Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Apr 19, 2018 | 12:29 PM
  #826
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Destroked 450
Bill: not going to argue over the codes but I don't think that's a 18,000 lb front axle, 18-20k lb front axles normally only came on heavy dump trucks or heavy haulers, the front of those trucks usually set higher for the larger floater tires to clear the fenders.
You're correct, it's a typo, should be 12,000 lbs. capacity Rockwell-Timken model FF-903 front axle. I corrected the post.
Old Apr 19, 2018 | 05:57 PM
  #827
80broncoman's Avatar
80broncoman
Can you convert the number on a part to the real part number ?
Its a Exhaust clamp From the turbot to Down pipe (number on part is F3HT-5A281-AA )
This is from my F-700
Old Apr 20, 2018 | 06:57 AM
  #828
NumberDummy
Its a Exhaust clamp From the turbot to Down pipe (ID engineering number on part is: F3HT-5A281-AA )
At one time I could, but last September, I loaned my Master Cross Reference Catalogs that cover the 1980's to Gary Lewis.
Gary returned the parts catalogs on microfiche slides (left lower in pic), but still has the other stuff.
You could contact Gary, or Green Sales, because they'll have these same catalogs.
Old Apr 20, 2018 | 09:19 AM
  #829
ifixjets's Avatar
ifixjets
6th Gear
I ask in the wrong place door tag decode
Hello I need help. I am looking at a N600 had guy send me a few pic here is the door tag thanks
Old Apr 20, 2018 | 10:00 PM
  #830
NumberDummy
N60 = N600 (gas).
D = 330 2V H/D FT engine.
U = Louisville KY Assembly Plant.
C73004 = 1968.
199" Wheelbase.
U = Lunar Green.
N602 = N600 (gas), 20,000 lbs. GVWR
481: 4 = Charcoal Black Crush Vinyl & Charcoal Black Ladder Pattern Vinyl // 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
62 = Timken model F106N Single Speed Rear Axle / 6.20-1 / 15,000 lbs. Axle Capacity.
20,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
53 = Kansas City MO Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Apr 25, 2018 | 09:04 AM
  #831
firelake's Avatar
firelake
need help on vin
Purchased a 1974 F600 dump truck over the weekend. Looking for info on the truck. Have found part of the info but not all. VIN is F60DVT21357. Door plate has WB 158 Color T Type/GVW T602 Body 538 AXLE E23 Trans O MAX GVW 19200 DSO. 21
Old Apr 25, 2018 | 01:33 PM
  #832
NumberDummy
VIN: F60DVT21357 // WB: 158 / COLOR: T / TYPE/GVW: F602 / BODY: 538 / TRANS: O / AXLE: E23 / MAX GVW LBS: 19200 / DSO: 21
F60 = F600 2WD (gas).
D = 330 2V Heavy Duty FT engine.
V = Kentucky Truck Assembly Plant.
T21357 = 1974.
158" Wheelbase.
T = Candy Apple Red.
F602 = F600 2WD (gas); 19,200 lbs. GVWR
538: 53 = Medium Red & Dark Red Vinyl / 8 = 81A Standard Cab.
O = Fuller model T905-B 5 Speed Direct or New Process model NP-542-FL 5 Speed Direct.
E23:
E2 = Eaton model 16244 Two Speed Rear Axle / 6.17/8.58 / 17,500 lbs. Rear Axle Capacity.
3 = Ford 6,000 lbs. Capacity Front Axle without P/S
19,200 lbs. Gross Vehicle Weight Rating.
21 = Atlanta GA Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Apr 25, 2018 | 02:37 PM
  #833
firelake's Avatar
firelake
T21357 = 1974.
158" Wheelbase.
E23:
Many thanks for the info. How do I tell which trany I have?
Old Apr 25, 2018 | 03:20 PM
  #834
NumberDummy
Look for a ID tag on the trans.
Scroll down to see a pic of the Fuller tag.
Old Apr 25, 2018 | 10:42 PM
  #835
Shade Tree Mech's Avatar
Shade Tree Mech
Bill,
I have a new project and hoped you could look up the VIN for me
F60Z6H70278
Says it is a 1956 F600
Thanks
steve
Old Apr 26, 2018 | 10:33 AM
  #836
NumberDummy
Originally Posted by Shade Tree Mech
Bill, I have a new project and hoped you could look up the VIN for me
F60Z6H70278
F60 = F600.
Z = 272 2V Heavy Duty.
6 = 1956.
H = Detroit MI Truck Assembly Plant.
70278 = 1956 Numerical Sequence of Assembly, the trucks specific serial number.
Old Apr 26, 2018 | 07:01 PM
  #837
80YOFORDGUY's Avatar
80YOFORDGUY
1973 F750 VIN
HAVE A 1973 F750 -- VIN F75FVQ75161 ALL VIN DECODER SITES ASK FOR A 17 DIGIT VIN BUT I DON'T THINK THEY WERE 17 DIGITS IN 1973 SINCE THIS IS THE VIN ON THE TRUCK AND THE TITLE. HOPE YOU CAN HELP.
ALSO, THE LOCAL PARTS HOUSES THAT I DEAL WITH DON'T HAVE ANY LISTINGS FOR PARTS ON ANY F SERIES TRUCKS LARGER THAN THE F-350. ANY SUGGESTIONS ON PARTS SUPPLIERS? PREFER ONLINE IF POSSIBLE.
THANKS
Old Apr 26, 2018 | 08:07 PM
  #838
NumberDummy
Originally Posted by 80YOFORDGUY
Have a 1973 F750 - VIN: F75FVQ75161
No 17 digit VIN's until 1981. Try NAPA for parts.
F75 = F750 (gas).
F = 391 4V FT engine.
Q75161 = 1973.
VIN doesn't tell you much.
Warranty Plate riveted to the left door face below the latch, post a pic of it or type all the info: WB / COLOR / MODEL / BODY / TRANS / AXLE / MAX GVW LBS / DSO
Old Apr 27, 2018 | 11:01 AM
  #839
ifixjets's Avatar
ifixjets
6th Gear
1968 F600 decode please
Hello looking at a f600 ask the guy for a pic of the I'd tag he sent this. I can find most everything except rear axle.
F60CKC
174 J F602 4 81 A F70
20,000 164 3800 53
Old Apr 27, 2018 | 02:32 PM
  #840
NumberDummy
F60CKCXXXXX
20,000 164 3800 53
What year is this? The last 6 digits of the VIN could decode to 1968 or 1976.
