Now what
Old Nov 4, 2010 | 12:58 PM
  #91
cj45lc's Avatar
cj45lc
Looks like you got a pretty good plan there X. Got it running yet! Good luck Bud
Old Nov 4, 2010 | 03:27 PM
  #92
AverageX's Avatar
AverageX
Thank you . Nothing yet . Just got the O rings
Old Nov 4, 2010 | 03:31 PM
  #93
AverageX's Avatar
AverageX
Got um Thanks Bob !!!
Old Nov 4, 2010 | 03:34 PM
  #94
PaysonPSD's Avatar
PaysonPSD
Originally Posted by AverageX
What the hell do you call this thing? I can see some uses for it, if modded.
Hope all goes well with the cooler.
Old Nov 4, 2010 | 04:05 PM
  #95
Skip1970's Avatar
Skip1970
man i hope its them cooler orings so you can have it fixed up soon.
Old Nov 4, 2010 | 06:51 PM
  #96
BDalton's Avatar
BDalton
Subscribing.
Old Nov 4, 2010 | 07:21 PM
  #97
AverageX's Avatar
AverageX
Me too . If it's not I'm gonna have to become a diesel mechanic
Old Nov 4, 2010 | 07:31 PM
  #98
AverageX's Avatar
AverageX
Thanks It's a Test Ball Plug
I was gonna cut that ball in half and hose clamp it to the coolant cap . It has a air valve in the end which I was going to screw a pressure gage to .
Same thing with the cooler . half on one end and the other on the opposite end . Pressurize and instant pressure test . They come in 2,3 and 4 inch.
Old Nov 4, 2010 | 07:44 PM
  #99
AverageX's Avatar
AverageX
One more question for the morning .
The gaskets on the adapter caps (cooler ends) Do they require any gasket seal ? They look as if they are pre-pressed with a sealant
Old Nov 4, 2010 | 08:36 PM
  #100
AverageX's Avatar
AverageX
I figured if I'm gonna do this thread I may as well make it as complete as possible. I'm looking at the end cap of the cooler (oil filter end ) and if you look in these pics. The coolant was positively passing the front O ring allowing coolant into the oil . I'm not sure this will be the exact cause of my problem but it definitely was leaking.Something to think about if you have a 7.3 PSD. My truck is an 01Ex and has 142K on it.
The white spots are the passing points around the black line.
Old Nov 5, 2010 | 07:24 AM
  #101
FTrucker's Avatar
FTrucker
Sub'd.
Good LUck!!
Old Nov 5, 2010 | 09:02 AM
  #102
AverageX's Avatar
AverageX
Morning UPDATE !!
Cooler is together and installed in the truck. That was some bugger to press together.
Not bad to install. You have to really roll around and have a bright drop light. I don't have a torque wrench so I'm running to get one. I need a gear puller anyway for my son's ATV . Any excuse to buy tools is ok in my book .
I'll then put the hoses back ,block heater and then fill er up . Be back soon
Old Nov 5, 2010 | 09:18 AM
  #103
cj45lc's Avatar
cj45lc
Got the fingers crossed for you bud
Old Nov 5, 2010 | 10:52 AM
  #104
AverageX's Avatar
AverageX
I need some help . Truck is all back together .
New oil filter ,14qts of oil . I 'm filling the cooling system and can only get 5 gallons in ?
It takes 8 .
Should I start it with the cap off and add it as it warms up ???
Old Nov 5, 2010 | 11:38 AM
  #105
cj45lc's Avatar
cj45lc
yes it has to run to get air out
