Now what
Old Nov 14, 2010 | 04:32 PM
  #211
AverageX's Avatar
AverageX
Originally Posted by b-uno
3500$ wow! doesnt seem to bad. shortblock is without heads right?
wonder what shipping is on one of them!
It doesn't say it has heads so I'm guessing not . I'll find out tomorrow
If I drop ship it on a common carrier it shouldn't be too bad. A skid spot from Ohio was 175.00 .
  #212
Skip1970's Avatar
Skip1970
Originally Posted by AverageX
Thank you for linking that for me .
WOW is right .Either way it's gonna be costly for me thats for sure . But the Stealership wanted $13000. or $10500. not that I was paying that but it probly will be at least half if the blocks shot which it's really looking like .
I just want to know what happen ? I will know tomorrow . We all will
im sure its just the front cover. that should be pretty cheap.
Old Nov 14, 2010 | 04:35 PM
  #213
AverageX's Avatar
AverageX
Maybe you will understand this .
The mechanic said he could hear air in the front cover and #2 and #8 cylinders ???
Old Nov 14, 2010 | 04:44 PM
  #214
Skip1970's Avatar
Skip1970
well dang it. i dont like the sounds of that.
Old Nov 14, 2010 | 04:46 PM
  #215
AverageX's Avatar
AverageX
I sure hope it's the front cover because I want to have some other stuff done since it's out . Gauges on the pillar and some stuff he recommended.
Old Nov 14, 2010 | 09:45 PM
  #216
Maintain's Avatar
Maintain
With the engine on the stand and the oil pan off, I plugged up all the cooling system hoses.
I pressurized the cooling system again and no pressure would build. It was all leaking out of the bottom of the front cover. If I recall correctly it was coming out where the oil pickup tube bolts to it. Anyway as I barred the engine over I started hearing air pressure noises coming out of the cylinders number 2 and 8. I am unable to locate a crack or any decisive reason so I am going to pull the glowplugs and redo it Monday.
Old Nov 15, 2010 | 12:05 AM
  #217
portsample's Avatar
portsample
Subscribing...just read the whole thread.
Wow- I need to go lie down.
I am sending positive thoughts your way.
Old Nov 15, 2010 | 02:19 PM
  #218
helifixer's Avatar
helifixer
[quote=PaysonPSD;9543491]Mine's a Mar '98 build date. What's your's.
Sept. '98 not as early as yours.
Old Nov 16, 2010 | 11:58 AM
  #219
PaysonPSD's Avatar
PaysonPSD
The build date might be why I don't have the radiator ATF cooler and you do. I just as soon not have the atf cooler in the rad. Just another place for a leak and you wouldn't even notice it for awhile.
Old Nov 16, 2010 | 02:29 PM
  #220
rbaker6336's Avatar
rbaker6336
Originally Posted by PaysonPSD
The build date might be why I don't have the radiator ATF cooler and you do. .
Mine has a Dec '99 build date and no radiator ATF cooler
Old Nov 16, 2010 | 06:12 PM
  #221
AverageX's Avatar
AverageX
Well so far it's a VERY strange hole in the front cover . There are still concerns about #2 and #8 but I have to put a new front cover and water pump on to test it. So for now this is the culprit.
Old Nov 16, 2010 | 06:13 PM
  #222
Maintain's Avatar
Maintain
Well found a hole in the front cover and strange wear marks. The water pump also has serious issues... I will let Tom update this.
Old Nov 16, 2010 | 06:14 PM
  #223
Maintain's Avatar
Maintain
Well I guess he beat me to it
Tom...... PM on the way.
Old Nov 16, 2010 | 06:15 PM
  #224
AverageX's Avatar
AverageX
Can you explain for me ? Thanks again for all the help
  #225
AverageX's Avatar
AverageX
No you have to explain . It's better that way .
