- Dipstick relocation
- 86 Hydraulic Clutch in a 82
- Lift kit opinion
- Help 1984 f150 4.9L 300-6 4x4
- Engine coolant check
- Quick wheel question
- 83 F150 info
- 1985 Fl50 302 2bbl dies!
- 83 F250 (again) Fuel issue...or something
- 1981 F-100 I6 Compression/Timing
- Tune Up advice for an 86 F-250 351 w with a 5.8L
- Alternatative to stock fuel selector valve
- HELP Fuel Pumps Quit - 460 w/Hot Fuel Handling
- I'm selling out....and this is why:
- 1985 Brake Problems
- New here
- 81 f350 clutch bracket
- flickering headlights!!!!
- 82' 300 I6
- spongy stuff cab corners
- radiator drain plug replacement
- Engine cleaning
- Clutch assy into block size
- 1985 F150 replacing fuel pump help
- Any long(ish) term Spectra F26D tank comments?
- replacementar pump assy for rear tank where??
- Lesson learned about rust prevention
- Sticky Brake Pedal
- Removing main tank question
- 86 F150 5.0 auto- idle rough, lurches at stops
