Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Jun 7, 2018 | 12:14 AM
  #871
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by DBrawley
I sure have, Bill! Some of my buddies have Model A's and I go there with them from time to time. What a neat "time capsule" kind of place!
They have quite a few NOS parts, but very little place to display them, excepting the glass showcases. Most are boxed up in a backroom adjacent to the office.
Bill, the owner used to be partners with Harold Looney, who owned several Ford Parts Obsolete stores, the last one in Stanton.
Looney (who wasn't crazy!), purchased all the used and NOS parts (excepting Shelby/Mustang), when Valley Ford Obsolete in North Hollywood sold out.
Old Jun 7, 2018 | 07:13 PM
  #872
04superduty6.0's Avatar
04superduty6.0
I'm looking at buying a 1979 Ford dump truck, all I have is VIN F82BVDC5899, door plate is missing. Present owner thinks carb needs adjusting or rebuilt, so I'm trying to figure out what engine and if possible what the GVW might have been.
Old Jun 8, 2018 | 01:37 PM
  #873
NumberDummy
F82 = F800 (gas).
B = 300 1V I-6 or 370 4V V8.
V = Kentucky Truck Assembly Plant.
DC5899 = 1979.
Warranty Plate riveted to the left door face below the latch // Certification Label glued to the B pillar (door post) below the striker plate.
Both have the GVWR listed.
Old Jun 13, 2018 | 09:52 AM
  #874
Oldmics's Avatar
Oldmics
Hello
Could you help me out with the part# for a 1979 F700 fuel tank (gasoline) sending unit.
Its a round 75 gallon tank. If any other info is needed regarding the tank - please let me know.
And of course IF you can find one that is availiable.
Thanks so much.
John (Oldmics@Yahoo.com)
Old Jun 14, 2018 | 04:09 PM
  #875
NumberDummy
And of course IF you can find one that is available.
Thanks so much.
There's a gazillion different sending units, because there's a gazillion different fuel tanks. Look on the top of the sending unit for its stamped ID number, post what it is.
Here's an example w/a 50, 75 or 100 gallon round tank: D4HF-9275-AA
Old Jun 14, 2018 | 04:16 PM
  #876
Oldmics's Avatar
Oldmics
Bill
Thanks for the reply
There does not appear to be any info on the top of the sending unit. Perhaps the unit has to be removed and the info is on the bottom side in the tank?
Would the information on the metal tag riveted onto the tank be of any assitance to you?
Thanks,John
Old Jun 14, 2018 | 04:26 PM
  #877
NumberDummy
Bill
Would the information on the metal tag riveted onto the tank be of any assistance to you?
If there's no ID number, the sending unit was replaced from one bought in an auto parts store. It might be correct, might not.
If it's the ID number for the tank on that metal tag, that'll be a big help.
Old Jun 14, 2018 | 04:32 PM
  #878
Oldmics's Avatar
Oldmics
Tank is a D9HS 9002 TA 75 gal as I previously mentioned
Thanks,John
Old Jun 14, 2018 | 04:48 PM
  #879
NumberDummy
Tank is a D9HS 9002 TA 75 gal as I previously mentioned. Where?
Thanks,John
I cannot find this ID number. There are several D9HS-9002's, but all have 3 letter suffixes.
Round, is it a step tank, does the truck have a gas or diesel engine?
Old Jun 14, 2018 | 05:10 PM
  #880
NumberDummy
Old Jun 20, 2018 | 06:04 PM
  #881
Spirit of '76's Avatar
Spirit of '76
Little help needed...
Hey Bill,
Wondering if you might have any info for me on this part;
https://www.ford-trucks.com/forums/1...l#post18045235
Thanks for all you do,
David
Old Jun 22, 2018 | 04:23 PM
  #882
redneck_davis's Avatar
redneck_davis
Hey Mr. Bill . . just bought a f500 fire truck. F50bvm60968
L32 f500 4 8 A 42
L5000 126 3400 462152
Old Jun 23, 2018 | 07:59 PM
  #883
NumberDummy
Originally Posted by redneck_davis
Hey Mr. Bill . . just bought a F500 fire truck.
F50BVM60968 // 132" Wheelbase / COLOR: Blank* / MODEL F500 / BODY: 4 8 / TRANS: A / AXLE: 42 / MAX GVW LBS: 15000 / CERT NET HP: 126 / RPM: 3400 / DSO: 462152
F50 = F500 (gas).
B = 300 1V I-6.
M60968 = 1972.
132" Wheelbase.
F500 (gas); 15,000 lbs. GVWR
4 8: 4 = Black Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
42 = Rockwell model D100 Single Speed Rear Axle / 6.20-1 / 13,000 lbs. Rear Axle Capacity.
15,000 lbs. Gross Vehicle Weight Rating.
126 net HP @ 3,400 RPM
462152:
46 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
2152 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order.
Old Jun 24, 2018 | 02:34 AM
  #884
aussie bl's Avatar
aussie bl
wondering
hi mate been reading through your posts was wondering if you would have any info on my truck it in australia so maybe not thanks for any help these are the only numbers i have
cheers Stuart
Old Jun 24, 2018 | 09:33 AM
  #885
NumberDummy
Sorry, cannot help with "Down Under" info, one needs an Aussie/New Zealand parts catalog which I don't have.
