Now what
Old Nov 6, 2010 | 08:21 AM
  #136
AverageX's Avatar
AverageX
Originally Posted by cj45lc
Milkshake anyone..... My bet would be that dang oil cooler, don't think it could mix oil & water at that rate anywhere else.
The other thing is that the water pump looks new. I ran an Oasis report when I bought the truck . I have to look and see if the replacement is on there and when . The cavitaion behind the water pump could be one other area .
I really looked at that cooler but it could be the cooler .
OK the Poll starts
1- Cooler ( CJ )
Old Nov 6, 2010 | 08:47 AM
  #137
clem1226's Avatar
clem1226
is there any coolant left in the radiator at all after it drains down? The oil cooler is lower that most of the radiator so it would drain the radiator almost complete if it is the problem, the water pump impeller sits around the center of the radiator so the water level in the radiator would only drain down to the level of the water pump....folllowing that if it was a head gasket water would only drain down to the level of the head....
I'm not sure of an exact way to test how far down the radiator is draining other than filling it with hot water and seeing where the heat ends on the side of the radiator after it drains down........the level of the water in the radiator will give you an idea of the physical location of the leak in the engine.......does that make sense? its early, I can picture how I would do this but my communication skills may be lacking right now.
Old Nov 6, 2010 | 09:57 AM
  #138
damicofuel's Avatar
damicofuel
Just a thought, pull oil cooler, make some block-off plates with gaskets and re-fill water, that will say yea, or ney on the oil cooler!! Just brain storming here!!
Old Nov 6, 2010 | 10:17 AM
  #139
Kwikkordead's Avatar
Kwikkordead
Danny, (mongo75) had a cracked block with some very similar symptoms.
https://www.ford-trucks.com/forums/9...the-cause.html
https://www.ford-trucks.com/forums/9...lock-pics.html
Old Nov 6, 2010 | 11:03 AM
  #140
AverageX's Avatar
AverageX
I understand but not sure if I could see the level
Old Nov 6, 2010 | 11:05 AM
  #141
AverageX's Avatar
AverageX
Thats a great idea too .
Old Nov 6, 2010 | 11:25 AM
  #142
AverageX's Avatar
AverageX
Thanks for the threads. Could that have happened to mine. I was cruising at 70mph down the highway for an hour and looked down and the needle was pinned . Truck never missed a beat.
I guess I'm gonna have to pull the engine and see. I have to find a good diesel mechanic though if I pull it. I cant loose any more work time guessing what it might be.
Around here most diesels are large equipment and dump trucks. Mechanics are around but the knowledge of them is not experience, just books.
I have a large equipmeent guy that I was buying my Stanadyne additive from and he said he has a guy who works on PSD's. I'm gonna call him Monday and see.
Now the question is do I just take it apart and see what's wrong (I feel I have to now) or just buy the bottom end and re-install all my stuff
The wife says sell it and buy another one but I think that's just asking for more problems
Just for the record here, my son car's T-stat stuck shut and blew the expansion tank cap and he broke down. I was just out buying parts for his car
When it rains it pours.
Old Nov 6, 2010 | 12:03 PM
  #143
clem1226's Avatar
clem1226
where are you located? someone here might know of a reputable shop in your area?
Old Nov 6, 2010 | 12:16 PM
  #144
AverageX's Avatar
AverageX
I'm 20 minutes North of Philadelphia
Old Nov 6, 2010 | 12:19 PM
  #145
AverageX's Avatar
AverageX
See my user location .
Nrth of Pretzels and cheesesteaks
Old Nov 6, 2010 | 03:16 PM
  #146
cj45lc's Avatar
cj45lc
What about taking the oil cooler of & rigg up those blow-up pipe plugs to do a leak test? At the rate of leak you got it wouldn't take much pressure to show up. Hate to see you take it to someone & get raped, But Marty on PSN knows these things inside out, good guy & he is not far Elkton, MD. If it comes down to that I might be able haul it for you
Old Nov 6, 2010 | 03:33 PM
  #147
AverageX's Avatar
AverageX
I can do that . Not like I havent done it LOL . I looked that cooler over pretty well but I guess ya never know unless you test it
I'll pull it out tomorrow and test it . If it's not bad we will have to get Marty involved and I'll PM you
Thanks for the help
Old Nov 6, 2010 | 04:20 PM
  #148
cj45lc's Avatar
cj45lc
Good luck bud, hope it something stupid like a o-ring got cut or ????
Old Nov 7, 2010 | 04:17 PM
  #149
AverageX's Avatar
AverageX
Well I tested the cooler and it's good. It's officially "not" the cooler . It's been tested and I guess I'm pullin the motor .
Give me 20 minutes or so and I'm gonna post the pics and test procedure
Old Nov 7, 2010 | 04:55 PM
  #150
AverageX's Avatar
AverageX
Ok here we go.
I bought the Test Ball and hose clamps
Took the cooler back out and popped it apart
Cleaned the cooler but left the oil/water(milk) in cooler
Here's the end cleaned up
Cut the test ball in half and slide on each end and tighten
Attach bike pump and start pumping
This is all set up .
I pumped it to 5 lbs and I should have seen something either a bubble or something . The cooler is slippery but I pumped it up till the end blew off . Sounds like a shot gun when it blew off .
That's it . Tested and not bad . At least I know it's not the cooler anyway
I found several places within 30 minutes from me that work on diesels . I'm gonna do some interviewing tomorrow . I also have to talk to CJ and see if Marty has any openings and how long it would take to pull it apart
I'll keep you posted . I think that's it for now
