Now what
Old Nov 5, 2010 | 11:49 AM
  #106
AverageX's Avatar
AverageX
Originally Posted by cj45lc
yes it has to run to get air out
Ok Thanks
It started and ran a little rough . I shut it off ,started and ran it for a minute or so shut it down .Started it again and it smoothed out. Gonna start it again in 5 minutes and let it run . Sounds like normal
Old Nov 5, 2010 | 11:55 AM
  #107
cj45lc's Avatar
cj45lc
Let her run & turn your heat on high. Hope you don't gain on oil diptick.
Old Nov 5, 2010 | 12:02 PM
  #108
clem1226's Avatar
clem1226
dude, it's been almost 10 minutes...wheres our update? I mean gosh in this age of instant information you should for the consideration all of us strangers have a webcam on your head and be doing a running commentary, or at the last updating your Facebook every 2 minutes with your mood, relationship status and the progress of the repair in addition to "tweeting" a play by play of the repair.
sorry, I am in a "funny" mood this morning, guess it's a Friday thing. Hope things are turning out well for you!!
Old Nov 5, 2010 | 12:17 PM
  #109
BDalton's Avatar
BDalton
I recently tried to do the flush and fill on my truck but could not remove the block plugs. I ended up flushing with more water flushes to try and compensate for the coolant that I could not drain from the block. That being said, when I filled back up all I got in was about 5 gallons, leading me to believe the block holds about 3 gallons of coolant. So unless you drained the block your experience and coolant requirements pretty much mirror my experince not draining the block. HTH.
Old Nov 5, 2010 | 12:20 PM
  #110
cj45lc's Avatar
cj45lc
He is doing a he-- of a lot better than I could, I don't even know how to put up a pic. But yea that's funny right there
Old Nov 5, 2010 | 12:22 PM
  #111
clem1226's Avatar
clem1226
I agree, he is doing great!!! I hope once the repair is finished he sticks around!!
another valuable asset to FTE
Old Nov 5, 2010 | 12:25 PM
  #112
cj45lc's Avatar
cj45lc
I hope he sticks around also, those where great pics of the oil cooler
Old Nov 5, 2010 | 12:30 PM
  #113
AverageX's Avatar
AverageX
ok ok I'm NERVOUS . It's runnin and runnin Heats on ,Got heat
Old Nov 5, 2010 | 12:32 PM
  #114
AverageX's Avatar
AverageX
Everything went well . Truck sounded like a Jet on the runway .Quieted down and just sat an idled . I just turned it off .
Old Nov 5, 2010 | 12:34 PM
  #115
AverageX's Avatar
AverageX
That is sooo funny . But True !!
Old Nov 5, 2010 | 12:36 PM
  #116
cj45lc's Avatar
cj45lc
Oil level & everything OK
Old Nov 5, 2010 | 12:44 PM
  #117
AverageX's Avatar
AverageX
AHHHHHHH !!!
Old Nov 5, 2010 | 12:49 PM
  #118
AverageX's Avatar
AverageX
After I shut it off . The tank drained some and then the pic above .
Now What ?? . Do I pull the water pump ? Should I just pull the motor ?
No leaks anywhere . Nothing .
Old Nov 5, 2010 | 12:50 PM
  #119
cj45lc's Avatar
cj45lc
Dam..................It
Old Nov 5, 2010 | 01:06 PM
  #120
cj45lc's Avatar
cj45lc
Could that be from the oil left in the engine? I would put pressure on the coolant cap 15-17lbs & see if it leaks down. Do you think you might have torn one of the o-rings putting it back together. IDK just thinking out loud.
