Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Apr 13, 2019 | 05:27 PM
  #1036
Hillbillysuv's Avatar
Hillbillysuv
I can’t speak for the bases on those air ride seats, but the seats themselves look like forklift or stepvan seats.
Old Apr 22, 2019 | 02:19 PM
  #1037
belikethismike's Avatar
belikethismike
I have every Ford Truck Parts Catalog from 1928 thru 2001, so I can decode all the VIN info, codes from the Rating/Warranty Plates and the Certification Label first used in 1981.
If you need parts, obsolete or not, I can look up the numbers, then search for them on two online websites to see if anyone has them. Then will post the part numbers, sources that have them.
If the parts are still available, I will list the MSRP and the FTE member discount price offered by sponsor PARTSGUYED.COM (Ed Olson, parts manager of Horizon Ford in Seattle WA).
I've been doing this jazz on FTE since 11/04/2006. And, btw: One of the parts locator sites is only accessible to FoMoCo Dealers.
NumberDummy:
Detroit Diesel is telling me the Fan Blade, Fan Shroud & Radiator are Ford items. Any chance of locating part numbers, availability ( if any ) & prices?
Year: 1974
Model: WT9000
VIN#: Z90TVT06124
Thank you in advance,
~Michael
Old Apr 22, 2019 | 03:50 PM
  #1038
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by belikethismike
NumberDummy:
Year: 1974 // Model: WT9000 // VIN: Z90TVT06124
One part per post, here's the fan shroud info.
T = Detroit 8V-71N 568 cid 8 Cylinder Diesel.
T06124 = 1974.
D3HZ-8146-D .. Fan Shroud / Marked on upper left corner: D3HA-8146-LA / Obsolete
1973 W/WT900 with Detroit diesel from serial number R20,001; Ditto 1974; Ditto 1975 before serial number W00,001
No Ford dealer or obsolete parts vendor has any, none on ebay.
This shroud was also used with Cummins diesels, here's the parts catalog pic that shows all the D3HZ-8146-D applications:
Old Apr 22, 2019 | 04:18 PM
  #1039
NumberDummy
D3HZ-8600-F .. Fan Blade - 6 Blades / Marked: D3HA-NA / Obsolete
1973/77 W/WT900 with Detroit 568 cid Diesel with 6 Blade Fan.
Also misc 1973/79 L/LN/LNT/LT/LTS900 with Cummins Diesels.
Old Apr 22, 2019 | 04:36 PM
  #1040
NumberDummy
D5HZ-8005-AE .. Radiator / 38 3/8" high x 31 1/4" wide x 2 7/8" core thickness / Obsolete
Marked: D5HA-8005-HA or HB or AZA or BAA
1973/77 W/WT900 with 568 CID 8 cylinder Detroit & 8 cylinder 903 cid Cummins diesels.
You could get it recored by a radiator shop.
A friend of mine owns a truck wrecking yard that has been in his family since 1929, he might be able to help you.
Southern California Truck Wrecking / 8229 S. Alameda Street / Los Angeles CA 90001 / 323-587-3144 ask for Marty.
Old Apr 22, 2019 | 04:52 PM
  #1041
belikethismike
NumberDummy, as always thank you so very much for your time & expertise.
This website / forum and all of us whom participate in it will certainly be at a tremendous loss the day you meet your creator! The wealth of knowledge you have and resources is invaluable. I say again sir, thank you!
Old Apr 22, 2019 | 08:38 PM
  #1042
garanda's Avatar
garanda
Needing help decoding Vin of a truck that I just purchased
F60ECP40262
Old Apr 22, 2019 | 10:24 PM
  #1043
NumberDummy
Originally Posted by garanda
Needing help decoding VIN of a truck that I just purchased.
F60ECP40262
Welcome to FTE
F60 = F600 2WD (gas).
E = 361 2V FT engine.
C = Oakville Ontario Canada Truck Assembly Plant.
P40262 = 1972.
VIN when decoded doesn't tell you much. Warranty Plate riveted to the left door face below the latch, post a pic of it or type the codes.
Old Apr 23, 2019 | 05:54 PM
  #1044
mrpilotron's Avatar
mrpilotron
A little background info about this truck:
This is an old fire truck with 11,000 original miles. It has what I consider an odd shift pattern 5 speed plus a 2 speed rear axle. The shift pattern looks like:
2-4-R
3-5-1
The clutch just barely engages at the top 1/2 inch of travel so I'm trying to figure out what part(s) I need to start looking for to replace the clutch.
The doors still close like they're new and there are no dents or rust anywhere. The fire department installed a new 24HP transfer pump on it about 12 years ago and it moves water very well. I already replaced the hydro-vac booster under the cab a few months back, but now it's sucking a heck of a lot of air through that little breather behind the seat which also makes the engine have a really bad vacuum leak. Looks like I need to change it out again.
The truck spent 2 weeks completely submerged thanks to the Midwest flooding last month and I'm doing everything I can to get it back to being healthy. All fluids have been changed, the fuel tank flushed and filled, several hours of pressure washing everything to remove the mud deposits, and then a second oil change after running the engine 5 minutes. The first oil change poured out 100% water only, the second oil change came out looking like butterscotch. Obviously, I didn't try starting the engine before the first oil change. I'm a bit surprised it started and ran as well as it did. I gave the Briggs and Stratton engine on the new pump the same treatment so it's running nice again too. Right now, we're using it as a wash water tanker for more flood cleanup efforts. With the bad clutch, we are almost to the point of just dragging it with a tractor since the water source is within a mile of where we're cleaning.
Old Apr 23, 2019 | 06:34 PM
  #1045
85e150's Avatar
85e150
Welcome to FTE!
Possibly a Clark direct. The trans code can be decoded, so stand by on that one.
Shift patterns:
http://www.chevyc60.com/the_transmission_page.htm
It should not be sucking air through the breather all the time--only briefly when you step on the brake.
Does the clutch lock up solid with your foot off the pedal, and does it shift ok with the clutch depressed?
Old Apr 23, 2019 | 06:48 PM
  #1046
mrpilotron's Avatar
mrpilotron
The transmission is certainly a Clark direct. There are no "OD" markings on the shift ****, just numbers. I'm not sure which Clark model, but I suspect it will be either 282v or 285v. I'm not finding a whole lot of info on that from Google. I might have to climb under there and clean off the ID tag, but I'm at work right now and the truck is 40 miles away.
The breather sucks air continuously and seems to actually slow down a bit when I step on the brakes. The brakes seem to work fine.
The clutch locks up firm enough to move the truck around in low gears, but I can slip it if I stab the throttle. It's definitely past it's serviceable life and there's no adjustment left on the linkage. Shifting works normally when the pedal is pressed. None of the online parts lookups I found know this truck exists so I'm not sure how to find the part numbers.
  #1047
NumberDummy
Originally Posted by 85e150six4mtod
Welcome to FTE!
TRANS code R = Clark model 2621-V1 or 2622-V1 5 Speed Direct.
This is a 1967 F600 w/a 361 2V FT engine assembled in Kansas City MO and ordered from Omaha NE Ford sales office.
Rear axle was a Domestic Special Order as there's no code for it. The D is the front axle code.
I'll decode the whole enchilada later tonight.
Old Apr 23, 2019 | 07:10 PM
  #1048
mrpilotron's Avatar
mrpilotron
Whoa! 1967 is a surprise. I've been looking for 1976 parts. Somebody was dyslexic on the date. No wonder nothing else is making sense. I'm not surprised this came from KC and was ordered in Omaha. The fire truck spent it's whole life within 100 miles of Omaha and was owned by the Herman Rural Fire District, which is a tiny farming village just north of Omaha.
Old Apr 23, 2019 | 07:49 PM
  #1049
mrpilotron's Avatar
mrpilotron
I'm curious now about what axle might have been ordered for this truck. The pumpkin is much bigger than I expected and since 1500 gallons of water weighs 12k lbs, it's unlikely that this truck stays under that published 20k GVW when full of water. I haven't weighed the truck, but I'm sure it's more than 8k empty. Since the axle's electric shift motor was under water for 2 weeks, I guess I should pull it off and give it a careful teardown and cleaning too.
Old Apr 23, 2019 | 08:35 PM
  #1050
NumberDummy
Originally Posted by mrpilotron
F60 = F600 (gas).
E = 361 2V FT Engine.
K = Kansas City MO Assembly Plant.
A99444 = 1967.
174" Wheelbase.
J = Rangoon Red.
F602 = F600 (gas), 20000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Bar Pattern Vinyl / 81 = 81A Standard Cab.
D = Optional Ford-Rockwell/Timken 7,000 lbs. Capacity Front Axle. There is no rear axle code.
20,000 lbs. Gross Vehicle Weight Rating.
182 net HP @ 3,800 RPM
540093:
54 = Omaha NE Ford District Sales Office, where the original selling dealer ordered the truck from.
0093 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Since there's no rear axle code, that's one reason why this truck was a Domestic Special Order.
If it was sent out by Ford after it left the assembly line to have the fire apparatus installed, that's another reason.
