Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Oct 4, 2018 | 10:42 AM
  #946
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by John smith 2018
And the search begins. Any chance of getting some part numbers NumberDummy on the drivers door vent window glass and door locks?
if the locks come as set including the ignition its fine. the ignition was changed and the previous owner doesn't have the keys to the doors.
Anything you can find out is greatly appreciated, thanks in advance. You Rock.
D8TZ-1022050-D (replaced D0HZ-8022050-A) .. Door & Ignition Lock Set w/2 keyed alike keys / Obsolete
1970/89 L/LN/LNT/LT/LTL/LTS500/900.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
LONG LEWIS STERLING in Bessemer AL has 2 = 800-476-3716.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 168 = 800-476-9653.
D0HZ-8021412-A Clear & D0HZ-8021412-B Tinted .. Vent Window Glass (NAGS: 2599T) / Obsolete
GREEN SALES CO. in Cincinnati OH has 1 = D0HZ-8021412-A clear glass = 800-543-4959.
NOS PARTS SOURCE has 1 = D0HZ-8021412-B tinted glass.
Check with local auto glass shops if this is still available. Give them the NAGS (National Auto Glass Society) number, specify clear or tinted.
Old Oct 4, 2018 | 10:50 AM
  #947
Destroked 450's Avatar
Destroked 450
Originally Posted by SlikWillie
Nice!! Thank you for that. Was hoping you still had the factory air cleaner. Looks like a fun project.
It definitely needs a better air cleaner than what it has.
Old Oct 7, 2018 | 07:37 AM
  #948
Thomas Emmons's Avatar
Thomas Emmons
Greetings, just joined. Picked up a 69 N-Series 600 yesterday, will likely be ;looking for a few restoration/repair components. Reach out to me, if site permits; trobco@gmail.com,...thnx, Tom
Old Oct 7, 2018 | 12:56 PM
  #949
Thomas Emmons
VIN N61DUF57020
Picked this up yesterday, step one, ID VIN. May also be looking for Manuals, Repair/Maintenance.
Thnx
Old Oct 8, 2018 | 11:53 AM
  #950
NumberDummy
Originally Posted by Thomas Emmons
Picked this up yesterday. VIN: N61DUF57020
N61 = N600 (gas).
D = 330 2V Heavy Duty FT engine.
U = Louisville KY Assembly Plant.
F57020 = 1969.
Old Oct 16, 2018 | 12:46 PM
  #951
74F600's Avatar
74F600
the part search continues
greetings... looking for potential part # and available retailers for a clutch dust cover boot on an NP 435 4 spd in a 74 Ford F600. thanks in advance. also interior door panels, headliner and the trim around the stock radio?
Old Oct 17, 2018 | 01:39 AM
  #952
William Rose's Avatar
William Rose
Need help
I’m in the process of buying a 1967 F600 dump, it needs a core support and inner fenders. Do you know what the part numbers are? And what website you can order them from? Thanks!
Old Oct 17, 2018 | 10:23 AM
  #953
Hanks other son's Avatar
Hanks other son
If your looking for new parts you might try LMC truck catalog just type it into google they should have every thing your looking, also, if I'm not mistaking that is a standard cab with larger fenders and grill so all the interior trim pieces will be the same on all the f- series trucks and wrecking yards are full of them. good luck with your truck
Old Oct 17, 2018 | 01:19 PM
  #954
NumberDummy
looking for part # and available retailers for a gear shift lever boot on an NP 435 4 spd in a 74 Ford F600.
D5TZ-7277-A (replaced C7TZ-7277-A) .. Gear Shift Lever Boot / Obsolete
1967/72 F500/750 // 1973/80 F500/800.
BOSS MOTORS in Marysville KS has 1 = 800-453-3696.
Old Oct 17, 2018 | 01:48 PM
  #955
Jeffrey Ferrell's Avatar
Jeffrey Ferrell
84 Ford F800 or F8000
Done a few VIN checks and can't find what this truck is.
  #956
NumberDummy
1967/72 F500/750 & B500/750 School Bus // 1973/79 F500/800 & B500/800 School Bus:
D1TZ-16054-A (replaced C7TZ-16054-B) .. Right Inner Fender Apron / Obsolete
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
D1TZ-16055-A (replaced C7TZ-16055-B) .. Left Inner Fender Apron / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
1967/72 F500/750 & B500/750 School Bus:
D1TZ-16138-A (replaced C7TZ-16138-C) .. Radiator Support / Obsolete
No Ford dealer or obsolete parts vendor has any.
Old Oct 17, 2018 | 02:12 PM
  #957
NumberDummy
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
X = Class 7 Air Brakes / 23,001-33,000 lbs. Gross Vehicle Weight Rating range.
K87 = F800 Diesel.
U = Caterpillar model 3208N or 3208T 10.4L (636 cid) V8 Diesel.
4 = Check digit, FoMoCo use only.
E = 1984.
V = Kentucky Truck Assembly Plant.
A52933 = 1984 Numerical Sequence of Assembly, the trucks specific serial number.
262397:
26 = New Orleans LA Ford District Sales Office, where the original selling dealer ordered the truck from.
2397 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
?41" Wheelbase.
K870 = F800 Diesel, 23,100 lbs. Gross Vehicle Weight Rating.
FH8: FH = Tan all Vinyl with Full Width Seat / 8 = Conventional Closed Cab.
SK = Spicer model CM5552A 5 Speed Manual Transmission.
JBN:
JB = Eaton model 22221 Two Speed Rear Axle / 6.17/8.41 / 22,000 lbs. Rear Axle Capacity.
N = Ford 9,000 lbs. Capacity Front Axle with Power Steering.
Old Oct 18, 2018 | 07:11 AM
  #958
Jeffrey Ferrell
Thank you so much, this info is a God send.
Old Nov 4, 2018 | 10:39 AM
  #959
hillyvilly's Avatar
hillyvilly
Hi NumberDummy , I was hoping that you could help me decode my vin and data plate info so I can do a brake job on my 1978 F600 dump truck . The Vin # is F61DVCA1690 The data plate reads 158 F616 AA8 3A E34 …….. 24000 2558177 I am trying to determine which brakes I have and wheel cylinders etc. and where I can get these parts to keep her going . BestRegards Ed
Old Nov 4, 2018 | 12:27 PM
  #960
NumberDummy
VIN: F61DVCA1690 .. Warranty Plate: WB: 158 / COLOR: Blank / TYPE/GVW: F616 / BODY: AA8 / TRANS: 3A / AXLE: E34 / MAX GVW LBS: 24000 / DSO: 2558177
Your F600 has a 7,000 lbs capacity front axle (4) and a 17,500 lbs. capacity two speed rear axle (E3).
This info must be known to get the sizes of the brakes, but there are two different sizes of rear brakes.
Front brakes with 7,000 lbs. capacity axle are: 15" x 3.00" // Rear brakes with 17,500 lbs. capacity could be 15" x 5.00" or 15" x 6.00."
