Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Apr 3, 2018 | 02:03 PM
  #796
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by lakequ
Can you decode my VIN for me?
F61 = F600 (gas).
D = 330 2V Heavy Duty FT engine.
C = Oakville Ontario Canada Truck Assembly Plant.
G35101 = 1969.
156" Wheelbase.
COLOR: Blank.*
F610 = F600 (gas); 21,000 lbs. GVWR
F 8 = This F 8 seat upholstery color/material not listed in the parts catalog for 1969. It might be Green Vinyl if the truck is a Custom Cab (1970 listing).
O = Fuller model T-905-B 5 Speed Direct or New Process model 541 5 Speed Direct.
F3C:
F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity.
C = Ford Rockwell-Timken 6,000 lbs. Capacity Front Axle.
21,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
470002:
47 = Cincinnati OH Ford District Sales Office, where the original selling dealer ordered the truck from.
0002 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the purchasers order, making it a Domestic Special Order.
Old Apr 4, 2018 | 08:51 AM
  #797
lakequ's Avatar
lakequ
thanks number dummy
Old Apr 6, 2018 | 07:00 PM
  #798
Corn73's Avatar
Corn73
Please decode this VIN, Thanks in advance NumberDummy.
Old Apr 7, 2018 | 12:06 PM
  #799
NumberDummy
Originally Posted by Corn73
Geez Louise, even with a 27" screen and a magnifying glass, this pic is so tiny that I can barely read it. Post a LARGER pic next time.
There's no guarantee that I'm reading these codes correctly. By the time I'm through, my eyes will resemble Mr. Magoo's!
W95 = NT950 (Diesel).
D = Cummins model NHE-195 743 cid 6 Cylinder Diesel.
U = Louisville KY Assembly Plant.
B12153 = 1967.
194" Wheelbase.
COLOR J = Rangoon Red.
MODEL W952 = NT950 (Diesel); 49,000 lbs. GVWR
BODY 681: 6 = Black all Vinyl / 81 = 81A Standard Cab.
Domestic Special Order TRANS - DRIVESHAFT - FRONT & REAR AXLE listed on the separate plate.
MAX GVW LBS = 49,000 lbs. Gross Vehicle Weight Rating.
CERT NET HP 184 @ 1,950 RPM
DSO 220210:
22 = Charlotte NC Ford District Sales Office, where the original selling dealer ordered the truck from.
0210 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Old Apr 7, 2018 | 12:57 PM
  #800
DeRock1106's Avatar
DeRock1106
1974 F 699
I appreciate all your interpretations. Amazing!
I have the following numbers on the door tag:VIN: F61DVU21635
TYPE GVW: F613
TRANS: 0
AXEL: E3L
Thanks a million!
Old Apr 7, 2018 | 01:31 PM
  #801
NumberDummy
1974 F600
Originally Posted by DeRock1106
VIN: F61DVU21635 / TYPE GVW: F613 / TRANS: O / AXLE: E3L
F61 = F600 2WD (gas).
V = Kentucky Truck Assembly Plant.
U21635 = 1974.
F613 = F600 2WD (gas); 22,000 lbs. Gross Vehicle Weight Rating.
O = Fuller model T-905-B 5 Speed Direct or New Process model NP-542-FL 5 Speed Direct.
E3L:
E3 = Eaton model 16244 Two Speed Rear Axle / 6.50/9.04 / 17,500 lbs. Rear Axle Capacity.
L = Ford 6,000 lbs. Capacity Front Axle with Power Steering.
Old Apr 7, 2018 | 03:44 PM
  #802
Corn73's Avatar
Corn73
B12153 = 1967.
194" Wheelbase.
DSO 220210:
Sorry about the picture size, it wouldn't let me resize it. Does the T of NT mean factory tandem axle? This one appears to have had the frame welded on both sides and maybe the tandem added.
Old Apr 7, 2018 | 05:26 PM
  #803
NumberDummy
The rear axle was not an RPO (Regular Production Order) for this truck. It was a Domestic Special Order and installed after the truck left the assembly line.
Who installed it and how it was done is unknown, as the records are no longer available.
The Fuller RT-915 15 speed transmission (usually installed in W/WT1000D w/a diesel), front axle and driveshaft were also Domestic Special Orders.
Old Apr 13, 2018 | 06:23 AM
  #804
Corn73's Avatar
Corn73
Thank you so much for your time and knowledge. Just two more questions please.
*Would the first three of the Vin for a '63-69 N1000 be W10?
*I know two of the three diesels offered were the Cummins 195 and the Detroit 671, but what was the third?
Thanks again.
Old Apr 13, 2018 | 02:02 PM
  #805
NumberDummy
*Would the first three of the VIN for a '63-69 N1000 be W10?
No such thing as W10. 10 = 1/2 ton truck.
Only two are listed.
R00 = 1963/69 N1000.
Cummins: 1963/69 // Detroit: 1968/69.
Old Apr 14, 2018 | 03:23 PM
  #806
Run2trouble's Avatar
Run2trouble
Hello,
I’m hoping that the forum will shrink the picture down.
Im looking for the exhaust manifold with a T4 turbo flange, and gaskets,
Also a intercooler pipe.
Pleqse advise.
Thanks,
ky
Old Apr 14, 2018 | 03:57 PM
  #807
Destroked 450's Avatar
Destroked 450
Why to you want a T4 manifold for that small of a engine?
As for the pipe, a salvage yard for shop that can cut out the bent section and weld in a new piece.
Old Apr 14, 2018 | 04:35 PM
  #808
Run2trouble
Have a s366 turbo on it.
Old Apr 14, 2018 | 04:39 PM
  #809
Destroked 450
How laggy is that?
Old Apr 14, 2018 | 05:29 PM
  #810
Run2trouble
Not to bad. Runs good when it lights up. I would like a little bigger p3000.
