Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Apr 26, 2019 | 03:15 PM
  #1066
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by RRRAVEN
What bulb number do you need. I have a few and can check and will send to you for nothing if I have the correct one?
It's not marked. I know that a Halogen home theater light bulb will work, but there are several different versions.
Here in "the sticks," Staples doesn't have the one I need. They carry it, but are out...I asked the dumb cluck of a salespeep when more were coming in, he doesn't know.
Old Apr 30, 2019 | 04:04 PM
  #1067
belikethismike's Avatar
belikethismike
NumberDummy:
Curious request for a part number, availability ( if any ) & prices on the lid or the top cover of the battery boxes on the vehicle below? I'm also looking for any place that might still carry wiper blades. I believe these are 20'in in length and are the kind that just slide down the arm.
Year: 1974
Model: WT9000
VIN#: Z90TVT06124
Thank you in advance,
~Michael
Old May 1, 2019 | 03:54 AM
  #1068
NumberDummy
Originally Posted by belikethismike
NumberDummy:
I believe these are 20" in length and are the kind that just slide down the arm.
Year: 1974 / Model: WT9000 / VIN: Z90TVT06124
D3XZ-17528-A .. Wiper Blade / Obsolete
1974/77 W/WT900.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
There are a gazillion different battery box pics, since you posted the VIN, I eliminated all but three. I'll post the correct pic when I know which one it is.
1974 WT900 before serial number T40,001: (2) 12V 204 amp batteries // (4) 6V 158 amp batteries.
1973/77 W/WT900: With dual integral battery box and fuel tank.
Old May 2, 2019 | 01:46 AM
  #1069
Hisdudeness570's Avatar
Hisdudeness570
F800 brake rebuild diagram/walk thru
i have a 96 F800 24000 GVW Lucas Girling brake setup.I managed to get apart but about to put back together.I need either a walk thru or diagram to put it back together,since what i found is i did it wrong on the break down. Thanks help greatly appreciated.
Old May 12, 2019 | 07:18 PM
  #1070
belikethismike
Any luck with these as of yet? Mine are the dual integral battery box & fuel tank.
I’m also in need of part numbers & availability for the upper & lower radiator hoses and the belts.
as always, thank you!
Old May 12, 2019 | 11:43 PM
  #1071
NowFordHappy's Avatar
NowFordHappy
1978 F600 Heater Core / Blower Motor
An actual replacement part would be nice but i can easily fabricate a seal as needed? Do you have a compatible part numbers or the dimentions for this year?
I can provide other info if needed?
Thanks!
Old May 13, 2019 | 01:27 AM
  #1072
NumberDummy
Z90TVT06124
1973/77 W/WT900 with Detroit 8V-71N
C9PZ-8260-A .. Upper Radiator Hose / Parts catalog says to cut off at "B" (Motorcraft KM-110) / Obsolete
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
D1HZ-8286-A .. Lower Radiator Hose (Motorcraft KM401) / Obsolete
GREEN SALES CO. has 1.
1) C9PZ-8620-CB .. Air Conditioning Belt (Motorcraft JC-460) / 1/2" wide x 46" long / Obsolete
GABRIELLI TRUCK SALES in Jamaica NY has 1 = 718-997-7348.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 26 = 800-476-9653.
1) C9PZ-8620-CD .. Air Brakes Belt (Motorcraft JC-483) / 1/2" wide x 48 3/8" long / Obsolete
CARPENTER NOS OBSOLETE PARTS has 4.
2) C9PZ-8620-GG .. Fan Belt (Motorcraft JC-614) / 1/2" wide x 61 1/2" long / Obsolete
2) D0HZ-8620-A .. Alternator Belt (Motorcraft JC-283) / 1/2" wide x 28 3/8" long / Obsolete
BUCKEYE WESTERN STAR in Plain City OH has 1 = 888-210-5344.
BOWMAN SALES & SERVICE in Bowman ND has 1 = 701-523-3257.
GREEN SALES CO. has 5.
Pic: Post the basic part numbers of the parts you need.
Old May 13, 2019 | 09:24 PM
  #1073
kd0nfq's Avatar
kd0nfq
number dummy,
i am looking at aquiring an old ford t series. numbers on the door are as follows.
A81CUF10934
158 M A811 0081 U CPE
30000 208 2800 61
what can you tell me about this old girl? im courious what engine, trans, rears it came with. how it was originally ordered, and i may need to find a windshield for it if i get it bought.
thanks!!!!
Old May 15, 2019 | 08:00 PM
  #1074
foster32203's Avatar
foster32203
looking for info on my new project
1FDNF70H0EVA05272 997
Old May 15, 2019 | 08:08 PM
  #1075
Aligater's Avatar
Aligater
Hi Bill, Found a firetruck!
C76FUD56523
135 C760 1 91 Q HQE
27500 199 3800 A1103
Old May 15, 2019 | 09:49 PM
  #1076
NumberDummy
Originally Posted by kd0nfq
NumberDummy, I am looking at acquiring an old Ford T series.
A81CUF10934 / WB: 158 / COLOR: M / MODEL: A811 / BODY: 0081 / TRANS: U / AXLE: CPE / MAX GVW LBS: 30000 / CERT NET HP: 208 / RPM: 2800 / DSO: 61
A81 = F800 (diesel).
C = Caterpillar model 225 636 cid 8 Cylinder Diesel.
U = Louisville KY Assembly Plant.
F10934 = 1969.
158" Wheelbase.
M = Wimbledon White.
A81 = F800 (diesel), 30000 lbs. GVWR
0081: 00 = There is no 00 BODY code, look at it again / 81 is a Conventional Cab.
U = Dana(Spicer) model 6852-G 5 Speed Direct.
CPE:
CP = Eaton model 19221 Two Speed Rear Axle / 5.43/7.39 / 23,000 lbs. Rear Axle Capacity.
E = Ford-Rockwell/Timken 9,000 lbs. Capacity Front Axle without Heavy Duty Front Brakes.
30,000 lbs Gross Vehicle Wight Rating.
208 net HP @ 2,800 RPM
61 = Dallas TX Ford District Sales Office, where the original selling dealer ordered the truck from.
Old May 16, 2019 | 03:40 AM
  #1077
NumberDummy
Originally Posted by foster32203
Looking for info on my new project;
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
N = Class 6 - Hydraulic Brakes - 19,501-26,000 lbs. Gross Vehicle Weight Rating range.
F70 = F700 (gas).
H = 370 2V or 4V (6.1L).
0 = Check digit, FoMoCo use only.
E = 1984.
V = Kentucky Truck Assembly Plant.
A05272 = 1984 Numerical Sequence of Assembly, the trucks specific serial number.
Old May 16, 2019 | 03:59 AM
  #1078
NumberDummy
VIN: C76FUD56523
WB: 135 / COLOR: C / MODEL: C760 / BODY: 1 91 / TRANS: Q / AXLE: HQE
MAX GVW LBS: 27500 / CERT NET HP: 199 / RPM: 3800 / DSO: A11033 (edit)
C76 = C750 Tilt Cab (gas).
F = 391 4V FT engine.
D56523 = 1968.
135" Wheelbase.
C = Pure White.
C760 = C750 Tilt Cab (gas), 27,500 lbs. GVWR
1 91: 1 = Light Gray Crush Vinyl & Light Gray Blockweave Vinyl / 91 = 91A Standard Cab.
Q = Dana/Spicer model 5652 5 Speed Direct.
HQE:
HQ = Eaton model 17121 Single Speed Rear Axle / 7.17-1 / 18,500 lbs. Rear Axle Capacity.
27,500 lbs. Gross Vehicle Weight Rating.
199 net HP @ 3,800 RPM
Edit: A11033: A1 = Ford Motor Company of Canada Ltd - Central Ford Division, where the original selling dealer ordered the truck from.
1033 = Domestic Special Order number, something was installed on the truck that was not an RPO (Regular Production Order) after it left the assembly line, probably the fire apparatus.
Old May 16, 2019 | 09:07 PM
  #1079
Aligater's Avatar
Aligater
D56523 = 1968.
135" Wheelbase.
C = Pure White.
HQE:
A is Ford Motor Company of Canada LTD., but with a missing number, this is all I can tell you.
A11033 sry my bad eyes
Old May 16, 2019 | 09:29 PM
  #1080
NumberDummy
See edit in post# 1078
