Now what
Old Nov 1, 2010 | 08:52 PM
  #46
AverageX's Avatar
AverageX
Originally Posted by PaysonPSD
You probably don't need a new one. The cooling core is pretty stout. The cooling core can be cleaned as well as the end caps. Any leaks are almost always due to a bad o-ring. If you buy used you would still have to get a gasket and o-ring kit to redue the used one. Is there a machine shop close by that can boil out the three parts?
FYI to those reading this thread : Try not to confuse the pics posted by AverageX and those posted by quader94. Had me goining for a bit.
Guys quader94 is my son .I asked him to use his camera for a close up . The other pics are my blackberry. They are ALL my truck an 01 EX
The concern I have is the pics quader 94 posted show wear. On the edge of my end caps the edge is wearing away . Do you think it's ok if I just re-use new O rings ? or should I get a recon or new ?
Old Nov 1, 2010 | 08:55 PM
  #47
AverageX's Avatar
AverageX
Originally Posted by USAF CCM
Give Parts Guy Ed a call.....he's a sponsor of this forum.....see above. Keep us posted! Subscribing!
Can you link Parts Guy Ed"s # ? I can't find it .
My truck is apart and I REALLY need to get it back on the road .
Old Nov 1, 2010 | 09:06 PM
  #48
AverageX's Avatar
AverageX
If you guys say "go" with new O rings I'll order a set from DieselOrings and have them overnight them and reinstall the cooler I have. I went out in the garage and looked at the caps . The ( first) O ring sits back on the neck of the cooler so maybe that erosion isn't an issue but I don't want to take a chance. Ford has one for $290. O rings are $58.
Old Nov 1, 2010 | 09:11 PM
  #49
AverageX's Avatar
AverageX
By the way the inside of the cooler was clean as a pin. The element port was dirty with scale I have it all cleaned up . The other concern I have is if there is a leak on the inside coil . It looks really clean though .I have a cleaner (AqaSolv) that cleans anything. I could run a cup or 2 of that through the coil but it looks pretty good to me
Old Nov 1, 2010 | 09:51 PM
  #50
BigAlsPSD's Avatar
BigAlsPSD
Here's Ed's site. www.partsguyed.com
Old Nov 2, 2010 | 03:39 AM
  #51
AverageX's Avatar
AverageX
Thank you for the link
Old Nov 2, 2010 | 03:46 AM
  #52
AverageX's Avatar
AverageX
So what's everyone think ? Based on the(quader94) end cap pics should I just get new O rings or get a new cooler ?
Thanks again for all the help !!
Tom
Old Nov 2, 2010 | 12:07 PM
  #53
PaysonPSD's Avatar
PaysonPSD
OOPS, that's right. I forgot about the original thread. SORRY.
I would recondition what you have unless you've got a spare 300 bucks laying around. I have a spare cooler core from a oil cooler R&R. Very good condition (105K). The only reason I replaced it was I got a helluva deal on a reman core. I know you are in a short time frame, but if the one you have does not work out shoot me a PM.
Old Nov 2, 2010 | 04:13 PM
  #54
AverageX's Avatar
AverageX
I'll definitely keep that in mind. Thank you !
Here's a NEW question .???
Would it be a bad idea to just replace the O rings and not have the core tested ? It looks like new inside but the end caps are my concern as shown in the pics. It's a tough call. I have no problem spending the 300 bucks on a new cooler but if It's not the cooler than I just wasted money . I'm keeping the truck so I guess it's worth it ???
Old Nov 2, 2010 | 04:57 PM
  #55
AverageX's Avatar
AverageX
shoot me a PM.
Tried but don't see the tab ? I left one in your visitors messages . PM me ?
Old Nov 2, 2010 | 08:04 PM
  #56
AverageX's Avatar
AverageX
OK O rings are being overnighted . Should have them Thursday am. I'll try getting my current cooler tested if not I'll be getting one from a member
I'll put it back together then
I'll be looking for my next venture into filling the pan and cooling system to start the truck
Old Nov 2, 2010 | 08:17 PM
  #57
PaysonPSD's Avatar
PaysonPSD
I sent you a visitor message.
It dosesn't look like you have Receive PMs activated.
You have enough posts to PM. Left click on my username. On drop down left click on Send a private message to PaysonPSD. Should work.
Old Nov 3, 2010 | 10:04 AM
  #58
AverageX's Avatar
AverageX
Quick question . The nut that holds the block heater element in the oil filter housing . What gets put on the threads when re-installing. That baby was tight to get out but looks like the brass threads are clean and nothing on them See pic .
Thanks
Tom
Old Nov 3, 2010 | 11:17 AM
  #59
PaysonPSD's Avatar
PaysonPSD
Thanks
Tom
I didn't use anything. Just cleaned and re-installed. No leaks.
Old Nov 3, 2010 | 11:42 AM
  #60
AverageX's Avatar
AverageX
Ok Thanks . Cody's looked like he had something on it
