flickering headlights!!!!
Old Sep 24, 2012 | 07:40 PM
BOthatGAboy's Avatar
BOthatGAboy
Cool flickering headlights!!!!
my headlights flicker then the blinker flashes the gauge lights don't come on and i have no running lights any ideas i have checked the fuses?
Old Sep 24, 2012 | 08:12 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The Headlight switch has an internal circut breaker.
When there is a wiring fault, or short circut, the headlamp switches circut breaker trips and resets itself. This is what causes the blinking.
The circut breaker in the headlamp switch can also be triggered when the headlight switch is worn out.
From what you are saying with your symptoms, with the instrument cluster and the marker lights are also not working, I'd say your headlight switch or the wiring at the headlamp switch are at fault.
I'd buy a new good quality headlamp switch, and while installing it, check the wiring to the switch at the switch connector for burns, bubbling or weirdness.
You never did say what year you are working on. The 1980 takes a different headlamp switch and is wired differently to the 1981-1986.
With model year information I can tell you how to test the headlight switch with a multimeter.
Old Sep 28, 2012 | 03:21 PM
kraylake's Avatar
kraylake
Do you have or have you ever had a wiring harness for a trailer? If so trace the trailer plug from the rear to where it is spliced into the main harness. I had the same sort of problems on my 1980 F350 400 cid untill I removed the whole dam thing. Someone had used those crimp-splices to gain access to each wire and the connections were bad.
Also check/clean any grounds you can find especially under the hood on the inner fenders near the headlights.
Old Feb 19, 2013 | 08:53 PM
BOthatGAboy
HEY SORRY IT TOOK SO LONG IT IS A 1980 it was involved in an accident before i bought it and he put on a trailer lightone(the round one lol) and now nothing on the right side works?
Eddillard79
Oct 2, 2014 08:32 PM
Tyler S
Apr 26, 2014 10:03 PM
awright72
Nov 4, 2013 09:06 PM
ErrorS
1978 - 1996 Big Bronco
18
Feb 17, 2013 03:15 AM
Fordtoughranger
Electrical Systems/Wiring
Sep 19, 2006 12:31 AM
