77&79F250
Part it out on "the list" first to at least to get a little bit more, them axles should get you something??
And it looks like a 96, so the dash bezel will not fit my 99, thanks anyway.
Old Jan 22, 2012 | 04:50 PM
  #592
j20owner's Avatar
j20owner
Switched out the ratty rear bumper on my 90 today. Hopefully a link to the album on facebook will work.
Well, I don't think the facebook link was working so I'll do it the old fashioned way:
Old bumper and hitch shortly before being torched off:
Rust one the rear brackets and the hitch is welded to the frame and the bumper brackets. The tongue is rust welded into the receiver tube and the cross pin is too. It's all junk.
Bumper is gone!
Bumper stolen from a 94 F250 that is going to be flatbedded later down the road.
Bolted up and ready to roll. I like it.
Old Jan 22, 2012 | 06:04 PM
  #593
earthquake68
I had a decent day with Lee's truck. Now his wipers work properly and the side markers work as well. I'll put the stereo in it tomorrow and see about the rear brakes. I also found some questionable wiring under the hood. That may be some of the intermittent power issues.
Old Jan 22, 2012 | 08:36 PM
  #594
j20owner's Avatar
j20owner
I updated my previous post to just link to the pictures.
Today was a very productive day. Got the bumper swapped out on the F150, inspected the axles that are going into my Jeep project, along with a couple of NP208 transfer cases. Couldn't get to the 700r4 because the truck it's bolted in has kind of sank into some terra firma over the years. Things are looking up. The front 44 we're going to be using has flat-top knuckles on both sides. Too bad it has 3.73 gears in it, I was hoping for some 4.10s, but a set of 4.10 gears from Randy's Ring and Pinion is only $165.
Old Jan 22, 2012 | 09:24 PM
  #595
pintoches's Avatar
pintoches
Worked on the frame for big red some more tonight! Pic as you ask.
My Dana 44 outer's!
Old Jan 22, 2012 | 09:36 PM
  #596
j20owner's Avatar
j20owner
What is Big Red? How much did it cost to have your knuckles machined and how much for the arm you're using? Are you going with a full high steer, or just crossover steering?
Not quite 20 questions, lol.
Old Jan 22, 2012 | 09:41 PM
  #597
pintoches's Avatar
pintoches
Big red Is Ryan's non Ford truck It was $25 to have it machined full high steer! This is the driver knuckle don't have right one done yet was waiting on paint to dry tonight!
Old Jan 22, 2012 | 09:48 PM
  #598
whiskey runner's Avatar
whiskey runner
what a long day..been down arkansas all day yesterday came back this afternoon. gathered more firewood and a few other tasks.now its time for bed..alan let me know what you want to do..i am leaving for arkansas again tomorrow afternoon... well ya'll have a good night
Old Jan 22, 2012 | 10:14 PM
  #599
77&79F250's Avatar
77&79F250
Big red what, with a passenger side drop? Hurray for your outers, going 8 lug on the Bronco finally?
Well folks, I am out here early tomorrow afternoon from PA to Dulles/DC and enroute to Germany at 7 PM. Should be in Istanbul and then into Iraq by Wed am....
I'll be in touch.......
Old Jan 22, 2012 | 10:17 PM
  #600
whiskey runner
have a safe trip rich... i know you will stay in touch
